Old 03-07-2006, 11:57 AM   #1
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Default AP setup, just 1 question!
So after i plug in the ap, and i flash the maps to my ecu, do i have to do the vishnu reset everytime i switch to a different map, say from stage 2 to the economy? that would kinda suck....or is it just a first time deal to flash the ap?
Thanks
Jon
Jpizzzle is offline   Reply With Quote
Old 03-07-2006, 12:50 PM   #2
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
You dont have to do it at all.
parker/slc/gc8fan is offline   Reply With Quote
Old 03-07-2006, 01:33 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yep, you really don't have to do it. It just artificially speeds up the learning process the ECU goes through by targeting some specific conditions that it checks to increase the IAM from 8 to 16 (or from .5 to 1 for sti's). It will have no effect on the fuel trims that your car needs to learn. In fact, I would venture a guess that it is probably better for the car to NOT do a vishnu reset because I would prefer to have fuel trims come into line before timing is maxed out.
nhluhr is offline   Reply With Quote
Old 03-07-2006, 01:49 PM   #4
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
ok so my real question still remains, do i have to wait to use each of the maps if i use a new one? say i first use the stage two setting, you have to wait for X days for it to really work. if i decide i want some fuel economy and use the economy map, do i have to wait X amount of days again before it kicks in?
Old 03-07-2006, 06:43 PM   #5
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Everytime you load a new base map for the ecu is basically reseted, not so for when you load a realtime map.
I beleive the main point of doing the "vishnu reset" is to increase the IAM to 16 as soon as possible. Whether that is such a good thing for the engine is debatable since your increasing the timing right away without the ecu having proper time to learn how your engine is performing.
When you load a new basemap/reset the ecu your IAM will go to 12 (when using the Off the Shelf AP maps), and will take a little time to advance to 16 or go down depending on how much knock you are getting.
How long it takes to learn varies, could be a few miles, could be a few hundred. I have noticed that usually within 15-30 miles of varied driving the IAM will usually be pretty much set at a certain point.
So to kind of answer your question, if you just switch realtime maps there is no need to do a "vishnu reset" or be worried that your not getting the max out of your engine. If you switch base maps doing the "vishnu reset" will make a difference right away.
boundy3 is offline   Reply With Quote
Old 03-08-2006, 07:01 AM   #6
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
i guess i dont understand the difference between base and realtime, quick explanation?
Old 03-08-2006, 11:37 AM   #7
boundy3
Member#: 54598
2004 WRX Sedan
Base maps contain all of the basic instructions for your ecu.
Realtime maps contain additional data to acheive a certain objective.
For example, if you have a turboback exhaust you should load the stage 2 basemap.
If one day you decided to go auto-x and wanted to run the STX map, all you would have to do is load the STX realtime map and the realtime map would tell the basemap to limit boost to 13.5 and go back to the stock wastegate duty cycles (since you are not allowed to change boost and WDC in STX).
Same as if you want to valet park your car and load the valet realtime map, it would tell the basemap to limit the revs and such.
If you add a realtime map and just want to back to normal stage 2 all you have to do is load the stage 2 realtime map, and it will act just like the basemap and there is no need to reset your ecu, ie do the "vishnu reset". All the learned parameters will still be there when you only change a realtime map.
There are other better examples, search around.
Old 03-08-2006, 12:22 PM   #8
-Kevlar-
Member#: 82378
took the words right out of my....fingers..
-Kevlar- is offline   Reply With Quote
Old 03-08-2006, 01:43 PM   #9
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
so then the base map basically just acknowledges what you have installed on your car and the real time map tells your ecu how to run, in a nutshell...correct? thanks for all the help boundy3! i should have it by the end of this week!
Old 03-08-2006, 02:24 PM   #10
-Kevlar-
Member#: 82378
not really but kinda. if it was like you said you would have to load a realtime map everytime but you dont. just the base. and then the realtime map just "tweaks" it.
Old 03-08-2006, 05:17 PM   #11
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
so the ap holds 10 maps total? real and base together ie. 5 real 5 base? then do you have to load the base map everytime you want a different tune ie. from stg 2 to economy? if this is true, then do i have to train my ecu for the x miles again before it trains itself to the new map?
Sorry for all the newb questions, however i think this thread will clear up a lot of questions for many others as well as myself.
Thanks for all the help!
Jon
Old 03-08-2006, 06:08 PM   #12
-Kevlar-
Member#: 82378
no, just flash stage 2 as your base then select switch map. pick the map you want to run. done. leave the base alone unless you need to revert to stock.
Old 03-08-2006, 09:21 PM   #13
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
ok, so say i have my stg 2 base set up, then i use the stage two real time. then i want to save money, so do i have to run the realtime economy as well as the base economy? or can i run the realtime economy with the base stage two? and does it take any break in time when switchin just the realtime?
so many questions, sorry!
Old 03-09-2006, 09:11 AM   #14
-Kevlar-
Member#: 82378
no just keep it as stg 2 base and think of the realtime maps as "tweaks". your base is the map you want to run all the time, but the RT maps are just to save your ecu. b/c you can only flash base about 100 times. also, there is no need to flash stg 2 base and then flash stg 2 realtime. also, when i got mine i wanted to run a stock base map. so then i flashed stg 2 RT map and it just didnt perform right. the base HAS to be your performance map. and the realtime can be whatever you want. period.
Old 03-09-2006, 12:30 PM   #15
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
ok, well now i understand and will let you know how it works when i get my ap, should be here by friday-ish...thanks for all the help!
AP Newb, Just updated the AP and lost some features? morrocco88 AccessPort 0 02-03-2010 09:28 PM
Have just 1 Question for my Swapped ECU..!? ViperWRX Subaru Conversions 4 05-29-2009 06:29 PM
ap setup question JPinn AccessPort 3 08-22-2006 07:13 PM
Just got my AP, quick Stage 1 Question porque Engine Management & Tuning 15 01-07-2005 11:59 PM
Just setup dual monitors...question... Jimmy S. Off-Topic 7 07-28-2004 01:25 AM
