Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Legacy Specific Parts
Old 02-15-2006, 01:31 AM   #1
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Default For Sale: 1998 Subaru Legacy 2.5GT Wagon
For Sale:
1998 Subaru Legacy 2.5GT Wagon 5 Speed Spruce Green Pearl
VIN# 4S3BK675XW6305101
All Wheel Drive
2.5L 4 cylinder 16 Valve DOHC Phase I
5 Speed Manual Transmission, 4.11:1 Gear Ratio
Dual air-bags
Anti-Lock Brakes, 4-channel ABS
Power windows, door locks, and outside mirrors
Height Adjustable Driver's seat, with lumbar support
Wood Trim package
GT Performance Exhaust
Halogen Fog Lights, projector beam
Fold down 60-40 rear seat
Cargo area retractable cover
Sunroof
Keyless Entry
Security System Upgrade
Rear Spoiler
Rear Cup Holder
Tweeter Kit
Add Ons
K&N Air Filter
14lb Lightweight Flywheel
EXEDY Clutch Kit
Sylvania SilverStar Headlights
Subaru Anti-Slip Mat
Info
179,000 miles (mostly highway miles)
Only 2 owners, me and my brother
New front CV Axles
New head gaskets, valve job, heads re-shimmed recently
Body in excellent condition with only a few small dings and rock chips
NO RUST
Paint is still shiny always garage kept
Engine leaking something onto exhaust
Kelley Blue Book Value is $4,475
Only Asking $3,975
Will Deliver within 100 miles of Sioux Falls, SD 57105 or local pickup. Cash or Money Order only. PM me with your email address for pictures upon request.
dan_j_b is offline   Reply With Quote
Old 02-15-2006, 01:35 AM   #2
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Default Service History
Date Work Performed Mileage
7/1/1999 Recharged AC 23,001
7/23/1999 Replaced bent antenna, fixed leaky sunroof, replaced exp. Valve, recharged AC 23,713
9/30/1999 Replaced brake master cylinder (recall) 25,797
10/7/1999 replaced radio, bleed brakes 25,798
1/12/2000 replaced broken cup holder 35,994
2/21/2000 installed new tires, plugs (Bosch Platinum +4) 39,124
3/24/2001 replaced broken left mirror/touch up paint in area 73,336
7/13/2001 replaced alternator (recall) 75,507
8/15/2001 installed K&N air filter 77,481
11/29/2002 replaced timing belt, idler pulley, belts, front oil seal 98,102
1/14/2003 installed new tires 106,462
7/30/2003 replaced front brakes, rotate tires 118,567
10/4/2003 all wheel alignment, rotated and balanced tires 124,576
1/24/2004 Purchased From Paul 131,363
6/17/2004 replaced water pump, timing belt, radiator hoses, plugs (Bosch Platinum +4) and thermostat 140,168
8/9/2004 replaced front right hub assembly and lower ball joint 142,883
10/23/2004 swapped engine with used Phase II DOHC (105k) temporarily, replaced rear disks and pads 146,702
10/27/2004 installed new tires (9/32 tread) 147,524
11/3/2004 all wheel alignment 148,190
12/31/2004 had heads planed, valve job, reshimmed, replaced exhaust valve, head gaskets, head bolts, cam seals, front crank seal, oil o-ring, exhaust gaskets, rear main seal, valve cover gaskets, thermo
gasket, installed Exedy clutch (disk, pressure plate, throw out bearing) and 14lb flywheel. Swapped engines back
1/11/2005 installed SilverStar headlights
1/15/2005 installed OEM thermostat back in and seal
1/18/2005 installed new front O2 sensor and ignition wires
4/2/2005 installed updated aluminum rear cover, rear main seal and put OEM water pump back in and seal
4/20/2005 installed new OEM platinum spark plugs
4/22/2005 Had codes P0507, P1507 - Subaru fixed it by loosening the throttle cables 158,422
8/11/2005 replaced front right CV axle, lower ball joint, inner tie rod and boot 166,120
9/9/2005 rotated tires front to back (average 5/32nds tread) 168,712
10/19/2005 replaced front left CV axle 172,041
11/26/2005 Changed transmission fluid / front differential fluid 175,251
Old 02-15-2006, 01:40 AM   #3
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Old 02-15-2006, 01:22 PM   #4
Huffer
Member Sales Rating: (9)
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Clean! Dammit! So far away!
Huffer is offline   Reply With Quote
Old 02-15-2006, 01:29 PM   #5
Rice & Gravy
Member Sales Rating: (38)
Member#: 39569
09 Acura TSX 6spd
Mod list: new tires
Looks really nice. Good price too. 2nd Gen green legacies will always hold a place in my heart. My first Subaru was a '99 L wagon.
Rice & Gravy is offline   Reply With Quote
Old 02-20-2006, 11:57 PM   #6
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Thanks for the compliments. If anyone is interested, you can call me at 605-310-3171
Dan
Old 02-21-2006, 12:18 AM   #7
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
some inside pics would be nice... I'll ask around dallas if anyone wants to fly and drive back to get them a good deal...
janikphoto is offline   Reply With Quote
Old 02-21-2006, 12:19 AM   #8
Wiscon_Mark
Member Sales Rating: (5)
Member#: 94945
2012 Impreza
Sport Limited DGM
looks great! Best of luck with the sale
Wiscon_Mark is offline   Reply With Quote
Old 02-21-2006, 02:01 AM   #9
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
I'll take some interior pics tomorrow if I get a chance
Old 02-21-2006, 11:00 AM   #10
jbilbo
Member Sales Rating: (1)
Member#: 26080
1997 Legacy GT
Black aka "Black Betty"
I would love to have this car!!!! Too bad its not closer to Bham AL.
jbilbo is offline   Reply With Quote
Old 02-21-2006, 03:42 PM   #11
Huffer
Member#: 36735
99 GF8 Impreza 2.0
Any idea what's leaking, and where from?
Old 02-21-2006, 07:25 PM   #12
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
Pretty much my car, except in green & a 5spd. I wish I had a 5MT
Good luck with your sale!
GTWagon_Phreak is offline   Reply With Quote
Old 02-21-2006, 07:59 PM   #13
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
not 100% on what it is leaking, but I have to top off the PS fluid once in a while, so thats probably it.
Here are some new pictures, mostly of the interior.
http://www.subaru-svx.net/forum/show...6&postcount=11
http://www.subaru-svx.net/forum/show...6&postcount=12
Old 02-26-2006, 04:47 PM   #14
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
SOLD!
Thanks for looking
Dan
Stock 1998 Subaru Legacy 2.5GT parts stargazerarizona Suspension/Brakes/Handling 6 11-05-2011 12:52 AM
FS: 1998 Subaru Legacy 2.5GT Limited Edition $3500 gforce MAIC Private Classifieds 15 11-24-2008 09:49 PM
Want to buy a stop tech kit for my 1998 Subaru Legacy 2.5GT AWD GotTurbo Subaru Conversions 7 08-25-2004 05:06 AM
Want to buy a stop tech kit for my 1998 Subaru Legacy 2.5GT AWD GotTurbo Brakes, Steering & Suspension 0 08-17-2004 05:43 PM
