Old 01-13-2012, 05:56 PM   #26
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
yes there is an enable switch in opensource to enable "force pass readiness monitors"
i went to smog once and failed because i didnt have it checked. the guy told me i needed to go drive 80 miles for the monitors to pass. I went home, flashed, went back 5 minutes later and passed. He never asked how i drove so far so fast
Old 11-10-2012, 04:16 AM   #27
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I lol at post #25 thats funny. If they where tamper proof someone would hack it most likely.
Wrxed I'm in the same boat for now also.
spoolinsti05 is offline   Reply With Quote
Old 11-10-2012, 11:33 AM   #28
Phatron
Member#: 36033
CEO PhatBottiTuning
The "force pass readiness" function is in the 05 STi opensource rom.
Old 11-11-2012, 09:52 AM   #29
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
It's also available through the Cobb Tuning, AccesstunerRace software.
Black94Snake is offline   Reply With Quote
Old 01-04-2013, 08:31 PM   #30
scooby4u
Member#: 324722
2004 Impreza WRX
In the AccessTuner Race, under the edit tab go to advanced parameters. There are two tabs on this page DTC's and Toggle's. Go into toggles and uncheck "Monitors Self-Test" and that should force your readiness to complete. Correct me if I am wrong please.
scooby4u is offline   Reply With Quote
Old 01-05-2013, 12:48 PM   #31
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You are correct.
Old 01-25-2013, 09:22 PM   #32
Jasoned
Member#: 344895
scooby4u In the AccessTuner Race, under the edit tab go to advanced parameters. There are two tabs on this page DTC's and Toggle's. Go into toggles and uncheck "Monitors Self-Test" and that should force your readiness to complete. Correct me if I am wrong please.
I tried this to force readiness on my 2007 STI. It did not work. Catalyst still not ready. I tried with and without the green connectors connected. Any other suggestions, or am I doing it wrong?
Jasoned is offline   Reply With Quote
Old 03-02-2013, 10:47 AM   #33
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
about uncheck monitor self check on my 02 wrx and give it a try...
Worked for me. I went through NJ state DMV inspection and passed.
maxpowr is offline   Reply With Quote
Old 07-12-2013, 09:39 PM   #34
kman49ny
Member#: 351962
I'm in the same situation with having to force readiness. Could you tell me if you flashed the map with the monitor self check unchecked using the Access Tuner Race software as a base map or would a real time map flash work if the car is left running during the inspection. I have a tactrix cable on the way to fully use the software and also i herd you can use Rom raider to force readiness. I have a 04 wrx Cobb STX 93 and it came uo with 02 sensor and Evap system not ready. Please, need help. thank you
kman49ny is offline   Reply With Quote
Old 07-22-2013, 01:03 PM   #35
R7MR7M
Member#: 86570
2007 STi
Urban Gray
I am also curious about this. I have an 07 STi that needs a smog and has been tuned prior to my purchasing it. I have an Injen CAI, catless DP/TBE. I do own a COBB AP but have only used it to backup my existing tune. I am going to be replacing the DP with the stock one but am concerned about the tune/ecu aspect and the readiness monitors. Can I force readiness on my existing, non COBB AP tune; or will I need to flash to stock; or _________?
Thanks
R7MR7M is offline   Reply With Quote
Old 09-12-2013, 07:15 PM   #36
spongerrich
Member#: 214736
2005 WRX wagon WRB
Cobb Stage 2 OTS
Bump for answer.
I have an 05 WRX driven about 1700 miles on new engine with VF48 and STI injectors. It was protuned. No CEL but the Catalytic readiness monitor still says "not ready". California STAR test stations require all the monitors to be ready.
spongerrich is offline   Reply With Quote
Old 07-06-2014, 07:11 PM   #37
Balabok
Member#: 60913
2006 WRX Sport Wagon
Stage 3 WR Blue
Originally Posted by vtecTHIS View Post
i now this is old, but this guy and post saved me a huuuuuuuge headache. if you get the not ready fail for the cat/evap do the first thing. i drove 60 for 20 minutes straight,idled for 1-2 minutes. turned car off for 2 minutes. then did it again. went back and everything was 'ready'!
I just did exactly this! Passed with a Titek single cat downpipe. AP flashed back to stock from stage 3. I had 7 out of 8 monitors ready. Here's a screencap from Torque showing monitors that are ready.
Balabok is offline   Reply With Quote
Please read my post. Am I financially ready for an STI? sXi General Community 138 08-22-2006 05:58 PM
Amplifier Issue *please read* circaisdashiat Car Audio, Video & Security 4 01-26-2006 08:43 AM
*ATTN* Safety issue when using CUSCO rear swaybar on a STI. Please read!! Dynamispeed Southern California Impreza Club Forum -- SCIC 29 03-08-2004 11:18 AM
Swaps and obd-1/obd-2 issues Cert Subaru Conversions 15 11-19-2003 11:17 PM
Warranty Issue ??? Please read... MKULTRA General Forum Archive 15 05-24-2000 12:06 AM
