Old 03-04-2006, 05:03 PM   #1
legacy2003
Member#: 38338
2003 Outback Sdn H6
Default is the valve cover gasket for jdm ver. 7 sti same as usdm sti?
hey guys,
i figured out that i have a rip in my passenger side valve cover gasket (the one that goes around the valve cover, not the little ones in the middle) on my jdm v7 sti motor that is causing oil to leak out from the motor and ignite upon hitting the exhaust manifold. needless to say, i need to fix this with a new valve cover gasket.
i'm hoping and praying that this gasket is the same as the usdm sti? and if it isn't does anyone know where i can get just that one gasket? i know ia performance sells the whole set for both heads, but i only need that one gasket and they want something like $85 or so for the set, and i doubt they would just give me one. is this something that could be ordered through the dealer (part #?)?
any help is appreciated! i need to get this fixed quick!
legacy2003 is offline   Reply With Quote
Old 03-05-2006, 02:33 PM   #2
legacy2003
Member#: 38338
2003 Outback Sdn H6
bump... anyone?
Old 03-19-2006, 03:34 AM   #3
greysave
Member#: 62395
2005 STI
Are you running the jdm cams?
greysave is offline   Reply With Quote
Old 07-05-2006, 02:50 PM   #4
EJ205rulezall
Member#: 21748
I'd like to know this as well
-Rick
EJ205rulezall is offline   Reply With Quote
Old 07-05-2006, 02:54 PM   #5
InfamousDX
Member#: 25413
NO THEY ARE NOT.
I had to order mine from Rallispec. $10 per gasket. And "apparently" you need the spark plug gaskets too ($5 each). I wasn't sold on that part but I got them anyway. Called them up, ordered.. right to my work door in about 1.5 weeks.
Old 07-11-2006, 09:50 PM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
thanks infamousdx... didn't see that anyone had replied to this thread till now . i fixed mine with rtv and it's been holding up just fine for about 5 months now. does rallispec have most of the gaskets we need for the v7/8 would you say? i remembered i had tried gruppe-s, gr8wheels, kingpin, and all the other main jdm importers in the country with no luck. do they order them from japan? that's not a bad turn-around time at all. i might stock up.
Old 07-12-2006, 09:52 AM   #7
InfamousDX
Member#: 25413
Rallispec orders from some dealer in japan, I believe, as mine aer genuine Subaru parts (downt o part numbers and boxes and pink labels)... and yes, it's great turnaround time.
Old 07-12-2006, 11:09 AM   #8
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
hmmm, now I know who I need to call for my timing belt cover
Capt Crunch is offline   Reply With Quote
Old 04-13-2013, 04:40 AM   #9
spencern
Member#: 328627
1994 impreza wagon
white
i have head gasket problems with the same motor, and am interested in your progress/procedure with this project! because i will be having to replace my gaskets in the very near future and am not entirely aware of which ones to get and/or where to get them.
spencern is offline   Reply With Quote
Old 04-13-2013, 04:51 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d000000000000000000000d
+1 on searching
-10 on bumping a 7yo thread
call rallispec and PM the guys in this thread if they are still active here
Timing Cover for JDM EJ207 Ver8 same as USDM STi? Kotir Subaru Conversions 7 03-24-2013 06:00 PM
JDM Legacy TGV's the same as USDM STi? BigJ04STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-05-2007 02:40 PM
Are JDM sti axles the same as USDM sti axles? Capt Crunch Transmission (AT/MT) & Driveline 0 06-25-2006 02:34 PM
wtb: passenger side valve cover gasket for jdm ver. 7 sti motor legacy2003 Private 'Wanted' Classifieds 1 03-05-2006 09:36 AM
Are the JDM STi axle boots the same as USDM STi? Capt Crunch Transmission (AT/MT) & Driveline 0 07-23-2004 08:23 AM
