Old 03-09-2006, 11:40 PM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Impression after installing USDM STi TMIC...
For those who have gone from stock TMIC to a bigger TMIC, what was your first impression when you took out for a spin? Did you really notice any difference in terms of power gain and slower turbo spool? I wonder what the expected power gain and affected turbo spools are. Is there noticeably difference between WRX TMIC and USDM STi TMIC?
I installed mine and car seems to be a little sluggish compared to before. My car has revised e-map to accomodate a bigger TMIC so it's not really a tuning related issue. Car doesn't feel that fast anymore, especially in 2nd gear. What could be the problem? It has been about a week and 100 miles since the ECU reflash.
Is it possible for a car to lose power in 2nd gear while gaining power on other gears? My butt dyno tells me that other gears feel about the same as before.
gopsu is offline   Reply With Quote
Old 03-09-2006, 11:52 PM   #2
Davenow
Member#: 23676
Your map is most likely made for a bigger tmic that has MUCh different flow characteristics than the STI tmic. The STI tmic isnt really much of an upgrade over the stock 02-05 WRX tmic.
You are probably not mapped correctly for that TMIC and the car is probably detonating as a result. Which would explain the power loss.
Now if you had an 06 WRX, there is a good reason to go to the STI tmic, but its still not really THAT much of an upgrade.
Your map is probably made for a bar plate TMIC as opposed to the restrictive tube/fin design of the STI tmic. There is over a 2lb difference in the pressure drop.
Old 03-09-2006, 11:59 PM   #3
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
I changed out my stock 02 WRX TMIC for one of them U Beaut Big Fat TMIC's from Ebay. Result.....
A little more lag, Butt dyno says sustained acceleration greater and ears say the turbo spin sound is louder. Don't understand why the last point....
renhoek is offline   Reply With Quote
Old 03-10-2006, 01:12 AM   #4
gopsu
Member#: 96448
02 WRX VF34
Davenow,
Will my car perform better with USDM STi TMIC over regular TMIC if I go back to regular stage 2 map? how much of a difference do you think there is between regular TMIC and USDM TMIC maps? according to the tuner that remapped the real time map (for TMIC), BCS duty cycle was turned down a little.
Old 03-10-2006, 02:12 AM   #5
BGPunk2001
Member#: 46134
meh, i would get the car tuned in person if i were you.
BGPunk2001 is offline   Reply With Quote
Old 03-10-2006, 08:59 AM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
15% difference... bet/ WRX and USDM STi TMIC?
Old 03-10-2006, 09:56 AM   #7
shogun90
Member#: 54858
2004 WRX Premium
Platinum Silver
When I installed mine on MY04 AP stage 1, I didn't notice any performance difference. I did notice that the factory boost gauge did read more vacuum off throttle than with the stock TMIC. It was ready -.07kPa.
shogun90 is offline   Reply With Quote
Old 03-10-2006, 11:01 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
who did the e tune?
why did they decrease bcs dc?
there's more to tuning for a bigger ic than this.
Old 03-10-2006, 11:50 AM   #9
gopsu
Member#: 96448
02 WRX VF34
Not sure why they decreased bcs dc.... they said the map was designed for STi TMIC.
Old 03-11-2006, 01:28 AM   #10
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default sti tmic
when i put on my sti TMIC i didnt notice any difference except the intercooler didnt get headsoaked, which is really good.
All4bSpinnin is offline   Reply With Quote
Old 03-11-2006, 04:46 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The STi tmic really should be used with the matching scoop splitter/skirt.
Forcing the air through the IC by using the proper splitter/skirt makes a(BIG) difference.
Someone I know put an STi tmic on his stage2 bugeye wrx, stock scoop and took the splitter out....results were
Installed the splitter(and STi scoop) and it was like driving a different car.
....another local used a v7 tmic on his LGT with a big turbo(gt30, IIRC) and made 380whp with it
Old 03-12-2006, 04:01 PM   #12
gopsu
Member#: 96448
02 WRX VF34
Scotty, I just placed an order for USDM STi splitter and shroud (my car already has STi hood scoop). I am not sure if air splitter is the main cause since outside temperature was relatively cold and IC was not warm to touch. I also have Cusco HS...
