Old 03-03-2006, 07:24 PM   #1
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
Default Alcoholics Anonymous
This is cool that we now have a sub-forum to help our cars deal with this addiction. Chime in if your car has become an Alky... or a tea totaler (water injection) that may fall off the wagon some day
Post a little bit about your setup and I'll keep a running total of who has what system.
-Steve. (Pssst, thanks Jon)
Code:
Name		 Type of System			 Car and Mods
Blennophobic	Snow Performance 50/50 water/meth	 WRX w/SR-30 @ 20psi (ECUTEK)
Davenow		SMC 50/50 water/den.alc		 STi VF39 @ 20psi
Zornorph		SMC 50/50 water/alc			 STi VF39
banzai		SMC 50/50 water/meth 		 WRX 2.5L w/VF22 @ 18psi (CobbST)
scoobie1		Coolingmist 100% methanol		 STi VF39 @ 19psi
tribalwrx		SMC 100% methanol			 WRX TD04 @ 20psi (UTEC)
RaiN		SMC 100% alc 			 WRX w/VF34 @ 19psi (UTEC)
aprazma		SMC 100% methanol			 WRX w/TD05-16G @ 19psi
ULTIMATE CC	Snow Performance water/meth		 EVO8 @ 28psi
DISCOPOPE	SMC 50/50 alc/washer fluid		 STi TD06-20G @ 21.5psi (UTEC)
mpower22		SMC 50/50 water/alc			 STi 20g @ 23psi
modifyd		Snow Performance 50/50 water/meth	 STi FP green @ 26psi
BVM		SMC 25/75 water/alc			 WRX w/SR-30 @ 20psi (ECUTEK)
mindchatter	SMC 50/50 water/alc			 STi w/SR-40 @ 22psi
nosmo		SMC 50/50 water/meth 		 WRX
CoolRex		SMC 100% methanol			 WRX w/TD05-18G @ 22psi (ECUTEK)
jtanoyo1		Aquamist 2d 50/50 water/meth		 JDM STi @ 1.5bar (Autronic sm4)
scooby007		Coolingmist 100% methanol		 WRX w/VF34 @ 22psi
DonkeyPunch	Snow Performance 50/50 water/meth	 WRX w/VF22 @ 22 psi (UTEC)
testes1010	Coolingmist 50/50			 WRX w/TD05-20G @ 21psi (UTEC)
Blennophobic is offline   Reply With Quote
Old 03-03-2006, 08:03 PM   #2
Davenow
Member#: 23676
SMC
50/50 denatured alch/distilled water
05 STI stock turbo- 20PSI
Old 03-03-2006, 08:32 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by Blennophobic
(Pssst, can someone point me to instructions on how to do a table here please)
Name - Type of System - Main Mods
Blennophobic - Snow Performance 50/50 water-meth - EJ205 stg 4
Davenow - SMC 50/50 water-den.alc - EJ257 VF39 at 20psi
You can use the [code]...[/code] construct.
Jon [in CT] is offline   Reply With Quote
Old 03-03-2006, 09:20 PM   #4
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
Former SMC
rebuilt onto 12 Liter Spec C tank
In car fuel Pressure guage to watch the fun
50/50 and loving it.
Zornorph is offline   Reply With Quote
Old 03-03-2006, 09:21 PM   #5
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
SMC 50/50 denatured alky/water
stock turbo, 18.2 lbs.
but not for long......
banzai is offline   Reply With Quote
Old 03-03-2006, 11:44 PM   #6
scoobie1
Member#: 41559
2007 Brocoma
Coolingmist
100% meth
Stock VF39 - 19psi
scoobie1 is offline   Reply With Quote
Old 03-04-2006, 01:18 AM   #7
Davenow
Member#: 23676
Guys be sure to list STI or WRX in your posts Especially if you dont have it in your location.
Old 03-04-2006, 02:36 AM   #8
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.54 Dale tuned
SMC 100% meth
stock tdo4 19-20psi
stage 2.5 utec
tribalwrx is offline   Reply With Quote
Old 03-04-2006, 04:50 PM   #9
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
SMC 100% Alky
VF34 Supporting Mods 19Psi
Stage 4 Utec
Big-Sexy907 is offline   Reply With Quote
Old 03-05-2006, 04:12 AM   #10
aprazma
Member#: 77619
2009 Cayman S
SMC 100% methanol
TD05-16G WRX: 19psi on 91 octane (was 16.5 psi)
271 whp dyno dynamics (was 251 whp)
aprazma is offline   Reply With Quote
Old 03-05-2006, 09:52 PM   #11
Ultimate Collision Center
Vendor
Member#: 69072
Snow Performance 100% Methanol or 50% Methanol/50% Distilled Water
EVO8 @ 28psi
Ultimate Collision Center is offline   Reply With Quote
Old 03-06-2006, 05:19 PM   #12
banzai
Member#: 63926
deck EJ 20G stroker
good point, I have a 05 wrx, please change it on the table when you get a chance.
