Old 05-12-2001, 02:21 PM   #1
tonytiger
Member#: 3844
1993 Legacy 1.8
Lightbulb Lowering idle RPM?
I think that the car is using too high rpms when idling. Does anyone know how to do this adjustment? Hope it's not ECU related. Most of you have Imprezas but I think it would nearly the same with my oldie. Pics would be great but any comment is highly appreciated. Thanks in advance...
tony
[This message has been edited by tonytiger (edited May 14, 2001).]
tonytiger is offline   Reply With Quote
Old 05-12-2001, 05:11 PM   #2
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Post
Its controlled by the computer. What do you idle at!? When I start it up, I hover at 1500 for a while, then it drops to 1000. When it is compleatly warmed up, it sits at 500.
Kevin
95 L
kevinsUBARU is offline   Reply With Quote
Old 05-12-2001, 06:32 PM   #3
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
There is an idle screw. If you look at the throttle body from the front of the car, it is located to the right of and almost below the throttle body. There is a 8 mm, IIRC, nut that keeps the screw in place. The head of the screw faces the firewall and you'll need a small phillips head screwdriver to turn it. Screwing it in increases the throttle opening at idle, hence raising RPM, and vice versa.
Hope this help,
Joe
If no one posts any pictures by tomorrow morning, I'll go take some and post it.
BTW, be careful when you mess around with it. Lowering your idle RPM too much could cause the car to stall when you lift off throttle!
jhuang76 is offline   Reply With Quote
Old 05-13-2001, 02:51 PM   #4
tonytiger
Member#: 3844
1993 Legacy 1.8
Cool
jhuang76: Thank you very much. Still waiting for the photos if it isn't asked too much. Normally it hasn't used as high rpms when at idle. Nowadays it uses rather high rpms at the start (about 1500) but doesn't lower enough when warmed up. Dunno if this at all a wice thing to do but I'm giving a shot. Besides it's fun to all kinds of adjustments. Hmm...just catch a thoght about a that my battery went down last winter (minus 15 celsius). Maybe it has reset my ecu and therefore it doesn't lower... Any thoghts? Was it something like battery off for an half an hour and let it warm up by itself and then turn of...Thanks again
kevin: didn't catch your drift about idling, it's my mother language
tony
Old 05-14-2001, 03:34 PM   #5
tonytiger
Member#: 3844
1993 Legacy 1.8
Post
Umh, didn't find the skrew. It's time for brain or eye update mod If you are still here with us Joe please take a couple of fotos and sem them in. Of course anybody else is welcome to send them. Gimme gimme Haven't check my spark plugs for a while, maybe I should check those out also while messing under the hood, if those are causing the situation...
tony
Needle drop lower than idling RPM... Henry Engine Management & Tuning 2 09-25-2003 11:52 AM
Help! Needle drop lower than idling RPM?? kalasend Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-07-2003 10:11 AM
Raising the idle rpm speed PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2002 09:51 AM
High idle RPMs and throtlle blips when shifting Holograph Service & Maintenance 9 09-19-2002 03:53 AM
Idle RPMs? willguidry Normally Aspirated Powertrain 12 03-28-2002 01:33 AM
