Old 08-18-2006, 04:56 PM   #51
slopemaster
Member#: 123413
2006 2.5i Sport Wago
Crystal Grey
thanks, I was hoping to do it without it, but I guess there's really no way.
slopemaster is offline   Reply With Quote
Old 08-18-2006, 05:12 PM   #52
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
It's really no biggie to pull the battery - 3 minutes does it. I also found that unhooking the ground wire that fastens to the fender helps move the wires out of the way. Another 30 seconds. I also wonder if the battery needs the removable side protection thing that is wrapped around it - it would make a little more space with it removed. I've also considered cutting out some of that wrap near the low beam area.
Alan is offline   Reply With Quote
Old 08-23-2006, 08:39 PM   #53
XWRATED
Member#: 111454
2003 WRX Sedan
WRB, 86' Buick GN 500 HP
I would assume they make H1 HIR bulbs but I cannot find any place that sells them. That ebay linky no worky. Anywhere else I can get them?
Scott
XWRATED is offline   Reply With Quote
Old 08-23-2006, 09:53 PM   #54
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Silver w/ JDM Roof Vent
Scott
They do not make HIR bulbs in the H1 base bulb. They only make them in the 9005 or 9006 bases. I have seen them for an H3 base but they cost around $75 each .
Yesitsdrew5310 is offline   Reply With Quote
Old 08-23-2006, 09:56 PM   #55
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Oh and www.rallylights.com sells the HIR bulbs as well.
Old 09-22-2006, 04:22 PM   #56
boostpower
Member#: 116550
2006 WRX
Crystal Gray Metallic
Man, and I just bought the SilverStars Guess that's what I get for not reading first! Oh well, it's just for my H3's and I got one of um free, so if they only last a little bit, no biggie, I'll do it right next time!
boostpower is offline   Reply With Quote
Old 09-26-2006, 12:03 AM   #57
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
Agreed, pulling it's the easy part. Maybe I'm just spastic but I spend forever and a day fighting to simultaneously hook the tie-down bolts under the cut-outs in the battery pan and screw down the nuts to the point where the J-hook won't pop out of the cut-out.
Captain Ned is offline   Reply With Quote
Old 09-28-2006, 12:22 AM   #58
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
I ordered mine over the weekend and they came in today. I ordered the 9005 and 9006(because I'm a freaking idiot). Those 9006's aren't going to fit in my wagon. Got the 9005's in and they look good. Really bright. Now I just need some H1 HIR's and sell off my 9006's.
dauss is offline   Reply With Quote
Old 09-28-2006, 12:37 AM   #59
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Yeah its too bad they don't make the HIR bulbs in the H1 base. If they did, I would buy them right away.
Old 09-28-2006, 12:29 PM   #60
legacymaximus
Member#: 98451
94 legacy TW
One thing about the LEDs also is that they don't produce that much heat which is fine for the summer, but if you live in snowy areas, and you use them as brake lights, you are missing the heat that is normally produced by normal bulbs and snow can build up on the outside of the light. Try passing a Semi with LED brake and marker lights at night in a blizzard, it sucks!
-max
legacymaximus is offline   Reply With Quote
Old 09-28-2006, 02:18 PM   #61
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Actually, it's the opposite.
Since it's running cooler, the snow is less prone to accumulate on those lamps. This is because the snow doesn't melt as easily. So there isn't any water on the lamps for the snow to adhere and freeze to.
Pinochle is offline   Reply With Quote
Old 10-13-2006, 09:38 PM   #62
OneManArmy
Member#: 36154
2004 WRX Wagon
any recommendations on replacements for 04/05 jdm fog lights.
I have the ion ones.
OneManArmy is offline   Reply With Quote
Old 10-14-2006, 01:57 AM   #63
REVNU
Member#: 82147
2005 WRX Sedan
I have the PIAA Ion Yellow Crystal bulbs in my fogs. They are brighter than the OEM bulbs and I've had them in for over a year with no problems. I would never recommend PIAA's for driving lights though.
~ REVNU
REVNU is offline   Reply With Quote
Old 10-29-2006, 11:23 PM   #64
whateverwrx
Member#: 99653
05 WRX
ok i went to rallylights.com and and was wondering if the Xenon +50s were the same as discussed,also i couldnt find the mentioned yellow fog lights-how do these compare? one more question is the bulb life...the HIRs look a bit low.
heres what i found. should i buy em?
from rallylights.com
HL78149 Replacement Bulb, H1 12V, 55W, Xenon +50, Premium, each $11.76
Xenon +50 None 55W 1780 350 3250 1 CP9011 9011-HIR1 Bulb, 12V, 65W, Toshiba, each $29.75
HL78135Y Replacement H3 Bulb, 12V, 55W, Yellow Star, each $5.82
Bulb Type Coating Watts Lumens Life Color K
(HIR) IR 65W 2300 235 3400
no info on yellow stars
whateverwrx is offline   Reply With Quote
Old 11-07-2006, 10:16 AM   #65
ninethreeeleven
Member#: 99777
Could anyone recommend be a light housing that will fit the in Bugeye fog light housing (5"? 6"?) but will accept a HID bulb (H3 or H4, probably H3).
