Old 03-06-2006, 06:59 AM   #1
blackrod punishment
Member#: 99757
2015 sti
white
Default not hitting peak boost with vf 34
ive got an 02 wrx and i just put in a vf34 and sti pinks, the cars faster but not as fast as it should be. ive got turboback exhaust cobb access port the pinks and everything i need to run the turbo and im only boosting 12 to 14 pounds around 6000 rpm. it also takes till about 5000 rpm to really start spooling. any ideas id apprieciate it thanks
blackrod punishment is offline   Reply With Quote
Old 03-06-2006, 07:10 AM   #2
-Kevlar-
Member#: 82378
-Kevlar- is offline   Reply With Quote
Old 03-06-2006, 07:28 AM   #3
InvertedB
Member#: 82455
Chapter/Region: HIIC
2006 Saab 9-3 2.0T
SportCombi
When you say you have everything necessary to run the VF34, did you include an upgraded fuel pump?
InvertedB is offline   Reply With Quote
Old 03-06-2006, 07:34 AM   #4
-Kevlar-
Member#: 82378
although good to do, i dont think cobb requires it.
Old 03-06-2006, 07:40 AM   #5
InvertedB
Member#: 82455
2006 Saab 9-3 2.0T
SportCombi
I think you need it to run the STi pinks with the bigger turbo on a WRX else the turbo sucks the fuel rails dry when it tries to reach full boost and therefore never makes it to full boost.
Old 03-06-2006, 10:11 AM   #6
g35sedamn
Member#: 87515
03 aspen wrx wagon
if you didn't upgrade the fuel pump then that would be the first thing i would do. its only like 80 bucks for the insurance alone of not running lean or not making the fuel rail pressure to get the 550 ish cc's of fuel out that cobb is tunned for. my other guess is you might need to pull the restrictor out of the wastegate line. my friend had that problem and harman motive removed the restrictor in the wastegate line.
g35sedamn is offline   Reply With Quote
Old 03-06-2006, 10:18 AM   #7
Balr14
Member#: 84809
2005 Forester XT
Have you had it custom tuned?
Balr14 is offline   Reply With Quote
Old 03-06-2006, 11:14 AM   #8
rallyme
Member#: 70803
2004 WRX PMS
DB18G w/ METH GOODNESS
i had the EXACT same problem... i did the helper spring mod. Do a search for it, if you cant find anything just let me know. What you really need though is a protune. Cobb was no help at solving this problem
chris
rallyme is offline   Reply With Quote
Old 03-06-2006, 12:08 PM   #9
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
I had the same thing happen. You do need a FP to run that map. I used a helper spring also in the meantime to achieve target boost. You can find these at Home Depot, hobby spring. Just rig it on your wastegate so it creates more tension in keeping it closed.
I'd be willing to bet the problem is with your map though. Once I loaded a protuned map I no longer needed the spring, and was getting on boost much faster and hitting all targets.
MF-DIF is offline   Reply With Quote
Old 03-07-2006, 09:45 AM   #10
rallyme
Member#: 70803
2004 WRX PMS
quick question.......just wondering MF-DIF and blackrod punishment....are yall using a aftermarket bov?
HELP turbo sounds weird and not hitting peak boost Adrenalinecrisis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-12-2010 05:25 PM
Not hitting peak boost with Accessport V2 and extreme taper. BrianMR2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-04-2010 11:00 PM
Not Hitting Proper Boost with VF39, Cobb Protune - Recommend a Boost Solenoid? whtlegacy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 06-06-2009 03:38 PM
Not Hitting Target Boost with Uppipe Install dan1587wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-11-2008 10:54 PM
Not hitting peak boost :( eurospek AccessPort 1 08-30-2007 07:38 PM
