Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 03-06-2006, 12:17 PM   #1
plus plus plus
Member#: 102013
Default Fuel Trim Experiences....w/ stock modded injectros
Care to Share......specifically fuel trim calibrations?
plus plus plus is offline   Reply With Quote
Old 03-06-2006, 02:40 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
I can tell you it will vary. The mod'd Perrins will flow test from 780-820 cc/min or around 5% (all tested at RC engineering). That's around 0.5 AFR units when fueling full boost at the same PWM value. My two sets (sets of 4 injectors) tested very evenly between sets: 0.1% difference, but their average flow rates were set 1=790, and set 2=810. Hence, I don't recommend mixing sets together.
You have to state which "stock modified" injectors you speak of to get more help. STI side feeds or WRX top feeds?
Old 03-06-2006, 04:41 PM   #3
plus plus plus
Member#: 102013
Wrx Top Feed
stock fuel trim problem.. MattP.18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-12-2008 02:29 PM
Circumsized Stock Injector Fueling - Rock Steady Idle - Perfect Fuel Trims - FREE map MRF582 Engine Management & Tuning 88 10-02-2007 06:42 PM
Stock STI Idle Fuel Trims LTFT & STFT jvcjbl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-10-2007 06:58 PM
Air Fuel Learning (Long Term Fuel Trim?) Jeramie Engine Management & Tuning 9 03-28-2006 08:34 AM
UTEC - relationship between pre-crossover fuel control and ST/LT fuel trims gpatmac Engine Management & Tuning 20 02-27-2004 01:21 PM
