Old 03-09-2006, 11:05 AM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Installing TurboXS Knock Light??
For all you guys that have this..anyone have specific instructions on how to install this? I am not sure about how to wire it. Thanks in advance
ScoobySnacker is offline   Reply With Quote
Old 03-09-2006, 11:54 AM   #2
Zumble
Member#: 34860
2005 Forester CGM
See if this helps you.
http://forums.nasioc.com/forums/showthread.php?t=835193
Zumble is offline   Reply With Quote
Old 03-09-2006, 11:55 AM   #3
ScoobySnacker
Member#: 105303
2003 WRX
Thanks, but i've already looked in there...didnt say anything about the install
Old 03-09-2006, 12:39 PM   #4
juste_frank
Member#: 109265
2006 WRX sleeved
built engine
I'm in the same situation here... If you find how to install let me know
juste_frank is offline   Reply With Quote
Old 03-09-2006, 12:54 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
But, the knocklite comes with instructions on how to install it. You just need ground, 12v, tap the RPM signal at the ECU and tap the knock signal at the ECU. There are more details on the install in the above thread if you look through it.
12v you can get from the cigarette lighter, ground is any body ground. You just need to find out which wire is the RPM signal and knock signal from your ECU.
TurboXS knock light, review and discussion PDXTuning UTEC 185 08-19-2013 06:03 PM
FS: TurboXS Knock Light (Knocklite) cowtown Engine/Power/Exhaust 3 02-05-2009 07:20 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 10:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 04:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 01:11 AM
