Old 03-08-2006, 12:14 AM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Driving with VF39 on Cobb stage 2.5 map without JDM pinks...
I want to install VF39 this weekend on my 02 WRX, but won't have pinks until two weeks later. Will my car be okay with 2.5 stage map as long as I don't push the car? I will not be boosting the car at all.
Will my car be okay as long as car is not boosted?
gopsu is offline   Reply With Quote
Old 03-08-2006, 07:10 AM   #2
salem
Member#: 56143
Fit is Go
Don't risk it.
salem is offline   Reply With Quote
Old 03-08-2006, 02:26 PM   #3
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Just wait
snwman is offline   Reply With Quote
Old 03-08-2006, 04:32 PM   #4
clamdip
Member#: 18709
driving your car and not boosting it at all is impossible. the low compression ratio that our cars run will make driving a living hell if you don't have any boost. also, no matter what, there's no way that you would be able to travel below 3000rpm and expect to reach anything near 35mph.
clamdip is offline   Reply With Quote
Old 03-08-2006, 10:10 PM   #5
Aerosim Research Ltd
Member#: 45648
GC8 CF 22B widebody
Lancia Stratos Replica
No is your answer. You cannot drive your car with the 2.5 map without pinks. Well, you can but not for long. The Fuel injector scaler is set to meet the pinks. The stock fuel scaler is 6442 according to the accessTuner Stage 1 map. The Stage 2.5 map scaler is 5120. The higher the scaler, the richer it runs. So in this case, your making your stock injectors inject less gas than stock settings with a much bigger turbo. Even if your not boosting, your will be running dangerously lean as your are crusing on the highway.
Just wait.
-Peter
Aerosim Research Ltd is offline   Reply With Quote
Old 03-08-2006, 10:21 PM   #6
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Not a snowman's chance in hell. Your engine wont make it two weeks! Dont even attempt it.
dexterous is offline   Reply With Quote
Old 03-09-2006, 05:22 PM   #7
gopsu
Member#: 96448
02 WRX VF34
what if you run it on cobb stage 2 map and boost is kept minimal?
Old 03-09-2006, 05:37 PM   #8
SketchINoc
Member#: 87370
2005 WRX,Soon to be
EVO9-94 toyota4x4 project
the anwer is NO, just wait for the pinks!
SketchINoc is offline   Reply With Quote
Old 03-09-2006, 05:37 PM   #9
MPREZD
Member#: 50596
04 wrx breakin
necks in JBP sucka!
dont do it!!! its never a good thing to rush things!!! just wait!
MPREZD is offline   Reply With Quote
Old 03-09-2006, 06:00 PM   #10
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
I am going to go agains the grain and say you can do it as anything is possible but it's again NOT recomended.
If you can't resist
I would return the AP to stock, install the turbo stay out of boost, under 3000 rpm should be more than fine. ( I can't imagine an engine letting go so low). The stock map sould be rich enough to supply till 3000rpm zero boost. At zero boost, no vac. or positive preasure my car scoots at 4500ft elevation.
Repeat, NOT recomended, If you can't resist, I feel this is the safest bet. I would probably do this a day or two before injectors because my back is tweck and can't work for long myself.
desert pirate is offline   Reply With Quote
Old 03-09-2006, 06:32 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no no no
even waste gate fueling will be off as the 2.5 map is looking for an injector 25% larger than what is present
do it all at once ..changing the turbo is less time consuming than changing the injectors any way
Old 03-09-2006, 10:49 PM   #12
gopsu
Member#: 96448
02 WRX VF34
Thanks for the advice guys! Much appreciated.
Old 03-09-2006, 11:37 PM   #13
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Patience my son.
ADR 04STi is offline   Reply With Quote
Old 07-26-2006, 01:49 PM   #14
DaBoxerman
Member#: 79019
where do you get the 2.5 map from? Is the 2.5 map specifically for the WRX with a VF39?
DaBoxerman is offline   Reply With Quote
Old 07-26-2006, 05:24 PM   #15
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Assassin4457 is offline   Reply With Quote
Old 08-01-2006, 09:54 PM   #16
Vince126
Member#: 91712
2006 Evolution IX
Wicked White
the 06s have a vf39 map, 02-05 doesnt. but there are numerous people running vf34 map on the 02-05s and have reported to hit target boost with 0 problems.
Vince126 is offline   Reply With Quote
Old 08-01-2006, 10:50 PM   #17
hondaeater69
Member#: 60324
IF you run WG boost on the 39 (~12psi) you will be moving less or about the same air than full boost on the TD04 in my estimation, so it's not the holy bejesus your engine won't last a week everyone makes it out to be. If i really had to do it, i would. Run the stage 1 map due to WGDC changes in the stage 2 map. I would of course be monitoring AFR's, knock, and timing too though
to achieve WG boost run a hose from the compressor directly to the WG bypassing the OEM BCS.
also be sure to inspect your 39 for cracks prior to install, there are some out there not holding up too well.
Cobb stage 2.5 map - reliability gopsu AccessPort 8 04-09-2006 08:38 PM
Anyone with OTS Cobb stage 2.5 map driving with VF34 and header? txl146 AccessPort 2 03-19-2006 11:34 AM
IDC's with Cobb Stage 2.5, VF34 and STi pinks Farnsrocket AccessPort 0 02-13-2006 03:54 PM
looking for Cobb stage 2.5 map swift2fly Engine Management & Tuning 2 05-11-2005 12:12 PM
Cobb stage 2.5 map with VF30 install WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2004 05:02 PM
