#1 |
Member#: 30691
South East
Vehicle:2013 FRS RED |
I have an 04 STi Utec that I bought used.
Is there any way to reset the utec back to the original settings? I'm not sure what what all was changed on it befor I got it and would like to start fresh.
#2 |
Member#: 100570
Reflashing the UTEC will restore it back to its factory settings and erase all maps.
See the TurboXS web site for the latest software. regards Pete |
#3 |
Member#: 69434
Vehicle:2002 Impreza WRX Blue |
Does the UTEC hold maps on a stock ECU reset? I.E. you disconnect the battery to change belts, or bolt on a new intercooler, this typically reset the stock ECU, but I've always wondered, does this do anything to the Utec?
#4 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
Yes it keeps it. The UTEC has non volatile memory meaning that you can disconnect the car battery and it won't erase the maps or parameters. However, you will loose the learning that your stock ECU has done (eg. IAM will be reset).
| Thread Tools | |
| Display Modes | |
| can you reset factory ecu to stock after factory ecu updates | SHAG SCOOB | Engine Management & Tuning | 6 | 11-29-2009 02:55 AM |
| Can you reset your ECU with ScanGauge2 without codes? | elitescouter | Newbies & FAQs | 5 | 06-07-2009 01:57 AM |
| Can you reset profile passwords in XP? | shinsain | Off-Topic | 17 | 03-29-2007 02:44 PM |
| How do you reset Utec? | calib17a | Engine Management & Tuning | 2 | 10-23-2005 07:38 PM |
