Old 03-05-2006, 08:38 AM   #1
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Default aP question
i got my AP this week on wednesday. the shop i purchased from loaded a map right out the box, stage 2. is it recommended to go on Cobb's site and dl their map or is it the same map and dont even worry about the map..also, what is the difference between base map and real time maps?
Boxer112 is offline   Reply With Quote
Old 03-05-2006, 08:48 AM   #2
innova
Member#: 97472
2005 PDX STi
Aspen White [email protected] woot
I'd download the map from cobb's website because chances are that it is a newer version.
Make sure you're have the right setup to go stg2 though, with a turboback exhaust.
Load your basemap once, and then flash to as many real times as you want.
innova is offline   Reply With Quote
Old 03-05-2006, 08:49 AM   #3
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
but what is real time?
Old 03-05-2006, 08:49 AM   #4
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
im lost when it comes to that
Old 03-05-2006, 08:50 AM   #5
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
by the way my max boost is 14 psi. and i heard people boosting at 16 when they loaded their ap.. is mine out of date?
Old 03-05-2006, 10:43 AM   #6
innova
Member#: 97472
2005 PDX STi
Real time you can switch on the fly. It is what you put on top of the base map. You can only flash the base map 100 times or so but you can flash with a real time as many times as you want. Realtime maps are just a quick switch. Once you do the initial Cobb basemap (be stage1,2 etc..) you should only need to use realtime maps.
Give it a few days to reach max boost. Check it out in 4th and 5th gears also. They will boost much higher then the first few gears.
Old 03-05-2006, 02:08 PM   #7
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
How about going to Cobb's website and learning how to use it before you put it on your car??? NOt trying to be a jerk, but if you purchase something that will affect your car (an expensive investment) why wouldn't you learn how to use it first?
darkstarmoto is offline   Reply With Quote
Old 03-05-2006, 02:47 PM   #8
subeesteve25
Guest
Member#:
^^^^^^ What he said.
Old 03-05-2006, 02:53 PM   #9
-Kevlar-
Member#: 82378
yeah you need to learn and read a little more. but target boost is 15.7 +/- .5 psi. the newest version is 1.30.
-Kevlar- is offline   Reply With Quote
Old 03-06-2006, 12:59 AM   #10
ase05scooby
Member#: 103710
05 impreza wrx
red
Read all the info u can find on it before you install it if you have any doubts.
ase05scooby is offline   Reply With Quote
Old 03-06-2006, 09:25 AM   #11
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
i went to the website and it just was not hitting me.. thanks for the input though guys..
Old 08-21-2006, 09:29 AM   #12
q0Y0p
Member#: 35903
99 R & 05BugShield I
RBP & PSM
Default another Noob question
I just got the AP.
running stage 2 base map,
I want to use STG 2 LWG realtime map.
My question is after I switched to the real time map,
I can just unplug it, correct?
The only case that it stays plugin only when I want to read live boost
any helps are appreciated...
Thank you.
q0Y0p is offline   Reply With Quote
Old 08-22-2006, 12:59 AM   #13
-Kevlar-
Member#: 82378
Originally Posted by q0Y0p
I just got the AP.
Thank you.
you are correct....
AP- question Need help Married AP!! subadrifta06 AccessPort 13 12-19-2007 03:16 PM
AP Question... F3nom3ni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-08-2004 05:51 PM
STi AP questions -=Fox=- Engine Management & Tuning 0 11-03-2004 01:37 AM
AP question rallyme Engine Management & Tuning 1 10-07-2004 11:31 PM
More AP questions AchmedRodriguez Engine Management & Tuning 9 09-12-2004 09:13 AM