Old 03-06-2006, 06:03 PM   #13
El Supremo
Member#: 38388
tribalwrx, RaiN, aprazma and whomever at ULTIMATE CC
A little bit off the subject since I don't have my kit yet. At what PSI (boost level) did you set your Alky/Meth/Water system to kick-in, (4psi, 5psi, 6psi???) cut-out? What the lowest PSI level (on-set of boost I hope) can you set the system? I don't mind using more Alky/Meth/Water mixture to get an early low-end kick in the pants.
My birthday's March 11th and this is going to be me and my wife's birthday present to me. Want ta fall off the wagon something fierce.
El Supremo is offline   Reply With Quote
Old 03-06-2006, 06:20 PM   #14
Ace009
Member#: 70353
2004 WRX
I'm interested in knowing what EM you guys are running w/ these kits.
Is it possible to add that to the list also? - pleeaase.
Ace009 is offline   Reply With Quote
Old 03-06-2006, 06:41 PM   #15
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
04 STi deadbolt td06 20g homebrew kit soon to be replaced with an smc kit.
dyno'd 309 on a mustang(stock sti's pull 220's). i believe we were running 21.5psi.
we ran into some dire surging issues and called it a night.
hence the upcoming switch to something with a progressive controler.
running 50% denatured and 50% washerfluid.
running utec now, swapping to accessport quite soon.
DISCOPOPE is offline   Reply With Quote
Old 03-06-2006, 07:09 PM   #16
Vendor
Member#: 69072
The rule of thumb for onset boost in most cases is about a 1/3 of your max boost, I run it on my evo so I have it turn on at 9lbs. It doesn't have to be exact but its a good place to start and you (or your tuner) can adjust from there.
Old 03-06-2006, 08:29 PM   #17
banzai
Member#: 63926
deck EJ 20G stroker
i wasn't asked, but i start spraying at 7 psi, and my max is set to the top of the scale.
i run SMC....and only 18.2 lbs of boost peak.
Old 03-06-2006, 08:45 PM   #18
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
smc 50/50 h20 alchy
sti...20g...23psi....
mpower22 is offline   Reply With Quote
Old 03-06-2006, 09:31 PM   #19
Blennophobic
Member#: 25886
2003 WRX Rally Blue
I don't think it's necessary to list EM in the table. The type of EM is not an important part of the equation, only that it's tunable to take full advantage of the water/alky injection benefits.
-Steve.
Old 03-06-2006, 09:40 PM   #20
El Supremo
Member#: 38388
Banzai and CC,
Thank You for your input. General Consensus looks to be a 5-7 psi setting before the system becomes active (spraying) for most with typical WRX Stage-4 (me, sorry I didn't state my set-up in the initial question) modifications. STI's look to be similar. I've also found other posts from different threads on NASIOC & IWSTI recently that seem to support the "1/3 of total boost before activation" rule.
Thanks again,
Supremo
Old 03-06-2006, 09:45 PM   #21
Vendor
Member#: 69072
EM is very important in some cases as it can decide what type of kit you should run and if you really need failsafes and if so what kind.
Old 03-07-2006, 02:25 AM   #22
entropy138
Member#: 87446
2005 STI
3 second start club
I agree. One use I can think of is the FIA2 of the Aquamist is 'possibly' not cooperating with the Hydra and since Phil's integrated kit is still in the works, it'd be nice ot see what other fellow Hydra users are currently using for water injection.
If EM is listed then I don't have to bug each of you Although I can find out in other threads and I actually know what EM system most all of the people on the list are using - someone else may not...
(Note I say possibly because I am aware of one person having an issue and have not been able to find evidence of anyone else successfully driving the FIA2 off of an injector signal from the Hydra... nor have I come across info detailed enough for me to feel comfortable diving into controlling the HSV via PWM map... Note to Phil - the demand is here - I have money burning a hole in my pocket that Garret is trying to swindle out of me j/k... kinda)
entropy138 is offline   Reply With Quote
Old 03-07-2006, 09:59 AM   #23
modifyd
Member#: 79688
2004 STI
snowperformance kit with the safe injection
3" inlet green @ 26 psi
50/50% meth/water
modifyd is offline   Reply With Quote
Old 03-07-2006, 06:16 PM   #24
banzai
Member#: 63926
deck EJ 20G stroker
I am using Cobb street tuner on mine.
Old 03-07-2006, 07:03 PM   #25
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
'02 WRX
SMC w/ Spec C 12l tank
75% Alcohol 25% water
APS S/R30 turbo @ 20psi
ECUTEK
BVM is offline   Reply With Quote
Alcoholics Anonymous website is pretty damn nice. NITROS Off-Topic 23 12-15-2006 08:05 PM
The Official OT Alcohol Snobs/Obscure Alcohol Thread shinsain Off-Topic 68 01-17-2006 07:49 PM
OT alcoholics - Rate your alcoholism dr_wheel Off-Topic 41 06-02-2005 02:59 PM
Taking train from CO to NC... bring my own alcohol or drink provided alcohol? Dolphin Overton Off-Topic 19 12-18-2004 11:21 PM
Alcohol Abuse Up, but Alcoholism Down sugar Off-Topic 10 06-11-2004 06:38 PM
Message Board Statistics All times are GMT -4. The time now is 11:30 PM.
