Old 03-09-2006, 04:06 PM   #1
innova
Member#: 97472
2005 PDX STi
Aspen White 12.7@110 woot
Talking STi tuning EXPERTS... I need your opinion (PDX tune)
I have a 2005 STi with a 3" catless turboback and a PDX semi-custom tune over a Cobb Stg2 setup.
It runs great! A solid 19psi in 4th and up and is very smooth. Night and day over stock and a good improvement over Cobb's Stg2 OTS map.
I have emailed/called PDX and they have only responded to my question once.
I asked if putting a K&N Typhoon short ram intake would be harmfull to my car's performance (being my primary concern).
They gave me the very vague answer "It will work ""Okay"" with the Typhoon".
What the hell does that mean?
I've seen some good improvements with the KN intake on a stock setup. I'm wondering if it will do the same on my setup.
Thanks!
innova is offline   Reply With Quote
Old 03-09-2006, 04:14 PM   #2
edmundu
Member#: 54672
Well, if it is similar to their LGT version, then you would be best advised to leave it off until you get tuned for it. On LGT's it has been proven via datalogging to lean out the afr's, by under reporting actual maf flow. On a stocker, that is rich, you can get by, but on a tuned stg2, you have already pulled some fuel out, so further leaning the afr could be bad news.
edmundu is offline   Reply With Quote
Old 03-09-2006, 04:36 PM   #3
drwrx
Member#: 50891
I watched a test done with the K&N Typhoon Intake.
Step 1: Run stock STi w/ stock intake on Dyno (dynojet) record whp/torque and AFRs (238/242 w/ AFRs at right around 10.5 to 1)
Step 2: Install K&N Typhoon Intake while car is still on dyno.
Step 3: Run STi on Dyno again record whp/torque and AFRs (250/251 w/ virtually no change in AFRs across the run 10.5 to 1)
There you have it: +12 whp & +9 ftlbs gain, with no change in AFRs and no tune!
I was there, I saw it!
This test was not done by K&N, it was just a guy who wanted to know if it really did what they claimed, and it did.
drwrx is offline   Reply With Quote
Old 03-09-2006, 04:40 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Wow, that sooo looks like evidence to me.
Sorry about the attitude but im getting frustrated with this topic.
Every car reacts differently, you would need to datalog the car to know for sure how an intake system is responding to the tune. Also, "it will work" is a relative term that is open to interperatation.
The car will more than likely be safe (Thanks to the stock ECU's ability), but you just wont know without datalogging it somehow.
parker/slc/gc8fan is offline   Reply With Quote
Old 03-09-2006, 05:19 PM   #5
innova
Member#: 97472
2005 PDX STi
Assuming that this will lean things out a bit.... is it also safe to assume it will be putting down a bit more power with the typhoon?
Old 03-10-2006, 12:28 PM   #6
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
The problem with intakes is they require the tune to allow for changes. If you are already running the optimum timing and fueling putting on an intake could alter your tune in such a way that you loose power. The map you are running is designed for a stock intake. What we have seen is the K&N is pretty good, but it is different than stock. You can probably get away with running the new intake if you really want, but the map you have is not designed for it. Our recommendation is to leave the stock intake on the car and enjoy the quality of the tune you have. If a car make more power with a new part on it something must be changing. Either the timing, the AFR, the boost level, or the efficiency. We have seen that the K&N does not have a huge effect on AFRs, but it does have some. That same AFR change is tied into additional timing. If you run an intake you should have a map that matches it. At stage 2 fully tuned we do not see large gains from running an aftermarket intake.
Jarrad
PDXTuning is offline   Reply With Quote
Old 03-10-2006, 07:10 PM   #7
innova
Member#: 97472
2005 PDX STi
Thank you Jarrad!
No intake for me!
Engine experts - need your opinion Rick Schu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-12-2005 08:25 PM
UTEC road tuning experts, I need your help. StiDreams Engine Management & Tuning 5 06-12-2004 01:08 AM
all 1/4 mile experts i need ur opinions please! scoobyjew Proven Power Bragging 19 07-06-2003 11:25 PM
Need your opinion! STI HIDs w/o foglight covers? AmirWRX Bay Area Impreza Club Forum -- BAIC 3 12-20-2002 02:57 PM
sway bar expert- need your opinion TerenceT Brakes, Steering & Suspension 17 04-04-2002 12:12 PM
