Old 03-09-2006, 11:19 AM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default Correct Spark Plug for AI/WI?
Is it better to go with a cooler plug when running WI/AI? Or best to go with the stock heat range?
bcblues is offline   Reply With Quote
Old 03-09-2006, 11:21 AM   #2
scooby24
Member#: 56414
2004 Forester XT 5MT
I went one step colder on mine and didn't have any issues. WI is pulling more heat out by itself so theoretically you should be able to go UP a heat range...but there's no need to.
Honestly I'd stick with stock heat range.
scooby24 is offline   Reply With Quote
Old 03-09-2006, 11:28 AM   #3
bcblues
Member#: 17256
04 STi
That may be best for me. I live in the frigid tundra of America's Outback, where you can see your breath most of the year No, seriously, here in North Dakota, it gets WICKED cold in the winter (at times 30 degrees below zero - F), but it also gets WICKED hot in the summer (100+). With the WI/AI, I would think that you are already pulling out a bunch of heat, and that stock heat range would probably work best, at least with my stock turbo setup).
Old 03-09-2006, 12:19 PM   #4
Ultimate Collision Center
Member#: 69072
Stock or one step colder, usually stock will be fine
Ultimate Collision Center is offline   Reply With Quote
Old 03-09-2006, 12:36 PM   #5
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
What do you guys gap your plugs at? I dropped mine down to 35
japslapr is offline   Reply With Quote
Old 03-11-2006, 01:58 PM   #6
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
Down to 35? Or did you mean down to 0.025"?
Stock plug gap is 0.028-0.030" which is where mine is still.
Blennophobic is offline   Reply With Quote
Old 03-14-2006, 06:09 PM   #7
japslapr
Member#: 100150
02 V9 STi 6spd
damn... plugs on my Grand Prix were at .055. Dropped them down .035 for the spray.
Old 05-30-2006, 10:56 AM   #8
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Bumping a slightly old thread. Does anyone else have any opinions on this? If I have roughly a stage 2 setup on an STi and I go to a 50/50 mix, is there benefit to one step colder plugs?
offset
offset is offline   Reply With Quote
Old 05-30-2006, 11:56 PM   #9
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
in my expirence, i have had to gap mine down a hair, next time they come out, i will gap to .023 ish, and these are one step colder iridiums.
the denser the charge in the cylinder (the more boost, fuel, and alky) there is you either need to retard timing, or shorten the plug gap, otherwise the spark will not be able to jump the gap and you will 'blow out the spark.'
saying that you're blowing out the spark is not correct, as the spark does not even jump, the mixture is too dense and thus offers too much electrical resistance for the spark to jump the gap, to correct this yiou either need to narrow the gap or run a higher energy ignition (more voltage) since it's not cost effective to get a higher energy to our ignition systems, the answer is to run a narrower gap.
banzai is offline   Reply With Quote
Old 08-17-2007, 01:23 AM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
bump!!
djerickd is offline   Reply With Quote
Old 08-19-2007, 10:25 PM   #11
Member#: 69072
it really depends on a lot of variables, most people get away with just one step colder but others have to also gap them down a bit...
Is this the correct spark plug? Fierysun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-27-2009 10:23 PM
Correct spark plug part #???? Cant for the life of me find it. Davenow Service & Maintenance 8 10-18-2008 06:32 AM
TXS Hyperflow TMIC TAPPED FOR AI/WI Kreeger Private 'For Sale' Classifieds 13 02-25-2006 11:04 PM
Are these the correct spark plugs for the wrx? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-22-2003 06:48 PM
Correct NGK plug for 99RS Warp3 Normally Aspirated Powertrain 4 12-22-2000 05:31 AM
