Old 03-05-2006, 06:15 PM   #1
Sleepysub
Member#: 94116
2000 Imp outback S
Green and tan
Default 200-250 DD build?
Alright here goes the thought of my build
some things to keep in mind
1. Im in school right now at VT so my buget is super small
2. It's my DD
3. no shop time
I have a 2000 imp outback sport. I would like to put stock WRX heads and run all stock turbo components with the top mount intercooler. I have heard that I might have to Replace my intake manifold and throttle body.
problems
will the heads bolt up?
will the turbo clear my cruise control unit?
will i have ECU problem?
I thought of this idea because that will give me a good end product with alot more room later to build bigger. I can also get all the parts for about a grand used of people upgrading or swaping.
What am i missing?
Mike
Sleepysub is offline   Reply With Quote
Old 03-05-2006, 07:21 PM   #2
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I'm not sure that putting WRX heads on your block will work with a stock ecu. The compression ratio etc might be different and would then need to be tuned for.
Capt Crunch is offline   Reply With Quote
Old 03-05-2006, 10:49 PM   #3
Sleepysub
Member#: 94116
2000 Imp outback S
Green and tan
ok what about a set of RS head so i can atleast get duel ports to move exhaust gas?
Old 03-05-2006, 11:17 PM   #4
Capt Crunch
Member#: 10852
hmmm, I'm not really sure... try asking in the Conversions forum or the Aftermarket Forced Induction forum.
Old 03-06-2006, 02:37 AM   #5
smahala1286
Member#: 93964
95 Impreza w/ej20g
you have a 2.2 liter right. I would suggest some phase one ej25 dohc heads, they will flow plenty enough for what you need, and they will lower your compression ratio. I would suggest a custom up-pipe and downpipe, rather then using the wrx manifold and up-pipe. It will most likely cost you less money. You will need engine managment that will control fuel and ignition. As for your goal of 200-250 that is an un-realistic goal for your n/a block.
P.S. this thread should be in the aftermarket forced induction forum
smahala1286 is offline   Reply With Quote
Renault could build hardcore version of new Megane Renaultsport 250 AVANTI R5 Non-Subaru News & Rumors 23 10-28-2009 03:15 PM
02 PSM WRX 10,250 worth parts invested in the build mpedigo Private Vehicle 'For Sale' Classifieds 7 03-04-2009 11:57 PM
My EJ205 is Dead.....Help Me Build a 400-450HP RELIABLE DD KenSekiguchi Built Motor Discussion 11 07-17-2008 01:49 PM
Bono: Lets spend 200 million euros and build a skyscraper Paraskass Off-Topic 18 10-18-2007 06:32 PM
best sub under 200, powered from jl 250/1 lettucemanatee Car Audio, Video & Security 20 01-09-2004 08:25 AM
