#1 |
Member#: 48199
Vehicle:06 WRX WRB |
First off I did a little searching and it appears that the # KB-002-2002 will work on a 2006 WRX, correct?
I didnt get the factory short shift because it was an easy cheap aftermarket mod. But after looking through some of the litature I got the dealer the factory short shift picture shows all the linkage from top to bottom. Is this something Subaru does to make it look like your getting more for your money, or is there some other benefits to having OEM over Kartboy? Thanks
#2 |
Big Ron
Moderator Member#: 18062
The linkage is cadnium plated for extra bling on the OEM unit and does nothing. Don't know the part number, but the Kartboy shifter will work on your car. Other than that, look at getting Kartboy bushings to accent their shifter.
#3 |
Member#: 86356
I'm not sure exact part numbers but my short shifter from my 05 fit right in my 06, FYI.
#4 |
Member#: 48199
cool thanks....I'm about to order the shifter and bushings now....
is the best place to buy direct? Thanks again |
#5 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Check out the vendor review forums, and the vendor for sale forums to see who carries KB stuff and who is reliable. Of course, there's always the easy way out by going straight to the source -> www.kartboy.com.
#6 |
Member#: 102238
Vehicle:08 DGM STi *RIP* 06 WRX TR |
I've tried a standard subaru short shifter and kartboy with front bushings short shifter. The difference is hard to explain but I guess you can say with the kartboy and bushings it's more harsh(more vibrations at the shifter) while the subaru short shifter is less harsh but doesn't throw as short. I believe the harness comes from the bushings and not the shifter directly though. I would try to find someone local who has a kartboy short shifter without urethane bushings, one with the bushings and ask your dealer to test drive an 06 wrx with their short shifter to see if you like it(as I'm sure you'll be hard pressed to find someone who has the subaru short shifter).
#7 |
Thanks Sir Alex!
Moderator Member#: 88606
Vehicle:2011 GMC Sierra 1990 Miata |
The bushings do add some vibration to the shifter...but its not bad. The bushings also remove the squishy, soft feeling that you have with the stock shifter. Its a big difference and worth the extra money.
| Thread Tools | |
| Display Modes | |
| Oem short shifter vs. aftermarket short shift? | SubeN'Siren | Transmission (AT/MT) & Driveline | 5 | 02-17-2008 11:23 AM |
| Greddy shift knob vs OEM wrx shift knob | ASpec818 | Interior & Exterior Modification | 8 | 10-24-2006 05:31 PM |
| Fs: Kartboy 5 Speed Short Shift Rod | D-Rodman | Private 'For Sale' Classifieds | 2 | 04-29-2006 01:53 PM |
| 2002 Legacy Shift Linkage + kartboy VS STi short shift linkage + kart boy | keirnna | Transmission (AT/MT) & Driveline | 5 | 05-27-2005 08:08 PM |
| Anyone compare Kartboy vs. Cobb short throw shifter | Ken S | Technical Forum Archive | 6 | 09-26-2000 09:13 AM |
