Old 03-06-2006, 11:17 PM   #1
djwhetzel
Member#: 109020
2015 WRX STi Limited
WR Blue
Default 1998 RS with EJ20G swap and Link ECM fuel gauge not working
I have searched for a long time looking for any information on this and found nothing. I have a 1998 RS with an EJ20G and a Link ECM. Everything seems to be fine other than the fact that my fuel gauge doesn't work. Does anyone know what I need to do to get it working? BTW the Link is a stand alone unit. Thanks for any help.
djwhetzel is offline   Reply With Quote
Old 03-06-2006, 11:41 PM   #2
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
not sure how it is on a 98, but w/ my 93 the sender unit is connected straight to the cluster. I had a problem w/ mine, turned out the sending unit was bad. Might just want to try and ohm test on it, make sure it's working, then check the wires that goto your cluster. Hopefully you have a wire diagram that'll show you how the circuit works
XENONSVX is offline   Reply With Quote
Old 03-07-2006, 12:06 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
shouldnt have anything to do w/ the link iirc
make sure the sender has power and a signal, and that the fuel pump level sender uses the same voltage as the car needs
Old 03-07-2006, 12:55 AM   #4
djwhetzel
Member#: 109020
WR Blue
Thanks for the quick replies. Before I changed the ECU the fuel gauge was working so I'm pretty sure itís good. My wiring diagram does show a wire for the fuel level sensor. It is pin number 27 on the stock ECU wiring harness and it says that it should have 0.12 - 4.75 volts with the ignition switch on. It seems to me that this is the signal wire for the fuel gauge and that it needs to be spliced into one of the other wires on the stock ECU harness. I'm guessing that the signal went through the stock ECU and then to the gauge (I could be totally wrong though). I don't want to just start splicing it with other wires guessing where it is supposed to go. I didn't know if anyone else that has installed a stand alone unit had the same problem.
Old 03-07-2006, 02:29 AM   #5
spulinup
Member#: 63880
1998 Doom Wagon
swapped GF8 with jdm ish
When I wired up my ej20G in my 96 Impreza I had the same problem. My wire diagram showed that brown/yellow was the wire for the fuel level meter. It turns out that there are two brown/yellow wires. One was for reverse and the other was for the fuel level meter. I had them backwords. I changed them and everything is fine now. Hope this helps and good luck.
spulinup is offline   Reply With Quote
Old 03-21-2006, 01:18 PM   #6
djwhetzel
Member#: 109020
WR Blue
I found the problem and thought that I would share just incase anyone else ran into this problem. The factory plug for the factory ECU has grounds at various different places and I needed the ground for the "Control Systems" to be hooked up. As soon as I hooked that gound up, the fuel gauge started working and the temp gauge (which was sky rocketing in the red when my laptop said that I was only at 130 degrees) started working right. Thanks for all the replys and help guys.
fuel gauge not working temtiv Electrical & Lighting 0 02-19-2008 07:36 PM
Fuel Gauge not working omeskcus Normally Aspirated Powertrain 1 12-12-2006 12:52 PM
Fuel gauge not working correctly omeskcus Service & Maintenance 1 12-12-2006 12:21 AM
05 Sti Fuel gauge not working please help hilfiger4you Service & Maintenance 5 12-11-2005 12:52 AM
fuel gauge not working sssp Service & Maintenance 7 06-28-2005 11:28 PM
