Old 03-07-2006, 11:21 PM   #1
Rice18
Member#: 98669
2004 WRX
Default Wierd clicking noise at partial throttle
Hi everyone, just wondering if anyone has some insight on this problem I have.
My wrx has 55000 miles on it and is recently Cobb stage 1. Now there is this wierd clicking noise from the driver's side at partial throttle in 1st gear. I've heard that its a sound like the crankshaft is going to walk away? I hope not. Any input?
Thanks
Rice18 is offline   Reply With Quote
Old 03-07-2006, 11:54 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
do you hear this noise when the engine is warm, or cold, or both? Do you have an oil pressure guage? Change your oil and dump it into a clean container. Look for sparkly metalic stuff.
Tim Sanderson is offline   Reply With Quote
Old 03-08-2006, 12:28 AM   #3
Rice18
Member#: 98669
2004 WRX
hmmmm usually when cold. The car runs fine otherwise. Sparkly metal stuff?? Sounds not good...
Old 03-08-2006, 06:59 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
if that happens when it's cold then that is pretty normal.
Old 03-08-2006, 11:45 PM   #5
Rice18
Member#: 98669
2004 WRX
whew. Thats reassuring. I'll probably still get it checked out though. Thanks for the info
Old 03-09-2006, 12:46 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
ya, sorry to leave you hanging on that first reply. That ticking is usually either piston slap or a lazy timing belt tensioner.
Just to be on the safe side you might want to find out what your oil pressure is anyway. And perhaps even have a leakdown test done if you are really concerned.
full boost at partial throttle??? sr_subie Newbies & FAQs 1 05-21-2007 09:08 PM
Wierd Psst noise at full throttle under load dntouch Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 05-11-2006 04:53 PM
wierd clicking noise. 1m4dSTI Brakes, Steering & Suspension 4 03-24-2006 10:34 AM
boost at partial throttle with stock boost controller pbchief2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-12-2003 06:18 PM
How much boost do you make at partial throttle? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-23-2002 06:05 PM
