Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 03-07-2006, 11:13 PM   #26
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
'04 STi SR40'd @ 22psi
SMC 50/50 alcohol/water blend
mindchatter is offline   Reply With Quote
Old 03-08-2006, 01:16 AM   #27
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
mods, sticky this please!
banzai is offline   Reply With Quote
Old 03-08-2006, 01:31 AM   #28
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Just got done with the install a few seconds ago.
Running straight H20 for the time being ( don't have meth in the garage)
Will most likely run 50% 50%
Smc Kit
Don't have boost set yet, just a bunch of flames
nosmo is offline   Reply With Quote
Old 03-08-2006, 01:32 AM   #29
Randy888
Member#: 89810
2005 STi
Alky was a great mod for me. I'm in a lot of commute traffic so I only go through a gallon a month; however, the power is there when I want it. I would also highly recommend the Cobb AP for the map switching ability when adding alcohol injection. Harman Motive in Torrance, CA tuned my STi and I couldn’t recommend them enough. No problems, daily driver and I track the car every other month or so. I use a race gas map on the track, no alky. List of mods for the car are on Harman’s website in the gallery section (Randy STi) although it appears the dyno sheet displayed is an old 91 map before I added the alky and AP.
Randy888 is offline   Reply With Quote
Old 03-08-2006, 01:46 PM   #30
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
SMC kit here. 100% methanol. Deadbolt td05h 18g with FMIC and supporting mods. Boosting 22 psi. Gained ~ 50 hp and tq. Went from a timing hating car to a timing loving car! EcuTek tuned.
CoolRex is offline   Reply With Quote
Old 03-08-2006, 01:52 PM   #31
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
E85 all the time
...duh .
HamFist is offline   Reply With Quote
Old 03-09-2006, 11:49 AM   #32
jtanoyo1
Member#: 102050
2004 JDM WRX STi
Diamond White
Aquamist 2d with fail-safe control system. Gonna be running 50/50 meth/distilled water mix on stock JDM 2.0L sti for now.
jtanoyo1 is offline   Reply With Quote
Old 03-23-2006, 09:39 AM   #33
banzai
Member#: 63926
deck EJ 20G stroker
Bump and motion for sticky.
Old 03-24-2006, 12:29 AM   #34
jtanoyo1
Member#: 102050
2004 JDM WRX STi
Diamond White
Hey can you please change my mod to "autronic sm4, 1.5bar". Thanks!
Old 03-24-2006, 02:40 PM   #35
scooby007
Member#: 87695
02 illicitwerx WRX
parting out 02 WRX :(
wrx, coolingmist, %100 methanol, vf34 @ 22psi
scooby007 is offline   Reply With Quote
Old 03-26-2006, 11:24 PM   #36
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Hi I'm a 2004 WRX, and I'm and alcoholic..
Snow performance 50/50 mix distilled H20 and Methanol
TurboXS UTEC stg 4, VF22 25PSI for the tune, but I normally run about 21-22 lbs
Stock block WRX 2.0L
DP
DonkeyPunch is offline   Reply With Quote
Old 03-27-2006, 07:49 PM   #37
banzai
Member#: 63926
deck EJ 20G stroker
change mine to a WRX, 2.5L VF22, 18 psi.
currnetly running denat/water, switching to meth/water when i run out of denat.
Old 03-27-2006, 08:47 PM   #38
Hoopty
Member#: 87976
2005 STi
Just curious, but why the change?
Hoopty is offline   Reply With Quote
Old 03-27-2006, 09:48 PM   #39
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
Yezz, boss. How high should I jump boss?
Pssstt... where I come from we ask nicely
Blennophobic is offline   Reply With Quote
Old 03-28-2006, 09:35 AM   #40
modaddict
Member#: 95840
sold to a good bud
awaiting next car
hi im MOD-ADDICT,
Im a wannabe alcoholic.
what would put this thread over the top, would be to have the people with progressive control systems such as the SMC, Coolingmist etc. put up their start and max settings on their controllers. then add those numbers to the list next to their names in another column.
SMC soon.....just wait....wait....wait....wait....wait...wait....wai t...wait.......
modaddict is offline   Reply With Quote
Old 03-28-2006, 01:49 PM   #41
testes1010
Member#: 47145
2012 Gas Saver
DB TD05H-20G'd WRX, CoolingMist 150psi kit, 50/50 mix, UTEC @ 21psi
testes1010 is offline   Reply With Quote
Old 03-28-2006, 02:34 PM   #42
banzai
Member#: 63926
deck EJ 20G stroker
pretty please?
Old 03-28-2006, 02:36 PM   #43
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
How's that turbo on your car? Spool nice? Stock EJ205?
Old 03-28-2006, 02:39 PM   #44
banzai
Member#: 63926
deck EJ 20G stroker
ten GPH nozzle, VF22 on a 2.5L
I get boost almost instantly and spray at 7 pounds, so i go thru a lot of alky.
meth = 3.25 a gallon
denat = 14 a gallon
i am spending more in alky than i am in gas.
also, Steve from SMC seems to think that there is more power to be found in meth than denat, something like 10%, but i would be happy with 5% more powa.
for me teh choice is clear now that i have found a reliable local supplier for meth. only thing is, i have to buy five gallons at a time.
Old 03-28-2006, 08:09 PM   #45
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Aquamist WI 2d complete kit, with the race pump and high-speed valve
Aquamist DDS3 blue bar water injection monitoring system.
i have yet to have my car tuned for the water/meth set up. there is a newer software release coming from UTEK that i am waiting for.
here is what i put down withOUT the water/meth, on 92*
so when i do get it all working *7th April* i should have a few more ponies to the wheel`s
PdXTuning did all of the install.
BREWPUBEAVER is offline   Reply With Quote
Old 03-28-2006, 08:16 PM   #46
E-Wrex
Member#: 94533
2006 FXT Limited
Aspen white /w MT
How much are you expecting to put down? This is Elliott by the way.
E-Wrex is offline   Reply With Quote
Alcoholics Anonymous website is pretty damn nice. NITROS Off-Topic 23 12-15-2006 09:05 PM
The Official OT Alcohol Snobs/Obscure Alcohol Thread shinsain Off-Topic 68 01-17-2006 08:49 PM
OT alcoholics - Rate your alcoholism dr_wheel Off-Topic 41 06-02-2005 03:59 PM
Taking train from CO to NC... bring my own alcohol or drink provided alcohol? Dolphin Overton Off-Topic 19 12-19-2004 12:21 AM
Alcohol Abuse Up, but Alcoholism Down sugar Off-Topic 10 06-11-2004 07:38 PM