I know this seems ludicrous but I hunt and have to get up the mountain full of snow and want the light as low as possible (fogs) but as bright as possible on the road (under the falling snow).
I found a great deal on H3 and H4 HID kits (used) and I would really like to do this, but only if it will actually help.
ninethreeeleven is offline   Reply With Quote
Old 11-08-2006, 01:52 PM   #66
jeffs04wagon
Member#: 130904
2004 impreza wrx
WR Blue
Default yellow
i liked the write up, it explained alot, i have some yellow h1 and h3 lights in my wrx now but they are not yellow enough, the brand is Euro Dezigns, i want my lights to be insanely yellow, does anyone know of a good brand to accomplish this yellow look?
jeffs04wagon is offline   Reply With Quote
Old 11-27-2006, 03:58 PM   #67
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Hey,
I need new high beam bulbs for my EDM's, should I look into HIRs or are they out of the question now?
Thanks,
Mike
TheShadowWRX is offline   Reply With Quote
Old 11-27-2006, 09:10 PM   #68
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Originally Posted by TheShadowWRX View Post
Hey,
Thanks,
Mike
It depends what bulb that light takes. If it is the 9005 or 9006 bulb, then YES by all means get the HIR bulbs, they are redicilously bright. You will like them cause they light up cop cars off in the distance.
Old 11-27-2006, 09:11 PM   #69
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
You could put some yellow rockblocker over your lights, that would make it really "insanely yellow." (yes it will dim the light a tit bit, not too much to notice though)
Old 12-04-2006, 06:02 PM   #70
ScandiaWRX
Member#: 109193
Thanks for a great lighting thread. I upgraded my stock bulbs this weekend in my 06 wagon to H3 - 55W Tungsram Gold for the fogs. Osram H7 rallye+65 for the low beams and Toshiba 9011 HIR bulbs for the high beams.
I can't believe how much better I can see road at night. We also adjusted the stock fogs upwards so they hit the road 20 feet from the car, they were uselessly hitting the road 5 feet in front (only helpful for seeing what you just ran over but too late to react), and aimed the low beams about 2" higher. If I start getting irate flashing from on coming cars I'll drop them back down a bit, but no trouble yet.
If you do any off road or rural driving, these bulb upgrades are great!
ScandiaWRX is offline   Reply With Quote
Old 12-05-2006, 02:53 AM   #71
Gethin
Member#: 2998
Anyone use these bulbs on a bugeye ? from rallylights.com
HL83700 Replacement 9007/HB5 Bulb, 12V, 60/55W Xenon, Hella High Performance, per Pair
Gethin is offline   Reply With Quote
Old 12-06-2006, 08:32 PM   #72
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Good Thread!
My Stock left front headlight went out Along with my Left Front Fog light which has been out for like 7 months.
Where can I get the Philips VisionPlus? Since those seem to have the brightest output of light.
Sometimes with the OEM bulbs I have to check to make sure I have my lights on.
SubaruImpreza_power is offline   Reply With Quote
Old 12-11-2006, 01:21 AM   #73
REVNU
Member#: 82147
2005 WRX Sedan
^^^ Try RallyLights.com or SUVLights.com
~ REVNU
Old 12-12-2006, 12:37 PM   #74
rugbywrx03
Member#: 57703
08 STi
anyone tried the new ultra silverstars? i just swapped them in for the old silverstars and i have to say there is a noticeable difference/improvement.
rugbywrx03 is offline   Reply With Quote
Old 01-02-2007, 03:15 PM   #75
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
My new toys
The Hella boxes are 4 H3 55W Yellowstars (2 for my fogs and 2 for the GF's GLi)
The Osram boxes are the H7 65W H9 Burner from www.rallylights.com 2100 lumens or something like that.
I will post back after I swap them.
Cheers
Sweep
MFR Sweep is offline   Reply With Quote
The 'Everything You Ever Wanted to Know About Smog' Thread WagonMonster Southern California Impreza Club Forum -- SCIC 667 06-27-2016 02:18 AM
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
All you've ever wanted to know about farting TheRex Off-Topic 5 02-01-2005 03:48 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
