Old 03-07-2006, 05:58 PM   #1
DFarris2420
Member#: 88945
Default FWD to AWD
Can you convert FWD to AWD? Is it even worth the hassle?
DFarris2420 is offline   Reply With Quote
Old 03-07-2006, 06:05 PM   #2
moss
Member#: 10197
Yes it can and has been done.
moss is offline   Reply With Quote
Old 03-07-2006, 06:15 PM   #3
DFarris2420
Member#: 88945
Is it expensive?
I am looking to buy an L. Should I just try and find an AWD car and skip all the FWD ones for sale?
Old 03-07-2006, 10:44 PM   #4
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
If you plan to convert... just buy a AWD, if you don't care, get the FWD. The FWD model is quite a bit lighter than the AWD, and has less drivetrain loss. But it's also harder to find parts for.
Harenil is offline   Reply With Quote
Old 03-07-2006, 11:25 PM   #5
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
hard to find parts for? more like if you plan on swapping, then you need to do the AWD swap.
it is possible but youll need a donor car or source all the parts. im starting the swap friday, i have a donor car. only reason im doing it this way is because AWD ones are hard to find and i got my FWD and swapped a motor in before the awd swap so now the tranny/clutch cant handle it.
Natoe is online now   Reply With Quote
Old 03-07-2006, 11:27 PM   #6
spongejosh
Member#: 62783
Midnight Black Pearl
it can be a lot cheaper if you find the parts. case and point:
i bought a fwd auto 93 impreza L for $500.
went to the pull & save junkyard and got the manual tranny, rear diff, rear subframe, diff carrier, rear awd hubs w/disc brakes, clutch, pedal box, rear awd tophats and other misc parts all from a 93 legacy for a whopping $120.
bought a used impreza manual driveshaft and the front knuckle for the legacy rear diff. $100.
awd gas tank $70
there it is. we did the full conversion from auto to manual and fwd to awd for $290 dollars.
the car is already set up for awd. all of the rear mounting holes are there and they are threaded. just pop the plastic caps out and bolt in the whole rear end.
moral of the story is, if you can get the stuff for cheap, it is worth it.
josh
spongejosh is offline   Reply With Quote
Old 03-07-2006, 11:59 PM   #7
moss
Member#: 10197
^ there ya go.
Old 03-08-2006, 12:02 AM   #8
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
awd gas tank $70
josh
genius.
thats an awd, 5speed, odb1 impreza for $790. ready for a nice sti swap.
svek is offline   Reply With Quote
Old 03-08-2006, 12:13 AM   #9
spongejosh
Member#: 62783
actually a hybrid 2.2t swap and a full cage. it's a rally car.
josh
Old 03-08-2006, 12:14 AM   #10
svek
Member#: 82259
1999 impreza 2.2L
that works too
Old 03-08-2006, 12:16 AM   #11
moss
Member#: 10197
Originally Posted by svek
genius.
EJ20G!
Old 03-08-2006, 07:29 AM   #12
DFarris2420
Member#: 88945
Thanks guys!
Old 03-08-2006, 02:12 PM   #13
Natoe
Member#: 90353
true that is the way to go if you can find everything, around here it would take forever for a awd gas tank to show up.... i got a donor car, am taking more than just awd from it and going to part it out.
Old 03-08-2006, 03:23 PM   #14
andys
Member#: 53455
2004 Forester XTI-RR
dark
I think some fwd models have the awd gas tank installed.
You can get a jpm clip with almost all the parts to go FWD auto to AWD 5speed - find.
I bought a FWD auto and did the conversion. The only pain was getting new RS model gas tank to work - and even that was minor.
andys is offline   Reply With Quote
Old 03-09-2006, 01:15 PM   #15
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
My swap is pretty detailed. It'll let ya know what you need to deal with on the electrical side...assuming your obd1
www.surrealmirage.com/subaru/swap
Legacy777 is offline   Reply With Quote
Old 03-11-2006, 04:50 AM   #16
Natoe
Member#: 90353
i had NO idea that they could be the same, my 2 95's (one awd, one fwd) i believe have the same tank, im doing the awd swap right now and realized that... its awesome!
Old 05-23-2006, 09:04 PM   #17
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
okay, suppose you bought a FWD L and an entire wrecked WRX...wouldn't it just be easier to swap the rear end out of the WRX to make the FWD L AWD?
projectrally is offline   Reply With Quote
Old 05-23-2006, 09:15 PM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup...
since your swappuign the tank over you would have all the sensors that you would need to make the ecu happy
Old 05-23-2006, 11:22 PM   #19
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
Jaxx,
I was talking rear diff/axles/hubs/trailing arms, etc. But are you saying that I can swap the tank from a newer WRX into the old L as well? because that would be great....
Want to do FWD to AWD? Drum to Disk? I have the parts keirnna Private 'For Sale' Classifieds 7 08-16-2005 04:39 PM
Anybody in S.D. or local that has a facility to swap my FWD to AWD STi-Nismo Dood Southern California Impreza Club Forum -- SCIC 10 04-09-2003 01:26 AM
FWD to AWD parts question Cliff Brakes, Steering & Suspension 5 06-13-2001 08:13 PM
Need some advice ASAP re: converting FWD to AWD Digital_Boy Technical Forum Archive 2 10-08-2000 04:49 PM
FWD to AWD swap N/A Technical Forum Archive 2 07-04-2000 11:32 PM
