Old 03-05-2006, 01:47 AM   #1
Impr3zy0u
Member#: 93404
Default Crappy idle when cold.
So my other thread was kinda off track so i deceided to start another. So i cant seem to figure out my idle issue. But the car idles really rough when its warming up in the morn. The car will shake around and idle rough untill it is completly worm, then it seems to smooth out. My buddy looked at all the sensors on his data logger and eveything looked ok "that was when the engine was warm and idleing ok though". So far i have swaped the MAF and IAC with my sisters WRX with no difference, and i also checked around for vacume leaks with starter fluid, and put in a brand new front o2 sensor, still idles horriable when warming up. One of my friends suggested maybe the coolent temp sensor is bad, if thats so would the sensor on my dash not work, because it seems to show the engine warming up as usual. Any ideas im lost and need to figure this out. I guess the next step would be to compression test it and swap the plugs "even though they only have like 5k on them". Only mods are a turbo-back. Stock intake and such.
Impr3zy0u is offline   Reply With Quote
Old 03-05-2006, 03:36 AM   #2
23b_Rex
Member#: 79394
02 gda
wrb
http://dictionary.reference.com/search?q=worm
when's the last time you changed your oil
23b_Rex is offline   Reply With Quote
Old 03-05-2006, 11:00 AM   #3
Impr3zy0u
Member#: 93404
about 600 miles ago, why?
Old 03-05-2006, 11:05 AM   #4
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Check the turbo inlet hose, I have seen those crack before, but they usually trigger a lean misfire though.
Old 03-05-2006, 11:27 AM   #5
Impr3zy0u
Member#: 93404
I sprayed starter fluid all over the hoses and nothing, im going to be doing a compression check soon.
Old 03-07-2006, 07:40 PM   #6
Impr3zy0u
Member#: 93404
compression results: 150, 150, 150, 150
Up and down idle when cold RRRR1 Engine Management & Tuning 12 05-11-2005 02:12 PM
Rough idle when cold jkiny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-24-2003 05:58 PM
High Idle When Cold Keith99RS Legacy Forum 42 01-23-2002 08:07 PM
Erratic idle when cold Peaty Normally Aspirated Powertrain 3 05-21-2001 08:41 PM
