Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-07-2006, 03:53 PM   #1
_sti_05
Member#: 72313
16 STi
Default Help with problem
I have been having alot of studdering and hestation when i get on the throttle, for explame, if im cursing along and im getting ready to get on the onramp, i give it gas and it starts to studder, i have to let go of the gas for it to go away. i took some logs of when the studdering accurs. anyone see anything wrong with them.
how do i post my logs here?
_sti_05 is offline   Reply With Quote
Old 03-07-2006, 04:23 PM   #2
_sti_05
Member#: 72313
16 STi
Code:
2498	-4	2.2	20	0	0	44.4	7.6	Ecu.	2	Ecu.	2.1
2610	-4.3	2.3	21	0	0	44.5	9.2	Ecu.	2	Ecu.	2
2798	-4.9	2.3	21	0	0	45.9	9.9	Ecu.	2	Ecu.	2.1
3063	-5.1	2.4	20	0	0	45.6	8.8	Ecu.	2	Ecu.	2.1
3089	-5.1	2.3	21	0	0	45.6	9.7	Ecu.	2	Ecu.	2.1
3255	-5.3	2.3	21	0	0	45.6	8.4	Ecu.	2	Ecu.	2.1
3373	-5.5	2.3	16	0	0	44.3	9.4	Ecu.	2	Ecu.	2
3326	-6.7	1.7	2	0	0	36.3	5.9	Ecu.	2	Ecu.	1.5
3248	-8.5	1.7	2	0	0	30.9	5.9	Ecu.	2	Ecu.	1.5
3055	-10	1.6	2	0	0	23.4	5.9	Ecu.	2	Ecu.	1.4
2886	-11.4	1.6	9	0	0	26.7	3.6	Ecu.	2	Ecu.	1.4
2374	-11.4	2.1	15	0	0	36.8	7	Ecu.	2	Ecu.	1.9
2308	-10	2.1	16	0	0	39.3	5.6	Ecu.	2	Ecu.	1.9
2364	-8.5	2.1	16	0	0	40.7	7	Ecu.	2	Ecu.	1.9
2408	-7.3	2.1	15	0	0	40.8	7.3	Ecu.	2	Ecu.	1.9
2452	-6.5	2.1	17	0	0	41.4	7.4	Ecu.	2	Ecu.	1.9
2502	-6.7	2.1	17	0	0	42	7.3	Ecu.	2	Ecu.	2
2566	-6.9	2.1	16	0	0	42.2	6.4	Ecu.	2	Ecu.	2
2620	-6.9	2.1	17	0	0	42.4	8	Ecu.	2	Ecu.	2
2673	-6.9	2.1	17	0	0	42.9	6.5	Ecu.	2	Ecu.	2
2721	-6.9	2.2	18	0	0	44	8.7	Ecu.	2	Ecu.	2
2803	-6.7	2.3	20	0	0	45.6	10.3	Ecu.	2	Ecu.	2.1
2878	-6.3	2.3	21	0	0	45.5	10.3	Ecu.	2	Ecu.	2.1
2957	-5.9	2.4	21	0	0	45.7	10.2	Ecu.	2	Ecu.	2.2
3033	-5.3	2.4	23	0	0	45.7	10.6	Ecu.	2	Ecu.	2.2
3109	-4.9	2.4	22	0	0	45.7	10.6	Ecu.	2	Ecu.	2.2
3195	-4.9	2.4	23	0	0	45.5	9.7	Ecu.	2	Ecu.	2.2
3280	-4.7	2.5	24	0	0	45.7	12	Ecu.	2	Ecu.	2.3
3330	-4.5	2.5	25	10	0	45.3	10.2	20.4	2.5	Ecu.	2.3
3387	-4.5	2.5	25	10	0	45.5	10.2	20.6	2.5	Ecu.	2.4
3479	-4.3	2.6	25	10	0	45.6	10.4	20.9	2.5	Ecu.	2.4
3553	-4	2.6	25	10	0	45.8	11.4	21	2.5	Ecu.	2.4
3607	-4.3	2.6	25	10	0	45.6	11.4	21	2.5	Ecu.	2.4
3728	-4.3	2.6	24	0	0	45.4	11.5	Ecu.	2	Ecu.	2.4
3809	-4	2.6	25	10	0	45.4	12.2	21	2.5	Ecu.	2.4
3827	-4.3	2.6	25	10	0	45.3	12.2	21	2.5	Ecu.	2.4
3916	-3.8	2.7	24	0	0	45.6	12.8	Ecu.	2	Ecu.	2.4
3992	-3.4	2.7	25	10	0	45.3	14.1	21	1.8	Ecu.	2.5
4030	-3.6	2.8	25	10	0	45.4	14.5	21	2	Ecu.	2.5
4130	-3.4	2.7	24	0	0	45.4	15.1	Ecu.	0.8	Ecu.	2.5
4246	-3.2	2.8	25	10	0	45	14.6	21	-0.1	Ecu.	2.5
4273	-3.6	2.8	25	10	0	45.3	15.1	21.1	-0.1	Ecu.	2.5
Old 03-07-2006, 05:46 PM   #3
kcook
Member#: 78074
2005 STi
does it stutter around 2700-3000rpms?? if so.. thats normal until u get a tune
kcook is offline   Reply With Quote
Old 03-07-2006, 06:04 PM   #4
_sti_05
Member#: 72313
16 STi
i do have a tune, its been tuned 3 times and still does the studdering, it pretty much happens at any rpm, just when i captured it on the log it was in the 3000-4000 range
Old 03-07-2006, 11:31 PM   #5
_sti_05
Member#: 72313
16 STi
bump..