Old 03-12-2006, 08:31 PM   #13
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
Originally Posted by gopsu
Attached is data logging from 3rd gear pull. How does it look?
It'll be a better fit, if it's an 04/05, if you use the plain WRX scoop with the v.7 splitter. With the v.7 splitter and the 04/05 STi scoop, there was a good 1-1.5 inches of dead space between the top of the splitter and the bottom of the interior or the hood scoop.
richde is offline   Reply With Quote
Old 03-12-2006, 08:38 PM   #14
gopsu
Member#: 96448
02 WRX VF34
richde, my car is 2002 WRX. Will fitment be ok using V8 splitter and shroud on bugeye?
Old 03-12-2006, 10:51 PM   #15
gopsu
Member#: 96448
02 WRX VF34
Based on above data logging, isn't there a sign of knock?
Old 03-12-2006, 11:12 PM   #16
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
another datalogging after install...?
Old 03-12-2006, 11:20 PM   #17
richde
Member#: 79498
2013 XV Silver Slug
Oh, then you'd be golden with the v.7 splitter and shroud with the STi (bugeye) scoop, that's what it's made for, not the huge gaping 04/05 STi scoop. Couldn't tell since you didn't have your model name under your name.
Old 03-13-2006, 01:52 AM   #18
Davenow
Member#: 23676
The problem, like I have said a million times, is that while the STI TMIC is larger, it doesnt flow any better. You CAn dissapate a touch more heat, but not enough to make a difference worth spending the money on (unless you have an 06 with that joke of a TMIC).
Much of real gains from a REAL tmic upgrade come from the dramatically decreased intake tract flow restriction. Your turbo has to work WAY less to make the same boost pressure. So not only can your shiny new TMIC dissapate a HELL of a lot more heat than the STI TMIC, but there is LESS HEAT TO BEGIN WITH. You also spool sooner, boost ramps up harder, and you hold more boost to redline.
And you can get that for about $500.
Or you could spend 250-400 to "dissapate a little bitmore heat" and gain zip.
Unless you have the 06 wrx, buying an STI tmic is a waste of money.
Old 03-13-2006, 02:52 AM   #19
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Davenow, do you have links or something to some flow testing on the STi TMIC vs the WRX TMIC?
I find it difficult to swallow that the physically wider endtanks and core of the STi TMIC doesn't present a smaller pressure drop than the WRX TMIC. And the core definitely dissipates a lot more heat since it's got like 50% more area.
Also, I think you can gain a lot from knife-edge porting and polishing the inlet y-pipe and and outlet duct of the IC. I did that on mine and It makes me happy inside. The stock ypipe and outlet duct are horrendously square-edged.
nhluhr is offline   Reply With Quote
Old 03-13-2006, 09:58 PM   #20
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am also curious about flow test on STi TMIC vs. the WRX TMIC...
Old 03-13-2006, 10:15 PM   #21
Ohannon7
Member#: 63824
05 WRX WRB pearl
Cobb II+
*werd*
awaiting those tests
Ohannon7 is offline   Reply With Quote
Old 03-14-2006, 01:10 AM   #22
dpk777
Member#: 97537
2005 Saab 92x Aero
what's the best & cheapest bang-for-the-buck tmic upgrade?
dpk777 is offline   Reply With Quote
Old 03-14-2006, 01:48 AM   #23
MrWhite
Member#: 80123
I bought an ebay special TMIC and the change was pretty drastic on my car. Car definately pulled harder, but yeah spool time got little worse. However, I do notice that the intercooler stays a lot cooler than stock. Then again, I'm a polish w**re. That could have been part of it too. I'd tell you to go with the TMIC is you're ready for a PITA install. Or, get a used one off the classified. Like a MRT or turboxs.
MrWhite is offline   Reply With Quote
Old 03-14-2006, 06:48 PM   #24
Ohannon7
Member#: 63824
05 WRX WRB pearl
Cobb II+
I really didnt think the install was that hard, atleast for the STi top mount
Old 03-14-2006, 07:00 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It's very easy for JDM STi TMIC. For USDM TMIC, it requires some work...
Summary: USDM STi TMIC installation txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 338 11-14-2013 09:17 PM
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 05:20 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 04:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 03:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 04:16 PM
