Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 03-07-2006, 07:41 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Ver. 6 RA Gears, ACT, Exedy, Kartboy, Mounts!!!
Hey all,
Our RA gears are out being cryoed but almost all of them are already presold. We have a few sets left that are currently unspoken for. If you've been waiting for these, now is the time to get them!!!
Version 6 STI RA (Special Edition) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- Stronger than stock WRX gears
- 1mm thicker gears
- Cryotreated for added durability
- Replace gears 1-4 (shorter ratios)
- Retains stock 4th and 5th gear ratios
- Better accelleration, same cruising fuel mileage
Version 6 STI RA (Normal) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- 1mm thicker gears
- Replace all gears (shorter ratios)
- Ideal for track
Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
STi Group N Tranny Mounts - 02+ WRX / 04+ STi - $69 Shipped
The STI "Group-N" Transmission Mount is designed to reduce excessive motion of your transmission during shifting and launching. This is done by increasing material stiffness over your stock transmission mount. By decreasing this type of motion, more energy is focused to the drivetrain and chassis rather than spent twisting your transmission. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
STi Group N Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $159 Shipped
The STI "Group-N" Engine and Tranny Mounts are designed to reduce excessive motion of your motor and transmission during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine and tranny mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine and tranny. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
Also, we now carry Kartboy products! Please PM for pricing and combos.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 03-07-2006, 07:44 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We have 1 Exedy Stage 2 3 puck clutch for the STi that need to go now!!! You will not see it at this price again.
Exedy Stage 2 3 Puck Clutch - 04+ STi - $500 shipped
This clutch is designed for both street and track which means that it holds far more torque than your stock clutch but it is still easily driveable.
-Torque Capacity Increase - 47%
-Clamp Load - 2310 lbs.
-Includes Pressure plate, throwout bearing, clutch disc, and pilot bearing
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Twin Plate Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2205 lbs/ft.
4) Exedy Organic Clutch Kit and Steetlite Flywheel - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
5) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
6) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 03-07-2006, 07:44 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 03-14-2006, 10:19 AM   #4
BVM
Member Sales Rating: (11)
Member#: 41049
2010 Impreza WRX
KTM 250sx
Why did you guys stop selling the rebuilt 5 speeds w/ RA gears?
BVM is offline
Old 03-14-2006, 03:14 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Well actually, we pretty much never had those. I'd say we've sold 1-2 of those in the last year. The reason we so rarely had them was because it required a core for us to rebuild. Cores are very hard for us to come by since they have to come off of used or wrecked car. Almost everyone just ended up sending us their tranny to have rebuild or just bought the parts from us and had their tranny rebuilt locally.
Thanks,
Geoff
Gruppe-S is offline
Old 03-14-2006, 06:31 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We also have a 6spd!
6spd. STi Transmission
-USDM Gearing
-Non DCCD (stronger and doesn't require DCCD controller)
-Includes front LSD
-Less than 6000 miles
$3999 + shipping
*Picture is representative of the actual item. Please PM for picture of the actual item.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 03-22-2006, 05:12 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Almost out of RA gears!
Also, we have:
Cusco 1.5 Way Type RS LSD - Rear - 02+ WRX
$945 shipped!
The Cusco limited slip differential is designed to provide maximum traction that is most often lost in hard off-the-line acceleration, these L.S.D. kits are designed to integrate with your factory transmission. The unit will sense when one wheel starts losing traction due to track/road conditions, hard cornering, and/or torque steer. Once it detects the slippage, it will compensate by shuffling the power from side to side to overcome the loss of traction. This translates into better track or quarter mile times, and more efficient use of the engines power.
With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower.
* 1.5 way LSD - Activates under acceleration while the understeer is less than on the 2 way LSD. Recommended for road racing applications.
Thanks,
Geoff
Gruppe-S is offline
Closed Thread
FS: 03 wrx longblock, sti ver 6 RA gears tranny fdrx7 SCIC Private Classifieds 24 12-30-2008 01:51 PM
Drivetrain wise we've got you covered w/ACT, Exedy, Kartboy, STI RA Gears, CCI & More SpeedElement Drivetrain 12 11-18-2008 06:29 PM
Cusco or Exedy Twin Plate($1299)/Exedy HyperS($599)/RA Gears/6speeds/Exedy Kits($549) Gruppe-S Drivetrain 20 05-22-2007 05:09 PM
ACT, Exedy Kartboy and more in stock! Z1 Performance Drivetrain 14 01-31-2007 11:09 AM
ACT, Exedy Kartboy and more in stock! Z1 Performance Drivetrain 0 11-09-2006 03:46 PM
