Old 03-08-2006, 05:16 PM   #1
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Default jdm v7 heads vs cosworth heads
Debating if it's worth it. Cosworth gave me these flow numbers:
Intake ports:
Cosworth-368 CFMs
05 JDM Sti Spec-C-337 CFMs
USDM sti-316 CFMs
Exhaust ports:
Cosworth-304 CFMs
05 JDM Sti Spec-c-255 CFMs
USDM Sti-235 CFMs
Dog leg::
Cosworth-287 CFMs
05 JDM Sti Spec-c-221 CFMs
USDM Sti-210 CFMs
Looking at both heads, the JDM head ports look larger. Wondering if I would be able to benefit from the cosworth heads. For me to put them on my 2.0, I would have to modify the cosworth heads which I'm not looking forward to. Heads going on a jdm ver7 block with mahle pistons, pauter rods, balanced and micropolished crank. AVCS 272 cams and a gt30r turbo or gt35r turbo. Car is mostly setup for road racing. Cost difference for me is around 1000 over using the JDM heads. Any recommendations? Thanks
petawabit is offline   Reply With Quote
Old 03-08-2006, 05:30 PM   #2
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
My recommendation is to have a good "pocket port" and valve job done, and let 'er eat
Cosworth's reputation notwithstanding, I'd wager there are a few folks out there (besides myself) that would make statements such as:
"Huh?"
"Can't see it."
"Not at 28""
and
"What flow bench are they using, and how is it set up?"
I for one, find it hard to believe that ANY Subaru EJ head would flow 368 cfm....period.
For those that would debate it, I'll take wagers. Seriously. Take the cross sectional measurements, curtain area, etc..... I'll plug the numbers into software (that works), and publish the results. Otherwise, I'm calling B.S.
S.
Intake ports:
Cosworth-368 CFMs
USDM sti-316 CFMs
Exhaust ports:
Cosworth-304 CFMs
USDM Sti-235 CFMs
Dog leg::
Cosworth-287 CFMs
USDM Sti-210 CFMs
n2xlr8n is offline   Reply With Quote
Old 03-08-2006, 05:33 PM   #3
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
"Huh?"
"Can't see it."
"Not at 28""
and
S.
Thanks for the insight. I'll try to find out how their flowbench is set up
Old 03-08-2006, 08:25 PM   #4
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
There bench readings are NOT from 28", if im not mistaken its 50" or 51". There reasoning is by flowing more air through, smaller flaws will show up making them be able to create a better flowing head. To what ever extent that is, i don't know.
Burnout is offline   Reply With Quote
Old 03-09-2006, 09:13 AM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I'll say this, then I'm finished (for now)
If Chapman can't get Trey Cobb a "good" CNC program for his heads, then I'd seriously doubt that Cosworth found something noone else did....Larger valves aren't going to do it.
Ask if it's flowed with the stock intake manifold attached.
S.
Old 03-09-2006, 11:58 AM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Data from my V7 Large Ported heads. Yes they are the large port version. It's easy to see the difference by just looking at the ports.
Flow at 28" water
Stock they flowed at .400" lift 262cfm intake and 188cfm exhaust
At .400" lift after porting, they flowed 297cfm intake and 243cfm exhaust
mick_the_ginge is offline   Reply With Quote
Old 03-11-2006, 01:48 PM   #7
keaniegenie
Member#: 94494
2005 Element 92x
Are you considering the heads?
I've always wondered how p&p'd USDM STI heads would flow vs. Ver. 7 JDM heads.
Anybody have experience with either or both?
keaniegenie is offline   Reply With Quote
Old 03-11-2006, 02:51 PM   #8
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Yeah, but thinking it might be too much work since I would need to get new pistons and maybe new cams since I have the jdm sti cams and may have to get the US sti cams. The jdm ports look much larger so I wondering if anyone has had any experience with them or if they thought if it was worth the price difference
Old 03-11-2006, 09:30 PM   #9
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
what's that all about?
MeetMrGlock is offline   Reply With Quote
Old 03-12-2006, 01:48 AM   #10
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Chapman does a portion, if not all of Cobb's CNC porting....but I'd expect you knew that
I'd bet they don't advertise 368 cfm out of a stock casting.
Granted, Chapman's work recently has not been on par with that of the past, but it's still considerably better than most, IMO.
S.
Old 03-12-2006, 02:05 AM   #11
hotrod
Member#: 14141
2002 Impreza WRX
Yes definitely ask them what the depression was those numbers numbers were developed on. Flows scale with the pressure so if we know their flow numbers we can convert to industry standard.
Also verify if those numbers are with a valve installed or just the bare head.
Flow numbers without valve lift / diameter and style of valve, info is pretty useless for comparisons purposes.
You should not buy heads based on peak flow, you should have a hard look at the midrange flow numbers because that is where the valve spends most of its time.
Larry
hotrod is offline   Reply With Quote
Old 03-13-2006, 09:57 AM   #12
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
FWIW....they don't think so, either.
It seems if Cosworth told you 368 cfm, they are doing some creative marketing
S.
Old 03-13-2006, 03:16 PM   #13
02Toyowrx
Member#: 56520
n2xlr8n How do you figure chapmans work being not on par? They port and fully machine the factory dodge viper heads, ALOT of the Edlebrock heads, and the factory GM performance ecotec heads. They did all the R&D for these projects and offer a superior product that isnt good in your eyes? Could you name someone better or equal?
