Old 03-06-2006, 11:14 AM   #1
AaronWRX
Member#: 7194
2011 997.2 Turbo
OMGHi2U Goodbye forum 80. Forum 141 is my new home.
I've had a good time in forum 80 over the past few years. I was here for the unichip "Stage" packages and got one of the first issued WRX utecs. The STI Utec was my first "mod" to my new car.
I had no experience with engine management or fuel injection systems before I got my WRX. I barely knew how it all worked when I dove head first into the wealth of knowledge nasioc provided. I've spent countless hours soaking up every bit if information I could. I've made my share of mistakes but using a slow and cautious approach, I never blew anything up!
My advice to anyone who wants to start tinkering with the tune of their car is 1.) Data is key. Spend the money on the gauges to get the data you need. And 2.) Just like anything worth doing, you need to put in the time.
The highlight for me was when I took my self tuned STI +TBE to a local dyno day and put down 300/whp and 300ft/lbs which was spot on to some of the professionally tuned STIs on the same dyno.
Goodbye forum 80. You've been good to me.
--aaonwrx.
p.s. Here is a dump of my utec folder and subdirectories.
06_05_current_map.txt
12_08_06_sz55_fmic_4thgear_1.txt
12_08_06_sz55_fmic_4thgear_2.txt
12_08_06_sz55_fmic_4thgear_3.txt
12_08_06_sz55_fmic_4thgear_4.txt
12_08_06_sz55_fmic_4thgear_47deg_6.txt
12_08_06_sz55_fmic_4thgear_47deg_7.txt
12_08_06_sz55_fmic_4thgear_5.txt
12_15_06_sz55_fmic_4thgear_41deg_1.txt
12_15_06_sz55_fmic_4thgear_41deg_2.txt
12_15_06_sz55_fmic_4thgear_43deg_3.txt
aaron-20g-93-pe850.txt
aaron-20g-93-pe850_NOTES.txt
aaron-20g-93-pe850_version2.txt
afr_map.txt
cb_v1.a.txt
cb_v1.b.txt
ChadB_map.txt
gt35r_uteclog.txt
knocktest.txt
log1.txt
MAF_HP.txt
sz12me.txt
sz12_new.txt
sz5510me.txt
sz55me9.txt
sz55_13_me.txt
sz55_14_me.txt
sz55_15_me.txt
sz55_16_current.txt
sz55_16_me.txt
sz55_17_me.txt
sz55_3.txt
sz55_4.txt
sz55_4thgear.txt
sz55_5.txt
sz55_6.txt
sz55_current_map.txt
sz55_me_7.txt.txt
sz55_me_8.txt.txt
sz55_me_8_.txt
07_09_78degrees_lots of driving_14txt
07_09_78degrees_run_10.txt
07_09_78degrees_run_11.txt
07_09_78degrees_run_12.txt
07_09_78degrees_run_13.txt
07_09_78degrees_run_8.txt
07_09_78degrees_run_9a.txt
07_09_78degrees_run_9_notps.txt
07_09_80degrees_run_1.txt
07_09_80degrees_run_2.txt
07_09_80degrees_run_3.txt
07_09_85degrees_run_4.txt
07_09_85degrees_run_5.txt
07_09_85degrees_run_6.txt
07_09_85degrees_run_7_badrun.txt
08_09_76degrees_lots of driving_1.txt
04_01_60_cbv1_drivehome.txt
04_01_60_cbv1_run1.txt
04_01_60_cbv1_run2.txt
04_04_67_cbv1_drivehome.txt
04_04_67_cbv1_drivehome2.txt
04_04_stripdown.txt
04_05_75_stg2_air_space_drive_home4.txt
04_05_75_stg2_air_space_pull_1.txt
04_05_75_stg2_air_space_pull_2.txt
04_05_75_stg2_air_space_pull_3.txt
04_06_81_stg2_rename_3rd_gear_church_1.txt
04_14_63_drivehome_rockville.txt
04_15_53_air_and_space_run1.txt
04_15_s2_postrun1.txt
04_15_s2_run0_start.txt
04_16_51_air_and_space_level_ground_run3.txt
04_29_59_as_runt1.txt
05_13_66_a_s_run_1.txt
05_13_66_a_s_run_2.txt
06_01_74_run1.txt
06_07_logger_3_boost_test1.txt
06_07_logger_3_boost_test_2_gain_55_txt.TXT
06_07_logger_3_drivehome.txt
10_09_60_hard_run_home_run5.txt
10_09_60_rt28_run1.txt
10_09_60_rt28_run2.txt
10_09_60_rt28_run3.txt
10_09_60_rt28_run4.txt
11-29-2005_drive_to_work_with_new_turbo.txt
11-29-2005_drive_to_work_with_new_turbo_differnt_MAP.txt
11-30-2005_sz55_3rd_4th_pulls_38_noBCS.txt
11-30-2005_sz55_3rd_4th_pulls_38_noBCS_2.txt
11-30-2005_sz55_3rd_4th_pulls_46degrees.txt
11-30-2005_sz55_3rd_4th_pulls_46degrees_set3_.txt
11-30-2005_sz55_3rd_4th_pulls_46degrees_set4_.txt
11-30-2005_sz55_3rd_4th_pulls_46degrees_set5_.txt
12-12--2005_sz55_4th__5th_pulls_33_noBCS_2.txt
12_11_2005_4th_gear_no_BCS.txt
56_wbworking.txt
56_wbworkingA.txt
57_wbworking._h2work.txt
afternoon_2_23_05_47degrees.txt
chadB2_sun_60f.txt
chadB_sun_60f.txt
morning_02_12_sat_ashburn_40deg.txt
morning_2_02_12_sat_ashburn_40deg.txt
morning_2_09_49.txt
short_runs1_2_23_05_47degrees.txt
short_runs2_2_23_05_47degrees.txt
short_runs3_normal_driving_2_23_05_47degrees.txt
short_runs_2_23_05_47degrees.txt
stage2_stockmuffler_1.txt
stage2_stockmuffler_2.txt
stage2_stockmuffler_3.txt
ReadMe.txt
sz55_17.txt
Tables.csv.txt
UTI-ME ReadME.txt
Info.txt
Knock-2-1-2006-1'37'38.txt
Knock-2-1-2006-1'47'28.txt
KnockReport-2-1-2006-1'37'38.txt
Pull-2-1-2006-1'24'21.txt
Pull-2-1-2006-1'25'26.txt
Pull-2-1-2006-1'25'49.txt
Pull-2-1-2006-1'37'47.txt
Pull-2-1-2006-1'47'38.txt
Pull-2-1-2006-1'58'48.txt
Pull-2-1-2006-2'02'48.txt
Pull-2-1-2006-2'03'13.txt
Pull-2-1-2006-2'03'42.txt
Pull-2-1-2006-2'04'17.txt
PullReport-2-1-2006-1'16'16.txt
PullReport-2-2-2006-4'22'06.txt
AaronWRX is offline   Reply With Quote
My new home away from home. (local bar) Stealthbmbr Off-Topic 20 11-30-2009 02:00 PM
Moving to Israel sep 1.. some pics of my new home ODiz413 Political Playground 111 08-25-2007 11:41 AM
I close on my new home today wolf8314 Off-Topic 39 02-17-2006 11:46 PM
My new home MeddlingKids Off-Topic 8 07-04-2005 01:28 PM
my new home Tim Quinn Vancouver Impreza Club Forum -- VIC 3 07-02-2004 06:25 PM
