Old 03-09-2006, 06:27 PM   #1
Travis Graham
Member#: 108191
2002 Impreza WRX
Cold Weather Fire Proof!!
Default I need a CEL code identified
If anyone can help me I got the code pulled off of my car. The code that came up was, "P1443 Mfr Controled Aux Emiss Cntrls" That's exactly what the scanner brought up. If anyone could help me out and tell me what this might be I would greatly appreciate it.
I'm also the same guy with the WRX that has a knock.
Travis Graham is offline   Reply With Quote
Old 03-09-2006, 07:21 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
the manual says that it indicates that the evaporative emissions systems vent control function is somehow faulty - it recommends first checking the vent line hoses - specifically, clogging of the vent hose between the charcoal canister and the drain valve, the one between the drain valve and the air filter, and to check the drain filter to make sure it's not clogged. The next step is to check the drain valve itself to see if it operates properly - it says you turn the ignition switch to off, connect the test mode connector at the lower portion of the instrument panel on the drivers side, then to turn the ignition switch to "on" and the valve should function.
Old 03-09-2006, 09:54 PM   #3
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Your gas cap was probably left loose, or you filled the car while it was running.
RexyGirl is offline   Reply With Quote
Old 03-10-2006, 08:29 AM   #4
Travis Graham
Member#: 108191
2002 Impreza WRX
Thanks for the info. I'll have it checked out as soon as I can.
Old 03-10-2006, 05:25 PM   #5
Randoramma
Member#: 60649
00RS EJ205 swap
This code is telling the computer that there is an improper fuel supply.
Yeah, check gas cap, then check for:
Clogging of vent hoses between canister and drain valve, Clogging of vent hose between drain valve and air filter, Clogging of drain filter.
See if any of these are the culprit?
Randy
Randoramma is offline   Reply With Quote
Need a CEL code pulled? Look in here for people to PM for help! Penphoe Vancouver Impreza Club Forum -- VIC 10 11-22-2008 11:10 AM
Need a CEL code pulled smokey25 Vancouver Impreza Club Forum -- VIC 17 03-21-2007 05:29 AM
Need some CEL code info. obyone Normally Aspirated Powertrain 3 04-15-2003 03:25 AM
Need Help Pulling CEL code cvsinner Bay Area Impreza Club Forum -- BAIC 4 04-04-2002 10:51 PM
Need help pulling CEL code Senger Bay Area Impreza Club Forum -- BAIC 2 03-01-2002 03:01 AM
