Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-29-2006, 08:53 PM   #1
H-I-M
Member#: 90679
03 WRX
WHITE
Default boost help
i just put my utec on updated it to the newest version, downloaded the maps and the 1-3 perameter. set my selecter switch to 3 and my boost level will not go over 10 pounds. i had some one that hooked one up before and worked at a tuner shop help. i had a manual boost contoler on it befor and was running on 17 pounds so i know the turbo works. we took it off and put hte one provided with it on. so please help i'm going crazy trying to get it to work. thanks.
H-I-M is offline   Reply With Quote
Old 07-29-2006, 09:09 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
"brass and restrictor"
hippy is offline   Reply With Quote
Old 07-29-2006, 09:15 PM   #3
H-I-M
Member#: 90679
03 WRX
WHITE
what does that mean?
Old 07-29-2006, 10:32 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
it means do a search for......
Old 07-30-2006, 09:28 AM   #5
59wrx
Member#: 115099
2005 Evo VIII MR
Graphite Grey
Default New Toy
What mods do you have? Some, none?
Did you try running off of Map #0/8, the stock mode, and see what you get?
Did you "hand poke" in your parameters or try downloading them? TurboXS says to input the upgrade parameters manually, not downlod them.
Are you using the TurboXS ABC or are you running an aftermarket MBC? Did you check your lines if you used either?
So many questions for information that you should've put in your original post.
59wrx is offline   Reply With Quote
Old 07-30-2006, 11:48 AM   #6
hippy
Member#: 36528
2002 Impreza Wrx
If he was using the mbc, he wouldn't have boost problems. I'd bet on the problem being the brass restrictor either being in the wrong spot or missing.
peace
Old 07-30-2006, 12:49 PM   #7
TurbojonLS
Member#: 38772
2 Cars, No Bling
Or didn't adjust the boost map at all...
TurbojonLS is offline   Reply With Quote
Old 07-30-2006, 12:52 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
.....or open the abc....(true). I just assumed that since he had an mbc on b4, that he chucked the brass restrictor without knowing that he did. Either that, or when he hooked the factory boost lines back upto the turbo, he put em on backwards.
peace
Old 07-30-2006, 09:45 PM   #9
H-I-M
Member#: 90679
03 WRX
WHITE
it has the boost controler that came with the utec, i have a blitz nur exhaust , rsr down pipe and up pipe , hks blow off valve ,arc air box. i will look to see if the brass restrictor is missing if it is which line does it need to go too? and also i down loaded the maps and peramaters from turbo xs and didn't adjust any thing. thank you every one for your help.
Old 07-30-2006, 09:47 PM   #10
hippy
Member#: 36528
2002 Impreza Wrx
It needs to go in the small tube between the t fitting and the turbo(no one the other side between the fitting and the wastegate).
peace
Boost or No Boost Help Needed SteveTC Pre-2002 Factory Turbo Powertrain 7 09-03-2009 08:00 PM
Stock 04 wrx over boosts/under boosts HELP! KnightRiderWRX Newbies & FAQs 5 07-17-2009 11:41 AM
Boost spiking/half boost Help please! Hah72215 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-22-2006 12:36 AM
Boost Controller failure=can't hold boost, help! SoBaLo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-30-2002 01:11 AM
Boost Monkey + MBC cranked down = too much boost, help! Mephiska Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 06-24-2002 03:17 PM
