Old 03-12-2006, 10:11 PM   #1
GotHP?
Member#: 51138
2015 LE STI
Default Still not clear which map is controlling...
I have a base map with lower boost limits (stock), and a realtime map with a peak of 18.5 psi. When I look at a 4th gear WOT log I'm hitting a lower boost than before when I had a higher boost in my basemap. So is the basemap controlling things, the real time, or some combination??
Thanks...
GotHP? is offline   Reply With Quote
Old 03-12-2006, 11:04 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The Realtime map controls realtime properties. The thing is, a basemap INCLUDES its own realtime map as part of it. If your other realtime map isn't loaded, the basemap's own realtime mapping will be in affect.
Realize though that simply adjusting the Boost Target values will NOT have much affect on the boost numbers you hit. You have to also adjust wastegate duty cycles to go along with it.
nhluhr is offline   Reply With Quote
Old 03-12-2006, 11:26 PM   #3
GotHP?
Member#: 51138
2015 LE STI
I was just being short with the example of the boost map, other maps were changed too including WDC.
So the way you explained it, my realtime map should be controlling things over the basemap? That doesn't quite seem to be the case, and I recall reading that Cobb suggests you run the same map as base and realtime. Is the point of the base then just in case of a reset (defaults to that)? Otherwise the realtime is always controlling.
Thanks!
Old 03-13-2006, 06:08 PM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
If you LOAD the realtime map while you are online, it will be in control, but only of the realtime properties.
Are we talking about AP or StreetTuner?
Rear Control Arm Bushings. Which side is which? cybin Brakes, Steering & Suspension 2 09-05-2006 11:21 PM
Whiteline FSB does not clear control arm Need Speed Brakes, Steering & Suspension 64 06-28-2005 11:21 PM
Can you run a "blank" UTEC map over an EcuTek reflash, in which the reflash controls? scooterforever Engine Management & Tuning 42 05-04-2005 11:27 PM
whiteline springs... blue and silver. which color is which? controls or flat outs? legacy2003 Brakes, Steering & Suspension 3 01-06-2005 08:32 AM
('93-'01) Which engine is better? the 1998 DOHC for RS, or the new SOHC with MAP. d-dvr Impreza Forum 4 01-16-2003 01:09 PM
