Old 11-27-2000, 02:05 PM   #1
richeich
Member#: 1353
2001 Impreza 2.5RS
Question 100W Fog Lamps?
Is anybody running higher wattage lamps in their GT foglights? I saw some H3-100W (instead of stock 55W) Sylvania lamps at Pep Boys the other day and thought it might be interesting to give them a shot. I don't want to melt or discolor anything, though. Any thoughts or experience would be appreciated.
Rich
richeich is offline   Reply With Quote
Old 11-27-2000, 05:49 PM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Post
Here is a good site with a lot of lighting info.
http://lighting.mbz.org/
specifically here:
http://lighting.mbz.org/faq/#overwattage
Peaty is offline   Reply With Quote
Old 11-27-2000, 06:12 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Okay, bad idea. Thanks Peaty!
How about some of those in some Hella 500's? Are those sturdy enough to handle that?
Rich
Old 11-27-2000, 07:50 PM   #4
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Post
I put a set of 4060 PIAA's on the wife's Outback. You'd be surprised what a difference a quality design will do for lighting. I'm not sure what will fit in the GT though. Hers are like 6.5 or so round. They are head and shoulders above the OEM Blazer lamps that were there. If you go higher wattage you just have to put in a relay and new wiring to handle the extra current. There are kits available for that. Competition Limited has them I think. I can't find the URL right now though.
Old 11-27-2000, 10:26 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Talking
Forget my previous question! I actually already had a set of Hella 500's. I had mounted the lights Sunday night, but didn't run the wiring until tonight. Anyway, all I can say is WOW! Them babies don't need any more wattage. I bought the driving lights and kept my factory fogs in place. I can get into some dark areas here in Oklahoma, and I wanted to improve the distance vision at night. They are a fantastic set of lights. That may be the best $70 I've spent!
Thanks for you response, Peaty. I appreciate it.
Rich
Old 11-28-2000, 01:47 PM   #6
Mx5racer
Member#: 2629
Post
Nice web page on lights.
I have to respectfully disagree with some of the points though.
I have used overwattage bulbs in my cars for over 15 years with no problems. As an engineer in the automotive field, I find it very hard to believe there is no margin of safty in the electrical system. And hey, there are fuses. My bulbs are usually 80/100 Watt.
There are potential problems though. My applications have been using Hella or Cibie lights that were designed for these bulbs. These bulbs will produce more heat, and will likely damage plastic housings found on cars like my subaru.
So, I agree this is a potential problem, I believe it has more to do with the heat the bulb produces in a reflector not designed for the heat rather than the electrical system.
I have had problems with housings not designed for brighter bulbs (i.e. fog lights) but not with a proper Cibie/Hella reflector.
Just my two cents worth. I certainly would like to hear of someone who had an electrical problem with higher wattage bulbs.
Mx5racer is offline   Reply With Quote
Old 11-28-2000, 01:48 PM   #7
Mx5racer
Member#: 2629
Post
To answer the original question, I can just about guarantee your stock plastic fog lamps will not take the heat of a 100 watt bulb.
Old 11-28-2000, 03:59 PM   #8
gumball
Member#: 1209
Talking
hey MX5, I agree the stock wiring is probably ok in the headlights for a little over-wattage- the circuit is set-up w/ 2 15 Amp fuses (15 Amps is way more than 100 Watts for 12 Volts, and most bulbs are designed for 13 Volts) and 2 15 Amp relays, one for each bulb.
However the fog lamp wiring is pretty wimpy, w/ 1 15 Amp fuse and 1 15 Amp relay for both lamps, so even at 110 Watts (2X55) there's not a big margin built in.
gumball is offline   Reply With Quote
Old 11-28-2000, 05:49 PM   #9
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Yeah, actually after removing the fog lamps and taking a look around, it's pretty obvious that 100W lamps in there would put the hurt on all that plastic.
No sweat. I'm so pleased with the Hella 500 driving lights that I'll probably put some Hella fog lights in place of the stock fog lights in the future.
Rich
Old 11-28-2000, 06:42 PM   #10
GG
Member#: 1062
Thumbs up
See FOSMO LAMPS at http://www.fosmo.com, great selection & prices on bulbs
GG is offline   Reply With Quote
Old 11-30-2000, 01:01 PM   #11
Mx5racer
Member#: 2629
Post
Thanks, that is a good point.
FYI, when I overwatted some fog lights (in a different car), the end result is that they were no longer weather proof. They got water in them, and this of course did not go well with the Halogen bulb. Had to replace both lights.
100w Fogs? sorrowfulkiller Electrical & Lighting 17 12-06-2008 08:50 PM
Complete set of OEM lamps WRX 2005 - High and low beans plus fog lamps Grande Private 'For Sale' Classifieds 21 06-16-2005 09:02 PM
100w fog lamp bulbs vs. 55w. stock? DJ Catchem Electrical & Lighting 14 05-15-2004 11:08 PM
fog lamp covers for 99-01 RS .. or fog lamps! Rebellion Private 'Wanted' Classifieds 6 11-20-2003 01:30 AM
