Old 03-07-2006, 04:48 PM   #1
daprez
Visiting NASIOC Timeout
Member#: 105645
2002 WRX Sedan
WRBP
Default the n00b questions will keep coming!
I have done a good amount of research on the topic of EM, but I have had a hard time finding answers to a few extremely newbish questions and I thought I'd ask you guys before hitting up Cobb directly. I apologize in advance for eyestrain from forceful backwards rolling!
So - true or false - the AP plugs into your OBDII port and it stores up to 10 maps. And these maps can be any of the following:
- staple maps downloaded from Cobb or presumeably other places
- maps you make yourself with StreetTuner
- maps you hire a tuner (or make yourself) to create with ProTune, which allows a finer granularity of parameters, to match your specific car?
Next dumb question: must you leave the AP plugged into the OBDII port for the map to work? Or do you flash the ECU, then pull the AP out and stick it in your glovebox or something?
The big newbie question: I am aware that the ECU in my WRX is really sophisticated, and makes complex decisions based on a lot of data. As a newbie to the concept of engine management, I was really surprised, for example, to learn that my ECU will make adjustments based on altitude as well as ambient temperature, and has different sequences for cold start after sitting for a few hours, and hot re-start after, say, a stall. Do the AP maps make use of all of this stuff?
Thanks for reading!
daprez is offline   Reply With Quote
Old 03-07-2006, 05:26 PM   #2
Scoobie Noobie
Member#: 65498
True. the AP stores maps and they can be any AP compatible maps.
No you don't leave it plugged in after flashing. I keep mine in my closet at home.
As I understand it, the AP only remaps certain ECU parameters with the standard maps. Most of the mundane functionality is still handled by the stock programming.
Scoobie Noobie is offline   Reply With Quote
Old 03-12-2006, 01:28 AM   #3
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
yup, your car's ECU will make adjustments depending on temp and altitude, but mainly how you drive it. if you reflash it, then drive like crazy, the timing will be increased to compliment the demand for it...
you don't need to have the AP plugged in while driving, unless you want to change the realtime map, or monitor boost..
WolfInSheepsCLothing is offline   Reply With Quote
Old 03-13-2006, 07:03 PM   #4
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
And if you're gonna try to monitor boost, ahve someone else in the car!! It's probably not safe to be checking live boost readings and driving at the same time!!!!
ihavebettersound is offline   Reply With Quote
Old 03-14-2006, 02:19 PM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
False. You cannot use street tuner maps on a regular AP. You can use streettuner maps on a StreetTuner-Converted AP, but if your AP is converted to a ST-AP, you cannot use normal AP maps that you'd download from cobb's site.
nhluhr is offline   Reply With Quote
Old 03-14-2006, 06:20 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Thanks for reading!
Yes and no. They make use of it to the extent that their are only changing parameters, not the whole code. No the the extent that Cobb's maps are not usually actually changing any of the coldstart parameters, for example, because they have no need to.
mcowger is offline   Reply With Quote
Old 03-14-2006, 08:07 PM   #7
DTECH-WRX
Member#: 37042
2014 Forester 2.0 XT
Marine Blue Pearl
Another good Newbie question to answer might be does the Street Tuner-AP have any starting/base maps to work with or do you have to start off tuning a map from scratch?
Also does Protuner truely have finer parameter "adjustments" than Street Tuner?
DTECH-WRX is offline   Reply With Quote
Old 03-20-2006, 10:58 PM   #8
gqchynaboy
Member#: 88529
Lets say I got a protune.
Here is a n00b question, if i needed to unplug the battery will I need to reload the protune map again? Also, is it easy to accidently delete/remove the protune map from the AP?
gqchynaboy is offline   Reply With Quote
Old 03-21-2006, 12:51 AM   #9
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Not if you set the map as your basemap, no.
Easy? No. Possible? Yes.
Old 03-21-2006, 03:16 AM   #10
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Cobb provides a few maps to start with but they are supposedly not as aggressively tuned as their AP maps so for instance, the "Stage1.stb" StreetTuner map will not be as strong as the "Stage1.ptb" AP map. They leave a lot of headroom for tuning.
Protuner does not have finer adjustment, but it does have MORE adjustments. The granularity of the maps is identical, but StreetTuner does not currently have, for instance, IAT-based Ignition Advance Compensation whereas Protuner does.
If you follow the forums at www.wrxforum.com , there is constant discussion of what mapping will be added to StreetTuner's capability in the next revision. They just keep adding to ST's capability. Soon, ST and Protuner will be equally capable with the exception that ST will be limited to a single ECU.
Typically, a Protuner would make their map a BASE map which means it is stored on the ECU in non-volatile memory (you won't lose it when you unplug the battery). They should also give it to you on a computer disk or through email so you can have it at your disposal in case you need to unmarry or whatever.
If they don't give it to you as a .ptb file, you can easily get it off your AP onto your computer using the Map Manager software.
the RS STI will be coming alive soon..... SubeSTIle South West Impreza Club Forum -- SWIC 58 05-11-2007 04:55 AM
Riplers car, Kingpin and the Texas Mile will Kingpin come through??? H.K. Phooey Texas Impreza Club Forum -- TXIC 54 10-28-2006 12:08 PM
Sorry for the n00b questions..help please! subiee sTi Newbies & FAQs 8 06-26-2006 11:47 PM
This may be the n00b question of the year.... RedMenace Legacy Forum 17 08-17-2003 10:51 PM
Which tires are best .... this is a repost since the question keeps coming back [email protected] Brakes, Steering & Suspension 7 07-25-2001 07:07 PM