Old 03-08-2006, 04:41 AM   #6
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
It seems that the jump in timing might be helping to cause this. Going from +45 to +20 then back to +45. I only have a stage 2 but in those load zones im running +29 timing, maybe if you increase the timing advance in your 10-30 load columns it would help the transistion.
Seeing as you are still in vacuum around these points there isn't much need to run low timing numbers. My map (tuned by TurboXS) doesnt hit 20 degrees until the 40% load column and right before peak torque.
Here is a artical by Nathan talking about tuning timing and how as VE increases (buy pushing denser air into the engine) timing decreases. This works both ways as VE decreases timing increases. So in the lower load points increase timing to help burn the low VE charge of air.
http://www.wrxhackers.com/forums/showthread.php?t=2068
Maybe some Guru can chime in on this as well, seeing I've only been messing with my UTEC for a few weeks
TravisSTi is offline   Reply With Quote
Old 03-09-2006, 12:18 PM   #7
_sti_05
Member#: 72313
16 STi
Do you think you can point it out for my on the log i posted, where u say im jumping from +45 to +20 i tired looking but i dont where your talking about. Super noob on this utec stuff.
Old 03-09-2006, 01:09 PM   #8
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
^^The 7th column shows the amount of timing the stock ECU wants to run. The 9th column shows the amount of timing the UTEC want to run. See how the 9th column says ECU most of the time. Well that means the stock ECU is controlling the timing. Then it changes from ECU to a number (ex. 21). That means the UTEC now took control of timing and the engine is running 20 degrees of timing. So that stuttering you are feeling is from the engine going from 40+ degrees of timing to 21 degrees of timing.
In the timing map, change these values:
0% column - change values from 250RPM to 5250RPM to 'ECU'
10% column - change values from 250RPM to 4750RPM to 'ECU'
20% column - change values from 250RPM to 4750RPM to 'ECU'
30% column - change values from 250RPM to 4500RPM to 'ECU'
40% column - change values from 250RPM to 4250RPM to 'ECU'
50% - 100% column - change values from 250RPM to 1500RPM to 'ECU'
This should allow the stock ECU to control the timing during most of your partial throttle driving and you won't get the crossover hesitation.
SloRice is offline   Reply With Quote
Old 03-09-2006, 02:43 PM   #9
_sti_05
Member#: 72313
16 STi
Awesome, thanks alot man, i will try this tonigt.
Thanks!
Old 03-10-2006, 04:39 PM   #10
_sti_05
Member#: 72313
16 STi
I was looking at my boost map today. Does this seem right?
Code:
Boost Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]
      [0]      [0]      [0]    [375]    [375]    [375]    [375]    [375]    [375]    [375]    [375]
Old 03-15-2006, 08:23 PM   #11
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Don't worry mine is full of 80's since I change the T in the wastegate turbo vac. line
gaby is offline   Reply With Quote
Old 03-30-2006, 05:14 PM   #12
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
If you are using a EBC to control your boost, yes.
_R
RickInLittleElm is offline   Reply With Quote
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
problem with wheel bearings.. some issues that need help with. evoeater8 Brakes, Steering & Suspension 15 09-11-2006 02:08 PM
Need some help with a problem with my knee StuBeck Off-Topic 65 01-12-2006 12:24 PM
NEED HELP with problem diagnosis (long) 17cTSi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-30-2004 04:07 PM
Help with Problem?? gr8wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-05-2003 04:25 PM
