Old 03-04-2006, 04:59 PM   #1
NYCshopper
Member#: 5126
Default First Drive: 2006 Porsche Cayenne Turbo S (edmunds.com)
Video @ Link:
http://www.edmunds.com/insideline/do...ticleId=109458
Porsche's 520-horsepower super-sport-utility defies logic and definition
By Chris Walton Email
It was not by accident that Porsche chose to introduce the 2006 Cayenne Turbo S on its own world-class (assembly-line adjacent) racetrack in Leipzig, Germany, as well as in the silty, orange sand dunes outside Dubai in the United Arab Emirates. Why not? Because there is simply no other production vehicle that could possibly manage to perform as well as the 520-horsepower Cayenne Turbo S does in both extreme locations.
"What about the 510-hp Mercedes-Benz ML63 AMG or the 420-hp Jeep Grand Cherokee SRT8?" you ask. While those two might be able to run a competitive lap at the track, neither one is offered with the kind of dedicated off-road hardware (and software) the Cayenne Turbo S has as standard equipment. Besides, its gargantuan power output, locking center differential (optional rear-axle lock), low-range (2.7-to-1 reduction) transfer case and six-way height-adjustable suspension are what differentiate the Cayenne Turbo S from its competitors and make it a unique offering in the ultrasport-utility segment.
And who wouldn't feel anything but glee hammering a nearly 3-ton vehicle around a racetrack (or flying over a dune) at speeds that would seem to suspend the laws of Newton and Euclid? More than a horsepower-fortified sport-ute with the aesthetics of a dented potato, the highly engineered Cayenne Turbo S employs decades' worth of Porsche know-how, track research and pure imagination. Does anybody really need a five-passenger supercar/dune buggy? Probably not, but that doesn't mean you can't want one.
520 horses, or about 1,000 camels
In the Cayenne Turbo S, Porsche increased the already potent Cayenne Turbo's 4.5-liter twin-turbo V8 horsepower and torque 16 and 15 percent, respectively — and yet it consumes no more fuel than its 450-hp brother in normal driving conditions. By enlarging and constructing the twin intercoolers entirely of aluminum, the engineers were able to promote higher efficiency and better flow conditions in the heat exchangers. The result is a reduction of turbo pressure loss by 50 percent. This more rigid system in turn allows the turbocharger pressure to be increased by 2.9 psi up to a maximum of 27.6 psi.
In terms of power output among current Porsches, the Cayenne Turbo S is second only to the 605-hp V10 Carrera GT supercar. Porsche claims the 5,200-to-5,900-pound (depending on options) Cayenne Turbo S will run zero to 60 mph in 4.8 seconds, and we have no reason to doubt it. That's a few ticks ahead of what we expect from its nearest competitors.
However, what's most striking about the Turbo S's driving dynamics is the ever present and ever ready wave of torque upon which the vehicle rides. Maximum torque of 530 lb-ft is available from just 2,750 rpm. There's an effortlessness to the way the Turbo S wills itself to any speed the driver chooses. It's the kind of vehicle that requires periodic speedometer checks because it never feels like it's had enough time nor worked hard enough to find itself at triple-digit speed. If the engine does venture north of 4,000 rpm, the guttural response from the exhaust sounds like a caged lion's roar in anticipation of fresh meat.
A ratio for every mood and occasion…
Porsche's six-speed Tiptronic S automatic transmission is standard equipment on the Cayenne Turbo S. It offers the driver the option of automatic shifts or manual shifting by nudging the selector lever or by thumbing switches on the steering wheel.
In auto mode, the intelligent system "learns" a driver's habits, observes the incline of the terrain and notices cornering G-loads to tailor and/or delay shifting to maximize comfort or performance. Further, the driver may, at any time, intervene in automatic mode by touching the thumb switches, temporarily summoning the manual mode.
We tried both automatic and manual modes on the racetrack and found that while automatic shifting does, indeed, become more aggressive and sporting with each passing lap, the manual mode was best suited to the demands of the driver, offering better control of the vehicle — especially when Porsche Stability Management (PSM) was disabled.
The Porsche Traction Management (PTM) four-wheel-drive system is based on an all-encompassing approach that incorporates a number of different electronic systems and traditional hardware. In simple terms, the engine's power is routed through a central multiplate clutch operated by an electric motor. This clutch apportions power to the vehicle's front and rear axles.
In normal driving, the split is rear-biased at 62 percent to lend a familiar and sporting demeanor. However, unlike similar variable-locking clutch-based systems, PTM can route 100 percent of the drive power to either axle — not a maximum of 50 percent to each. Drawing on information gathered from the vehicle's speed, lateral acceleration, steering angle and throttle position, the system constantly adjusts the power split to both axles.
Many manufacturers' systems end there — with one system that is optimized for either on- or off-road use. Not Porsche. This system is so highly developed and flexible that it's as useful as an all-wheel-drive sports car as it is as a capable snow (or sand) mobile.
