Old 03-06-2006, 06:27 PM   #1
ktmbass85
Member#: 99793
11 STI
Default help with 2.5 sti block breather holes plugged?
i am doing a wrx hybrid engine swap..wrx heads/sti shortblock. someone told me i need to plug 2 breather holes on the sti short block. which holes? "pics" and how do i plug them?
ktmbass85 is offline   Reply With Quote
Old 03-06-2006, 08:35 PM   #2
gpatmac
Member#: 18446
2002 WRX wagon
psm
I'm not going to tell you what you should or shouldn't do like I'm an expert, but generally what I've seen is that folks cap the breather in the center of the block but still utilize the other breather for proper crankcase ventilation. As a matter of fact, I don't think it'd be very healthy to cap both of them.
In the pic, the arrow in the center is the one which folks cap and the arrow on the right is where you reuse your WRX or STi "Y". The bottom of the Y goes to the block, one of the arms of the Y goes to your PCV behind your intake manifold, and the other arm routes back into your turbo inlet pipe.
gpatmac is offline   Reply With Quote
Old 03-06-2006, 08:51 PM   #3
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Very good pic man! What would be used to plug the breather line?
Crazykev is offline   Reply With Quote
Old 03-06-2006, 09:00 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Definitely do not cap them both.
And I don't recommend capping only one of them.
They're there for a reason.
"T" them together if you have to.
jblaine is offline   Reply With Quote
Old 03-06-2006, 10:18 PM   #5
gpatmac
Member#: 18446
2002 WRX wagon
psm
When I initially capped it, I just used a rubber hose-type material which was closed on one end, and then I clamped it. That was the advice of one of the well-known and respected vendors on here. However, he never really explained why.
Right or wrong, I now have mine T'd like Jeff is talking about and running to a catchcan (along with the breathers on my heads.) If you look around this website, you'll see some really good ideas of how to manage your crankcase ventilation.
Old 03-06-2006, 10:56 PM   #6
moorebl
Member#: 59238
i love the looks of a fresh 2.5. t them off
moorebl is offline   Reply With Quote
Old 03-06-2006, 11:15 PM   #7
TexRex2002
Member#: 36303
06 Evo IX
the one in the middle is an air intake for the block. put a hose on it with a little pvc filter. make sure the filter is 6" or so above the top of the block with no "low spots" in the hose where oil can accumulate.
TexRex2002 is offline   Reply With Quote
Old 03-07-2006, 04:37 PM   #8
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Huh, is it OK to just T them together?
Early EJ20G heads with 2.5 STI Block? sniper512 Pre-2002 Factory Turbo Powertrain 35 02-10-2013 03:23 PM
WRX with 2.5 Sti Block 293whp 13.5k! awdvf22 Private Vehicle 'For Sale' Classifieds 5 03-21-2007 03:19 PM
WRX with 2.5 Sti Block 293whp awdvf22 Private Vehicle 'For Sale' Classifieds 4 03-17-2007 05:12 PM
USDM 2.5 STi block with CP Pistons Rizzo314 Private 'For Sale' Classifieds 1 07-27-2006 08:50 AM
2.5 sti block with 2.0 regular wrx heads serious Normally Aspirated with bolt-on Forced Induction Powertrain 21 08-03-2003 12:36 PM
