Old 03-09-2006, 04:43 PM   #1
entropy138
Member#: 87446
2005 STI
3 second start club
Default SMC users, anyone with a FMIC?
I was curious if anyone with the SMC kit is running a FMIC and where they mounted their nozzle?
I know its designed nicely to work with the tmic and thats how I plan to use it for awhile... Just thinking about down the road when I want to switch to a FMIC...
entropy138 is offline   Reply With Quote
Old 03-09-2006, 04:54 PM   #2
Ultimate Collision Center
Member#: 69072
Mount it close to the TB, just as you would with a TMIC. On my EVO it is mount about 6 inches away from TB.
Ultimate Collision Center is offline   Reply With Quote
Old 03-09-2006, 05:53 PM   #3
scooby24
Member#: 56414
2004 Forester XT 5MT
yup, 6 inches from the throttle body. That's where we mounted my buddy's.
You want atomization without complete evaporation...otherwise all you have is really humid air getting sucked in. ;-)
You want full evaporation to take place inside the cylinder...that's where heat goes kapoot.
scooby24 is offline   Reply With Quote
Old 03-10-2006, 10:07 AM   #4
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
I will be running it on my Turbo XS FMIC, I will probably mount it 6-7 inches from the TB
wrxraaca is offline   Reply With Quote
Old 03-10-2006, 07:35 PM   #5
Davenow
Member#: 23676
I know a couple gusy with SMC and a front mount, they all have their nozzles about 3-5 inches from the tb in the FMIC pipe.
Old 03-10-2006, 07:57 PM   #6
scoobie1
Member#: 41559
2007 Brocoma
I have the TXS FMIC and I already had the nozzle mounted in a TB/IC coupler from when I had my WRX. I was able to use it with the FMIC, the nozzle is about 1 inch from the TB.
scoobie1 is offline   Reply With Quote
Old 03-10-2006, 11:33 PM   #7
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
How did you get it to seal w/ the silicone...I would do that just so If i ever sell my IC I dont have to buy a new pipe, or sell it w/ the injector in there...but I have heard of putting it in the silicone coupler, but it leaks boost
Old 03-10-2006, 11:38 PM   #8
scoobie1
Member#: 41559
2007 Brocoma
I've been running it in the coupler for over a year now with no boost leaks. I drilled a hole just slightly smaller than the nozzle, put a washer on the inside and outside of the coupler, ran a very thin bead of gasket sealer in there, then screwed in the nozzle from the inside of the coupler. Never had any issues with it at all.
Old 03-15-2006, 02:47 PM   #9
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I have the Perrin kit. The nozzel is directly across from the BOV bung which is about 4-5 inches from the throttle body. TurboXS FMIC users have better clearance because their hot pipe runs near the firewall. However Perrin FMIC like myself have hot pipes that run directly under where the cold pipe bends to go into the TB. Be very careful and make sure you have clearance. Metal on metal rubbing will pop a hole in no time
CoolRex is offline   Reply With Quote
Old 03-15-2006, 02:54 PM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
ensure the BOV is well before the spray, unburned alcohol in the engine bay is not ideal.
Aquamist is offline   Reply With Quote
Old 03-15-2006, 10:35 PM   #11
beavis820
Member#: 44572
2005 STi
Built and Ported
this is where mine is, a few inches before the tb and under the pipe
and with my old setup with a perrin fmic
beavis820 is offline   Reply With Quote
Contact Users, anyone with Bad Astigmatism?? mikescar Off-Topic 14 07-28-2009 03:00 AM
Question for anyone with a FMIC... Project Rex STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-06-2005 07:44 PM
Anyone with a FMIC on a stock turbo (STI) FAST CO STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 07-28-2004 10:28 AM
Anyone with a FMIC want to sell there stock TMIC? TwinTurbo Bay Area Impreza Club Forum -- BAIC 1 05-05-2002 10:50 PM
anyone with a fmic on a legacy??? subyspeed2 Legacy Forum 4 04-25-2002 08:58 AM
