Old 09-20-2000, 11:24 AM   #1
webaddict
Member#: 1860
Post MY00 AT Transmission ?
I got my tranny fluid changed yesterday at Jiffy. Ya I know, stupid, but I don't like ignoring fluid changes. They put in 3.5 quarts but the manual says the tranny takes 9+ quarts, and the dip stick says full. Why the difference? Torque converter maybe. And what if I choose to go synthetic, how does one go about removing all of the fluid?
webaddict is offline   Reply With Quote
Old 09-21-2000, 12:18 AM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
The trans does indeed take 9+ quarts, as 2/3 of it cannot be gravity drained or even siphoned. The only way to get it all is to use a machine that connects to the cooling lines and flush fluid throughout. This requires one full 9+ quart flush plus another one with brand new fluid.
With Synthetic it can be expensive but should be doable.
DLC is offline   Reply With Quote
Old 09-21-2000, 10:48 AM   #3
webaddict
Member#: 1860
Post
Thanx for your response. I'm wondering if this "partial fluid change" is good enough? I suppose the only proper way to change the fluid is to take it to the dealer and have them pump the entire 9+ quarts.
Old 09-22-2000, 12:27 AM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Well since the manual probably recommends changing it every 39k miles, a partial drain is probably all they do.
I would call and ask them about what they normally do and if they offer a full flush.
Otherwise, you're at least replacing some of the fluid and getting the heavy stuff out so it did do some good.
AT Transmission making a whisling sound NEED HELP!! linemup Newbies & FAQs 4 08-01-2004 01:19 AM
AT Transmission Probems - Grinding AcIdRoX Transmission (AT/MT) & Driveline 6 09-10-2002 01:51 PM
AT transmission shift boot 128d Interior & Exterior Modification 2 06-09-2002 12:32 PM
trashed MY00 at Blackgold Imports schlong8 Canada Region Forum 5 11-23-2001 03:13 PM
MY00 Manual Transmission can be FWD? NickCat Technical Forum Archive 12 07-19-2000 12:27 AM
