Old 03-07-2006, 05:11 PM   #1
Chonojake
Member#: 82313
2003 REX WAG
Platinum
Question Check engine light blinking!?!
I have an OBD2 reader and it is giving me a EGT upper bank sensor error.
When I am driving, the check engine light blinks when I am accelerating under most conditions. ie light load, rolling on smooth, hard loads(2/3 throttle).
I am thinking I have had total Sensor failure... would this thought be warranted?
Planning on replacing the sensor soon, I just wanted to hear from you all and see what you think.
Jake
Chonojake is offline   Reply With Quote
Old 03-07-2006, 05:15 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
flashing CEL = misfire in progress... That is if the ecu is running the show. If you have a utec on there, it means detonation is in progress..
do you have any mods?
jigga is offline   Reply With Quote
Old 03-07-2006, 05:36 PM   #3
STL WRX
Member#: 88304
05 VF34 Aspen WRX
Flashing check engine light is your cars way of saying OMFG HELP ME NOW!
STL WRX is offline   Reply With Quote
Old 03-07-2006, 05:40 PM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
insufficient information about your car. Possible induction leak post-MAF?
supermarkus is offline   Reply With Quote
Old 03-07-2006, 11:30 PM   #5
pingpong
Member#: 108539
2004 wrx sedan
+1
Get it fixed ASAP!
pingpong is offline   Reply With Quote
Old 03-07-2006, 11:33 PM   #6
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
Originally Posted by pingpong
+1
Get it fixed ASAP!
wow, simply useful info... anyway, flashing cel means misfire on stock ecu like previously stated. on utec, it means knock knock
vipernj is offline   Reply With Quote
Old 03-08-2006, 05:52 PM   #7
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I had a flashing cel running Cobb stg. 2 I t suggested a misfire, but Trey @ Cobb told me to do the 2.2K mod. I did, and the cel was gone.
BIG GUN is offline   Reply With Quote
Old 03-08-2006, 06:05 PM   #8
-Kevlar-
Member#: 82378
wow all you had to do was look down the page a bit. didnt even have to do a search. oh well. ^^^ x eleventy billion for misfire or knock w/ utec.
-Kevlar- is offline   Reply With Quote
Old 03-08-2006, 07:57 PM   #9
Chonojake
Member#: 82313
2003 REX WAG
Platinum
Knock Knock? what does this indicate? Lean mixture? More info pls...
Old 03-08-2006, 08:26 PM   #10
supermarkus
Member#: 6971
2008 WRX STi
SSM
How can we help if we don't know what you have done to your car? All of this is just stabs in the dark until there is a mod list posted. Have changed your components lately or checked for vacuum leaks?
Old 03-08-2006, 08:34 PM   #11
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
It looks like you are quite a n00b to the Subaru's. You have misfiring in progress. Replace that sensor and you should be fine.
Anub1s is offline   Reply With Quote
Old 03-09-2006, 10:44 AM   #12
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
If you get a chance you should do a compression test... My car started throwing Misfire CELs and the occasional flashing CEL and cylinder #1 & #3 tested very low.
Useful Thread: http://forums.nasioc.com/forums/showthread.php?t=956842
Good luck!
coolcougar is offline   Reply With Quote
Old 03-09-2006, 07:58 PM   #13
Chonojake
Member#: 82313
2003 REX WAG
Platinum
Exclamation List of engine mods
Here are the mods as of late... Sorry for not posting this earlier in the Thread.
IHI VF34
turboXS Tmic
" " Turbo back exaust w/ Magna flow muffler
" " Piggy back w/dyno tune
WB O2sensor
K&N airfilter.
thats all for the motor right now. I have come to the conclusion that I should replace my EGT sens. Is this an easy one to do? Also where is it I have been under the car and can't locate it. I should and will by a shop manual.
I do like having all of your experience and opinions to help me base my decisions on so, keep them coming thanks again.
Old 03-09-2006, 08:38 PM   #14
lovesmysuby04
Member#: 71494
07 Legacy GT
11 SSM Hatch
EGT is in the upper half of the uppipe. You should be able to see it just under the turbo on the passenger side.
lovesmysuby04 is offline   Reply With Quote
Old 03-09-2006, 10:54 PM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
you could replace it, but it will just crap out on you again. Do the resistor mod, replace the probe with a bolt or just clip the end off the probe and use it as a plug and be done with it.
Old 03-10-2006, 12:12 AM   #16
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
agreed.....
Old 03-10-2006, 12:35 AM   #17
Deus ex Machina
Member#: 79815
06 Mazda 6S
Does your car lose a lot of power when the CEL is flashing? It could also be a loose coilpack... It happened to me, so I'm just throwing out my two cents.
Deus ex Machina is offline   Reply With Quote
Old 03-10-2006, 03:49 AM   #18
prometheum
Member#: 92003
04 bicycle!
happened to me too, causes a mis fire and its very bad for your cats
prometheum is offline   Reply With Quote
Old 03-10-2006, 10:46 AM   #19
-Kevlar-
Member#: 82378
thats a good bit of mods w/o even knowing what knock is.
Old 03-10-2006, 06:10 PM   #20
Chonojake
Member#: 82313
2003 REX WAG
Platinum
Question
Supermarcus what type of resistor do I use? Well the light has stopped blinking but I am having a huge loss in power and the engine seems to be pulsing now. Its definatly making me uneasy.
Old 03-10-2006, 06:56 PM   #21
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Does it pulse more under boost? It definitely sounds like a misfire. I had the same problem once. Check your coil packs they can come loose.
blkwrx02 is offline   Reply With Quote
Old 03-10-2006, 11:21 PM   #22
Chonojake
Member#: 82313
2003 REX WAG
Platinum
yeah I am going to do that tomorrow. ummm yeah kinda... at all throttle positions. I can feel it early, about 2k... so I keep it gental.
Old 03-11-2006, 02:30 AM   #23
josh04
Member#: 89288
2002 Rex
When your car pulses as you say. Does it allow you to go past rpm where it's pulsing at. Or do you have to let off and then give it gas again to get past it.
josh04 is offline   Reply With Quote
Old 03-11-2006, 07:42 AM   #24
K2Skier
Member#: 20515
2002 WRX - 2.5L
most likely, your knock sensor is hearing an audible noise which it is translating as knock.
K2Skier is offline   Reply With Quote
Old 03-11-2006, 09:13 AM   #25
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
But does it come on stronger during boost? I ask because when I had a loose coil pack the car would drive (struggled but drove) but as soon as it went under boost it bucked and pulsed like crazy.
Help! Check Engine Light + Blinking Cruise Control mindz0f1 General Community 3 02-15-2007 09:35 AM
check engine light blinking jimball21 Tri-State Area Forum 20 01-25-2005 12:31 AM
Check engine light blinking!!! rageatm007 Electrical & Lighting 5 07-26-2004 07:54 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 5 08-26-2003 09:08 PM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 08:59 PM
