Old 03-04-2006, 11:34 AM   #1
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Default Dumping fuel during closed loop.
Just that.. during closed loop I'm definately running uber rich.. to the point that the car died and I replaced the plugs in this 22 degree weather.
I'm running modded stock injectors and a Perrin big MAF. Car ran fine for the first 2500 miles since swinging the new motor and getting flashed. Now it idles like crap and seems to be dumping fuel. The only CEL is from the TGV's not existing.
I'm going to try replacing the MAF and front o2 with known good ones I had in my tool box.
Here's the kicker.. during CL the car should idle no matter what - as long as the front o2 is reading properly and there are no leaks between the MAF and the intake port.. which there appears to be no vacuum leaks or anything. Not to mention the car builds boost as fast as usual I'm not hearing anything out of the ordinary.
PeteDucati is offline   Reply With Quote
Old 03-11-2006, 12:28 PM   #2
canosardines
Member#: 102773
2004 Subaru STi
40 of 42 sardines left
[quote=PeteDucati]as long as the front o2 is reading properlyQUOTE]
Maybe you just answered your own question
canosardines is offline   Reply With Quote
Question on open loop/closed loop fuel delay imprezzing Newbies & FAQs 2 09-19-2006 01:33 PM
Closed loop fuel and higher RPMs jblaine Other Engine Management 6 06-05-2006 08:20 PM
Stuck in closed loop fueling (i think)...need help!!! lowblow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-16-2005 08:35 PM
What exactly is closed loop vs. open loop fuel control? Neek Engine Management & Tuning 5 03-09-2005 12:50 AM
open loop or closed loop fueling for auto? WRXout Engine Management & Tuning 2 06-21-2004 04:12 PM
