Old 03-04-2006, 02:28 AM   #1
cornerbuddy28
Member#: 88976
Main Ingredients:
WRX motor, PPG's, me
Default leg turbo idle problem + bogs down at WOT
My friend just bought a 95 impreza with a 94 legacy turbo motor swapped into it and we've been having some problems fixing it. When we picked it up it had some serious exhaust leaks and the bypass valve was not plumbed back into the intake and it was having idle problems so it was a rough ride but we got it back home safe and sound. We've been tearing it down, fixing leaks, plumbing issues, fixed up the a few shady contraptions on the throttle we put it all back together. The idle control valve is missing the motor or servo and one of the previous owners had just filled the exposed bearing with some kind of adhesive to attempt to seal it (unsuccessfully).
We started the car up today finally after 4 days of work and here's what's happening... Initially it would start right up and idle around 4000 rpm. So we turned the idle control valve by hand all the way closed and the idle settled to around 1100. So then we tried the throttle for response by blipping it quickly and it would bog down quickly and then rev up as you kept it depressed. We seemed to be able to get the throttle to respond correctly a few times but then the engine would only come down to idle at 3000 or 4000rpm and VERY slowly come down to 1500 or so. The throttle is not sticking and the ICV is closed so we're having a tough time figuring out what's making it stick at a high engine speed and slowly come down and also why it's bogging down on WOT.
One other thing we noticed just now is that originally there was a crank case breather and a head breather that were both plumbed back into the intake and now I think we have them into eachother.
Any ideas?
cornerbuddy28 is offline   Reply With Quote
Old 03-04-2006, 02:34 AM   #2
cornerbuddy28
Member#: 88976
Main Ingredients:
oh yeah and now it won't rev over 4500. ever
Old 03-04-2006, 01:26 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
dollars to dough-nuts they used the impreza ecu not the legacy turbo ecu
the LT IAC is not on the throttle body like the impreza ...my guess thats why they removed it it will NEVER idle/run stock like with that ecu setup (i know first hand- better during the summer but really bad during the winter)
lift up the carpet under the passenger foot rest and see if there is any sign of wire splicing / the codes on the ecu
-j
Old 03-04-2006, 08:30 PM   #4
cornerbuddy28
Member#: 88976
Main Ingredients:
hmmm. Well we reset the ECU today and plumbed those breathers back into the intake and fiddled around with the TPS, ICV, and BOV and now its running like a champ! Boosts about 10 lbs at WOT, pulls hard and it idles around 1000 to 1500.
Old 03-06-2006, 01:59 AM   #5
cornerbuddy28
Member#: 88976
Main Ingredients:
Ok now its cutting fuel at about -5 psi. It will rev high but only if you do it slowly without building any boost. as soon as you get up to -5 or so it just throws you foward and bucks like crazy.
02 wrx hybrid bogging/hesitation at wot around 4400 rpms help!! STiGuy23 Built Motor Discussion 50 10-31-2009 12:41 PM
bogging/hesitation at wot around 4400 rpms help STiGuy23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-20-2009 09:52 PM
Car seems to bog down at 3100 Rpm Patrick1948 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-13-2008 03:12 PM
When bogged down at work, how do you respond? El Camino Off-Topic 17 11-01-2007 03:51 PM
2nd Gear bog down at WOT Chuck Technical Forum Archive 5 08-14-2000 08:25 PM
