Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-07-2006, 11:49 PM   #1
Gregmatic
Member#: 57100
2004 Baja Turbo
Black Onyz
Exclamation Rough idle issue solved via TSB sticky!!!
As per the TSB in the 2.5L turbo section I removed the oil feed bajo bolts to the top of the heads and sure as ***** the small oil filter in each side had fallen partially obstructing oil flow. Followed the TSB and can say that it is easily done in less than a half hour. A little finesse and some small tools were able to remove the filters (you'll see what I mean). Rough idle solved, seems to pull smoother to redline. I reset the ECU as well, maybe that also was a factor. HIGHLY recommended as it is an easy fix and there is already one report of these filters disintegrating and ending up in the valvetrain.
Gregmatic is offline   Reply With Quote
2006 Impreza 2.5i Power/rough idle issue subarumafia700 Normally Aspirated Powertrain 3 02-22-2010 07:46 PM
Rough idle on 04 Turbo motors (2.5L) TSB Peaty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 145 03-29-2009 07:50 PM
stalling and rough idling issue nJDMmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-20-2008 11:46 AM
X-post: TSB on rough idling hatake Baja Forum 3 12-26-2005 08:29 AM
help/comments w/rough idle issues? Benjamin Tang Legacy Forum 14 10-01-2003 05:55 AM
