Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 03-03-2006, 11:48 AM   #1
NEEdENGINE
Member#: 108855
Default 02 Harness+ECU Work For ALL????
Hey guys Im building a VW Bug of death and I have plans for a subby engine. Will a 2002 WRX Engine harness and ECU work on a 98 Legacy 2.2 Liter??? I got told that as long as the harness and the ECU match they will work on any subaru engine TRUE???????????
NEEdENGINE is offline   Reply With Quote
Old 03-04-2006, 11:42 AM   #2
stircas
Member#: 53886
the person that told you that is a very smart person and you should pay them for any valuble info they give you! i think you would be cool just need tune. (bug of death)
stircas is offline   Reply With Quote
Old 03-04-2006, 12:33 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um no won't work (won't work well anyway)
the 98 has a low density crank wheel and is sohc
and FWIW the wrx harness+ecu actually has some value to it i would guess in the 500-600 range if its complete
i would try and find a complete setup from a pre 96 car.
the obd-2 (1996 and later) ecu will look for other strange things like purge valves on the gas tank and throw the car into limp mode
check out the conversion forum there are several ppl that have done subarus into porsche conversions
Old 03-04-2006, 12:57 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You should use the harness and ECU that goes with the engine.
Old 03-04-2006, 02:12 PM   #5
NEEdENGINE
Member#: 108855
How about a 2002 Ecu and Harness with a EJ20T engine from japan???
Old 03-04-2006, 02:26 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
same proublem
there are several sand rail companys that sell pretuned stand alone ecus for what you are dooing either the 2.2 or the jdm ej20T
outback motorsports is the first one that comes to mind
the 02 +ecu is very very smart it will ot respond well to other engines
Complete ECU pinouts for all GC8 JDM EJ20; ej20g, ej20k, ej207 swapstar Subaru Conversions 86 08-11-2015 10:40 PM
Will 02-03 Ecutek Ecu Work For 2004 Wrx 01EJ20NOS Engine Management & Tuning 0 09-19-2007 04:30 PM
ECU question [for all you gurus] kellie00 Texas Impreza Club Forum -- TXIC 3 04-17-2006 09:49 PM
02/03wrx ecu work on a 04? Blackpantherwrx Engine Management & Tuning 8 08-25-2005 06:52 AM
Wire harness re-work for swap rocketman1 Subaru Conversions 3 08-09-2005 03:23 PM