02Toyowrx is offline   Reply With Quote
Old 03-13-2006, 04:03 PM   #14
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I'm not going to debate this in this thread, as this is off-topic. If you'd like to discuss specific examples, PM me, and I'll give you several.
In response to your question:
There is nothing "wrong" with Chapman's work, as they have ported heads I've owned in the past, and I think other than the folks that are "unreachable" in the business, they could do my heads again. I was simply stating that based on observations of their recent R&D (esp on GM performance heads), they left alot of room for the detail work. There are different levels of "satisfaction", I suppose.
S.
Old 03-18-2006, 06:31 PM   #15
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
saw the cosworth heads in person and the ports looked a lot smaller than what I expected. I also remember people making observations that the port lengths are different between the JDM and USDM heads. Still haven't talked to cosworth yet:-(
Old 08-10-2006, 01:09 PM   #16
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I have a superflow flowbench with all the port analyzing software and pitot tubes if someone wants to send them out...I'm interested too...I'd like to flow EJ205, ver 7, ver 7 spec c, ver 8-9 (standard big port), ver8-9 spec c and usdm sti heads...see what they do from the factory...then I'd like to run all the race heads too, axis, cobb, cosworth...
I'd run them in given lift increments with the valves still installed...that way we can see the usable flow and flow in relation to a give cam profile (what you will really see with a head, valve and a given cam...)
Old 08-13-2006, 03:23 AM   #17
D_Sagan
Member#: 22902
2005 STI
CGM
omg! - YES please! This could actually be the most information we've gotten from an unbiased 3rd party.
You don't work for Cosworth do you .
Nasa huh?
D_Sagan is offline   Reply With Quote
Old 08-13-2006, 03:30 AM   #18
Homemade WRX
Member#: 33782
96 bastard child
well, I work for NASA via my school and an internship...one of two poor undergrads there...anyhow, I do design work and am basically the TA/run the labs for the motorsports engineering minor available at the school. This includes the IC engines course!! this gives me access to the flowbench, land and sea dyno, shock dyno, scale pads and all kinds of other fun things
my job has perks but is boring as crap...
Old 08-14-2006, 11:54 PM   #19
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
HOly crap, subscribe! Make it happen!
eclip5e is offline   Reply With Quote
Old 08-15-2006, 12:03 AM   #20
silentbob343
Member#: 57307
I agree, I would love to see it happen.
silentbob343 is offline   Reply With Quote
Old 08-15-2006, 12:39 AM   #21
Homemade WRX
Member#: 33782
96 bastard child
well, I will surely flow a stock wrx head and a usdm sti head when my car and our shop sti get torn down...
if I can get the big port sti head I want (ver8 or ver7 spec c) that will get flowed too...other than those, they will have to be sent out if they want to get flowed.
-Micah
Old 08-15-2006, 02:19 AM   #22
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
I'm definitely interested too as the motor for my new project was going to to be a full tilt EJ22 closed deck with Cosworth heads at a rotated GT40r, whereas now i'm looking at just buying the full v7 Spec C clip and having it shipped over and using that as a starting point.
QuikWgn is offline   Reply With Quote
Old 08-15-2006, 05:36 AM   #23
subabusa
Member#: 89600
I do it also.I used crawford block and cosworth head with cams.but I have a big problem..
I can not install EJ25 USDM AVCS cam shaft sensor to JDM ECU .They are different .One of has three pins but the cables to go to ECU has two pins.
I opened new topic for this reason but I wrote here again.
subabusa is offline   Reply With Quote
Old 09-05-2006, 07:26 PM   #24
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Intake ports:
Cosworth-368 CFMs
USDM sti-316 CFMs
Exhaust ports:
Cosworth-304 CFMs
USDM Sti-235 CFMs
Dog leg::
Cosworth-287 CFMs
USDM Sti-210 CFMs
What did you end up going w/?
DoctorNick is offline   Reply With Quote
Old 09-09-2006, 06:44 AM   #25
nomorem3
Member#: 73469
2005 STi - Black
2002 540i - Black
Intake ports:
Cosworth-368 CFMs
USDM sti-316 CFMs
Exhaust ports:
Cosworth-304 CFMs
USDM Sti-235 CFMs
Dog leg::
Cosworth-287 CFMs
USDM Sti-210 CFMs
I just posted up a thread asking just this!! haha...
The numbers seem to add up to Cosworth's claims of 15% increase in Intake Port Flow & 31% increase in Exhaust Port Flow.
nomorem3 is offline   Reply With Quote
ENGINE PARTOUT: JDM V7 RA-C EJ207 heads, Tomei cams/turbo, exhaust, FMIC, much more zeropsi Engine/Power/Exhaust 27 12-20-2009 12:54 PM
EJ207 big port vs. Cosworth Heads question Fierysun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-21-2009 06:29 PM
JDM v7 wheel vs GC8 vs Tire size??? OB2 Tire & Wheel 5 03-03-2006 12:29 AM
WTB: JDM V7 or V8 Bare Heads WhiteKnight Private 'Wanted' Classifieds 1 02-14-2006 11:29 PM
JDM Sti Head vs. wrx head M3GTR Subaru Conversions 14 03-07-2005 07:16 PM
