Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-09-2006, 03:47 AM   #1
ncarn8
Member#: 71419
Default water cooled turbo w/no water
here is a question - hiow long will a td05-h last if you dont connect the wqater pipe instead you bypass the turbo with a hose from water pump to the return on the rear of the head.
Just seeing what opinions you guys have.
ncarn8 is offline   Reply With Quote
Old 03-09-2006, 07:23 AM   #2
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
I wouldn't, what's the point?
Plus doesn't the car cycle coolant throught the turbo when it is off hence the reason we don't have/need a turbo timer?
Farnsrocket is offline   Reply With Quote
Old 03-09-2006, 11:42 PM   #3
ncarn8
Member#: 71419
yeah thats what i thought as well. Until recently i was edumacated to another way of looking at it and i saw conclusive proof that a 330 hp STI had run several thousand miles with no water cooling on the TD05-H. End result was a much cooler running engine, and less thermal stress all round.
Old 03-10-2006, 01:09 AM   #4
BGPunk2001
Member#: 46134
yeah well im sure the engine was ok, but what about the turbo??? Im sure it wouldnt last as long. also, you are still heating the oil that runs through, and that will be hotter since it will be the only thing cooling the turbo. If im wrong, correct me, cause this is just an educated guess.
BGPunk2001 is offline   Reply With Quote
Old 03-10-2006, 07:32 AM   #5
Farnsrocket
Member#: 83567
08 Outback
Yep, I can see both of your points. True the car was maybe cooler without the coolant lines but that oil is probably getting way more stressed in the hotter turbo........I would say its probably better to run the coolant lines. Again, just my edumacated guess also.
Would be interesting to see the oil temp coming out of the turbo with and without the coolant lines, the overall temp of engine with and without and the temp of the turbo itself with and without the lines.
Old 03-10-2006, 07:37 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you cool it down properly to prevent cooking the bearings it will last as long as it would have with water cooling.
Water cooled turbo options import111 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-06-2005 10:48 PM
non water cooled turbo/water distribution housing attitude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 01-26-2005 06:02 PM
Water cooled turbo ? subaru.ca Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-04-2005 08:20 AM
Oil or water cooled turbo upgrade... maestro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-16-2004 09:24 PM
Air cooled turbo vs Water cooled turbo. Which is better? lo0pback Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-10-2001 12:29 AM
