Old 03-03-2006, 04:52 PM   #1
FuriousGeorge
Member#: 108975
2013 Impreza
Marine blue
Default GC8 w/EJ20 exhaust
Simple question...Will a cat back exhaust made for a GD chassis WRX line up properly on a GC8 with an EJ20 swap or am I going to have to make custom piping?
FuriousGeorge is offline   Reply With Quote
Old 03-03-2006, 05:13 PM   #2
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
I put a Greddy Evo2 on mine and had to weld a 3 inch extension to the stock downpipe for it to reach. Later I put a Meaghan dp on and it bolted right up without modification. The hangers don't all line up, but if you hold the muffler up with a couple kartboys, you won't need the rest.
-Rob
tweakling is offline   Reply With Quote
Old 03-03-2006, 06:23 PM   #3
FuriousGeorge
Member#: 108975
2013 Impreza
Marine blue
so as far as the cat-back is concerned I would just need to relocate the hangers?
Im asking because I found a GD chassis exhaust that is probably around $200 cheaper than most GC exhausts I've seen.
Old 03-03-2006, 06:26 PM   #4
Mann Engineering
Member#: 77164
2015 STI CWP
2013 BRZ Limited
As long as you are using a USDM WRX downpipe, you can use any USDM WRX catback. However, only one hanger mount will not fit on the GC chassis because the GD hanger is lower.
For the USDM swaps, you can use any USDM WRX turboback and it will fit.
Hope this helps.
Regards,
Gary
Mann Engineering is offline   Reply With Quote
Old 03-03-2006, 06:55 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its the third hanger for the cat back section its not nessicary
Old 03-04-2006, 01:44 PM   #6
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
Yeah, like I said, if you just use stiff hangers in the back, you won't need the one in the middle.
Old 03-04-2006, 01:57 PM   #7
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
or you can do what I did and talk to Rich at MadDad. He can talk to the shop that makes his stuff and they'll put the correct hanger points on for you.
subydude is online now   Reply With Quote
Old 03-04-2006, 10:23 PM   #8
Daddy's SCP
Member#: 36596
2009 135i
Alpine White
The rear hanger on the axleback section of the catback has the hanger flipped 180 degrees and a slight difference in height. As mentioned you can still use a late model WRX catback less that one hanger but you'd want to use something stronger like the Kartboy's as mentioned.
Rich
Daddy's SCP is offline   Reply With Quote
Old 04-21-2006, 03:16 AM   #9
LegendaryHarry
Member#: 104696
sorry to hyjack
will the wrx exhaust fit on a GC8 with stock engine?
thanks
LegendaryHarry is offline   Reply With Quote
Old 04-21-2006, 11:03 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
kinda vague
a real gc8 is a turbo car
a gc6 or gc2 .. nope the flanges are differnt .. but not so much that 30 min at he muffler shop won't solve
Might buy a GC8 With ej20 swap bhkami Subaru Conversions 5 01-04-2007 09:31 AM
a/c suction hose in gc8 with ej20 ej20swap Subaru Conversions 4 07-12-2006 02:28 PM
GC8 RHD EJ20 Sti-RA conversion in process supermoose Subaru Conversions 21 08-07-2005 11:30 AM
help a subi newbie....gc8 w/ ej20 swap RS_to_WRX_swap Subaru Conversions 35 10-16-2003 09:24 PM
lets start a L -->JDM GC8 WRX ej20 conversion thread supermoose Subaru Conversions 13 10-08-2003 12:34 PM