…and another set for off-roading
When the pavement runs out, the Cayenne Turbo S is just getting started. With the flick of a switch the reduction gear is engaged and the engine's torque is multiplied 2.7 times. At the same time, PTM, PSM, ABS and automatic brake differential (ABD) are all reset to better manage off-road situations. Should these settings prove insufficient, the driver may operate the same switch again to lock the entire system front-to-rear, thereby driving both axles simultaneously. And if the vehicle is equipped with the Advanced Offroad Technology Package, rocking the off-pavement switch a third time will lock the rear axle's left and right wheels.
If a particularly troublesome obstacle (fallen tree, rock on the trail) presents itself, the front and rear antiroll bars may be electronically decoupled for an additional 2.4 inches of suspension articulation that keeps the vehicle more upright while traversing the hurdle. Additionally, the Cayenne Turbo S features a hill-descent mode wherein the driver removes his feet from both pedals and the Cayenne safely inches its way down a slippery slope at a prescribed speed.
Is something rubbing?
OK, so what's the rub? How about a $112,415 price tag for starters? Porsche is notorious for optional equipment pricing matrixes, with a colored Porsche crest on the wheels' center caps costing an extra $185, for instance. The Offroad Tech Package we loved so much is another $4,290, and the 20-inch wheels/tires pictured here will cost $2,160 more. You get the point, and we can comfortably estimate that the total cost of the Cayenne Turbo S we drove to be $150,000.
Also, we noticed how sensitive the vehicle is to worn tires on the racetrack, where handling was greatly affected by variously new/old tires. Those aren't free, either. Finally, all of our sand-dune slinging was only possible by letting about half the air out of all four tires. Should you choose to replicate our foray, you'll need to have an air compressor handy before returning to civilization.
But then again
You've gotta love that there is a vehicle that can run competitive track laps and also go where only camels have gone before. It should be no surprise that Porsche builds the machine that can do that, while costing you half a fortune. Put a large enough engineering team behind a project and anything is possible.
Remember, Porsche is the company that made the 911 a crown jewel, a rear-engined car with the weight distribution of a lead-feathered arrow that flies like one built with perfect weight distribution. Why? Because the carmaker enjoys the heck out of solving riddles with ingenious engineering. Doing with ease what appears to be impossible is what the 2006 Porsche Cayenne Turbo S is all about. It'll humiliate a sports car or four-wheel-drive truck. So, how much should a magic carpet cost? Put it that way, and $112,000 starts to sound if not reasonable, then at least plausible.
NYCshopper is offline   Reply With Quote
Old 03-04-2006, 05:00 PM   #2
NYCshopper
Member#: 5126
Old 03-04-2006, 05:40 PM   #3
buddha511
Member#: 109123
so sexy.
I would never own an suv but I can still apreciate 400+ hp in any package
buddha511 is offline   Reply With Quote
Old 03-04-2006, 06:01 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
hmmm... 150K for a loaded one?????? Dunno about that....If there wasn't a V6 version to dilute the line, I'd bite.... But imagine if there was an ultra high performance STi for 70K???
jigga is offline   Reply With Quote
Old 03-04-2006, 06:05 PM   #5
JBLU24
Member#: 97503
def an "if i win the lottery suv"
id rather buy 3 Jeep SRT8's for that money
or 2 of them if hennesy throws some twin turbos on them
JBLU24 is offline   Reply With Quote
Old 03-04-2006, 06:17 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
is that Jeep srt8 even out yet??
Old 03-04-2006, 06:27 PM   #7
Ozzy
Member#: 8774
1998 Impreza RS
Id rather just buy a GT2 and a 98 outback wagon for my wife.
Turbo Cayennes are fast but suck to work on. Vw trim pieces and electronic control units hidden all over the place.
Ozzy is offline   Reply With Quote
Old 03-04-2006, 06:36 PM   #8
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Amen for freaking gay a$$ trim pieces. What was Volkswagen thinking? Make the easy twist-offs or something. The undersides are impossible to get apart to do anything on in a pit.
ScubaruImpreza05 is offline   Reply With Quote
Old 03-04-2006, 06:38 PM   #9
ScubaruImpreza05
Member#: 74041
SV650 For sale
Oh, and for the car, I've always wanted to do the female form of a porsche, I believe her name is Angelina Jolie. Not sure though.
Porsches are teh secks, I've always wanted a Poor-sha , so I am bias, price sux though.
Old 03-04-2006, 06:52 PM   #10
LastResort
Member#: 99289
Originally Posted by NYCshopper
I'm not sure that wheel has enough buttons on it...
With 150k, I'd buy a 911, and an H1 Alpha.
LastResort is offline   Reply With Quote
Old 03-05-2006, 11:19 PM   #11
BigElm
Always under your radar!
Member#: 1568
Yep!
