Old 03-05-2006, 04:39 PM   #1
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
Default What percent on idle for an 800ccc.
i have my car tuned with ap... i had 565 pinks running 5% on idle or coming to a stop.. with the 800cc i can't run 5% becuase the hole is too big. i beiieve it's down to 1-2% now and my car sound and feels like it going to stall when coming to A stop. needs some help. this is my daily driver or do i just get smaller injectors.
gmanwrx is offline   Reply With Quote
Old 03-05-2006, 05:40 PM   #2
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I am running modded stk. [850cc] injectors w/ a Protuned A/P, and mine idles just like it did stock. That is w/ a 40T & Walbro.
BIG GUN is offline   Reply With Quote
Old 03-05-2006, 06:07 PM   #3
JRSCCivic98
Member#: 67080
How are you changing the fuel percentages? Do you have ST? Does it not have a place to put in your injector size? The overall corrections are the same across the band for the fuel if all you're changing is the injectors. All else fails... here's the equation for injector correction.
565/800=0.71 So, if the 565cc is at 100% then 800cc would be 71%. You basically need to run 29% less fuel across the board to make it run the same (if the injectors are the only thing changing).
JRSCCivic98 is offline   Reply With Quote
Old 03-05-2006, 06:56 PM   #4
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
FWIW, I had my wrx protuned with ap and my 800 injectors were scaled to 530. The car did run horrible and stall when not scaled, just as you described. But all good now.
kingtut12 is offline   Reply With Quote
Old 03-05-2006, 08:04 PM   #5
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
i run's fine till i come to a stop. i don't know if my idle is too low or to much fuel. then when i step on it hard it stalls then just takes off.. no smoke...
Old 03-05-2006, 10:34 PM   #6
JRSCCivic98
Member#: 67080
If all you did was change your injectors from 565 to 800 and no other changes (including to the tune) then your car is running 30% richer EVERYWHERE. I don't care how it runs or doesn't. That's the end result despite what world you think you live in. Scale the injectors and you're done. Simple as that. Then when you get to the point where you actually need the added fuel from the bigger injectors it will be there with a simple change. Work smart, not hard.
Looking for real-world advice on modifications for an OBS kattz General Community 1 09-02-2005 01:07 PM
what do i need for an ej25? Smoke Show Canada Region Forum 13 03-25-2004 07:28 PM
What can I use for an outdoor shelter for my car? whtlegacy Off-Topic 3 12-22-2003 10:21 PM
('93-'01) with birthday $$ between 2-250$, what to get..anything for an RS DangeRS Impreza Forum 11 08-20-2001 04:29 PM
deciding what font to use for an AWD sticker..help! Keirik General Forum Archive 5 06-26-2000 01:32 AM
Message Board Statistics All times are GMT -4. The time now is 12:30 AM.
