Old 09-21-2000, 08:16 PM   #1
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post Temp sensor replaced
Contrary to my overzealous local Subaru Master Mechanic's warnings, the temp sensor replacement on my 93 was easly, very easy.
Required are the following:
1 ratchet or means of leverage, 3/8 or 1/2in.
1 18mm deep socket, 3/8 or 1/2in.
1 long extension or 2 short extensions.
1 replacment temp sensor plus washer
1 small strip of teflon tape
3-5 hours of cool down time.
3 minutes of actual work.
It's located almost directly underneat the throttle cables and isnt very hard to get out after you disconnect the plug.
DLC is offline   Reply With Quote
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
L@@KING [email protected]: Lamco Oil Temp Sensor / Probe / Replacement Drain Plug BeBop86 Private 'Wanted' Classifieds 0 05-02-2008 05:43 AM
Replacement of stock oil temp sensor ghschirtz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-08-2006 02:04 PM
93 legacy still starts hard after temp sensor replaced diaper eater Service & Maintenance 10 12-14-2004 02:52 PM