BigElm is offline   Reply With Quote
Old 03-06-2006, 12:41 PM   #12
Subie FI
Member#: 17253
2014 BMW 328i Wagon
Alpine White
"520 horses, or about 1,000 camels" Funny line.
I love how they test it in Dubai. For $150k the oil sheiks are gonna be the primary market.
Subie FI is offline   Reply With Quote
Old 03-06-2006, 02:41 PM   #13
gumball
Member#: 1209
"sport-ute with the aesthetics of a dented potato"
gumball is offline   Reply With Quote
Old 03-08-2006, 05:06 PM   #14
kwilson36
Member#: 67449
03 VF22, TXS FMIC
EcuTek, Catless...:)
If you owned that.....
Do you think you'd ever....... have to work on it.
kwilson36 is offline   Reply With Quote
Old 03-12-2006, 09:17 PM   #15
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Love how they show that thing just ripping up in sand dunes. Like to see how many yuppies even geth theirs dirty. Well I guess everyone has to go through a puddle here and there . They make these SUVs with all these controls that would help them conquer offroad excursions so well and i bet not 1% of them sold are even taken off paved roads.
John__Gotti is offline   Reply With Quote
Old 03-12-2006, 09:24 PM   #16
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
If I was loaded - I'd have one in the garage.
Sadly, my bank account has never seen that much money at once.
Tkacik is offline   Reply With Quote
Old 03-23-2006, 01:57 PM   #17
AUTOwrXER
Member#: 5817
2005 STi
Anyone know if it's rated to tow, and if so how much? Just curious, as lots of the hod-rod trucks and SUVs aren't rated at all (the Dodge Ram SRT10, for example).
AUTOwrXER is offline   Reply With Quote
Old 03-23-2006, 02:01 PM   #18
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
It's hilarious that you have to step up to the Turbo S model to be quicker than a turbo Forester.
Of course, you can't get a dual-range transmission in a north american Forester (though they are made for other markets)...
Chromer is offline   Reply With Quote
Old 03-23-2006, 02:46 PM   #19
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Am I allowed to say that I think the dashboard looks like crap? I'd take a Tribeca interior over that any day of the week.
The rest of the vehicle, fine, good, amazing, whatever, but the shots of the dashboard just make it look, well, cheap!
CirrusWRX is offline   Reply With Quote
Old 03-23-2006, 03:16 PM   #20
themarxist
Member#: 104555
1996 VW Passat Wagon
TDi White
27.6 psi?!?!?!?!? That's what it says the maximum pressure generated by the turbos is. There's no way they're actually running that much boost is there? Seems like it'd be making 800hp or more at that boost level. Now all they need to do is take that motor and put it in a RWD coupe. Win. Then take one of those, swap in a pair of GT40s or summat and go to town. Bam, 1000hp.
themarxist is offline   Reply With Quote
Old 03-23-2006, 03:58 PM   #21
jmlmr2
Member#: 49330
03 WRX Wagon
Sonic Yellow
I think the Europeans rate boost in absolute PSI, so subtract 14.6 normal atmospheric pressure to get the "boost" pressure we're accustomed to reading - 13psi sound more realistic?
I think they are rated to tow ~ 9000 lbs too, though I have heard the transmissions have a hard time as the middleman between all that torque and the load that's being towed. When I had my Boxster there were always a couple of Cayenne's in the service bay for some mysterious electrical glitch, though in their defense, at that time the Cayenne had just come out within the past few months...don't know if they have solved any of those problems yet.
jmlmr2 is offline   Reply With Quote
Old 03-23-2006, 04:37 PM   #22
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
How much can a Forester XT tow?
Rapid_Roo is offline   Reply With Quote
Old 03-23-2006, 06:58 PM   #23
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
<shrug> Get an XT and a Ram 3500 dually diesel and have $75,000 left over for a Cayman S.
Old 03-23-2006, 07:29 PM   #24
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I just wanted to know what it could tow. I was wondering if it could tow a Caterham Super 7, or do I actually need to get a truck too.
Old 03-23-2006, 07:45 PM   #25
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
IIRC, 2000lbs for the manual, 2500lbs for the auto. I towed a 3500lb "microvan" (Dodge Colt AWD) for 600 miles on a dolly, through 2 mountain ranges, with no problems.
First Drive: 2008 Porsche Cayenne (Road & Track) NYCshopper Non-Subaru News & Rumors 1 03-27-2007 05:11 PM
First Drive: 2008 Porsche Cayenne (edmunds.com) NYCshopper Non-Subaru News & Rumors 7 02-10-2007 12:51 AM
First Drive: 2006 Kia Sedona (edmunds.com) NYCshopper Non-Subaru News & Rumors 4 02-14-2006 11:33 AM
First Drive: 2006 Subaru Impreza WRX and WRX STI (Edmunds.com) NYCshopper News & Rumors 44 09-08-2005 09:56 PM
Edmunds.com - First Drive: 2006 Subaru Forester NYCshopper News & Rumors 8 07-06-2005 11:11 PM
