Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 03-08-2006, 11:39 PM   #1
BrandonWRX
Member#: 42177
2005 STi
Default Protune map only boosting 15 psi
I got dyno tuned and everything was really strong, 317 awhp and boosting 18.5 psi solid. Now after a couple days I can only get 15 psi and it rises very slowly. My mods are ngk 1 step colder plugs, short ram, turboback, and FMIC. Would a leak before the turbo cause this (my EGT gauge is acting funny, dropping up and down at random times)? Or is is low rising boost and only 15 psi from a boost leak from somewhere?
BrandonWRX is offline   Reply With Quote
Old 03-09-2006, 09:59 AM   #2
-Kevlar-
Member#: 82378
you dont really need the step colder plugs. dont know if that would help... ive seen more problems in the last couple days.
-Kevlar- is offline   Reply With Quote
Old 03-09-2006, 12:17 PM   #3
tuskenraider
Member#: 65699
15 WRX
WR Blue
Certainly sounds like a leak based on your symptoms. Time to retighten and/or refit all your applicable hoses.
tuskenraider is offline   Reply With Quote
Old 03-12-2006, 10:22 AM   #4
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
FMIC with the stock turbo?
Has the temperature changed?
elevation change?
what gear are you seeign the low boost in?
scoobdude is offline   Reply With Quote
Old 03-26-2006, 01:28 PM   #5
BrandonWRX
Member#: 42177
2005 STi
Dont knock it, I picked up an extra 40 whp and 50 wtq from the tune
The strange thing is itll be ok, hitting boost targets, shortly after I start up (warming up of course). After ive been driving a while it doesnt boost as strong. Im thinking perhaps the FMIC causes the radiator to be more inefficient due to less air and the car runs hotter so it pulls timing/boost to prevent detonation.
Old 03-26-2006, 03:23 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I know in street tuner there is a map for wastegate and boost comp depending on temp or altitude. maybe this map has been altered?
only reaching 15 psi jaspittman Engine Management & Tuning 6 04-14-2010 10:32 PM
Stage 2 Protune 15 PSI? justin24 AccessPort 2 06-23-2009 11:39 PM
Why only boosting 7 psi? PlanNnWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-03-2008 01:22 PM
Only boosting 8 PSI max? Andrew06WRX Newbies & FAQs 5 09-10-2008 12:04 AM
WRX only boosting 7 psi......help, please nottheliving Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-13-2004 10:35 PM
