Old 03-10-2006, 10:44 AM   #1
GM02WRX
Member#: 16989
Cobb Stg.2 PSM
Default Headers w/ Cobb VF34 93Oct. ots map?
I will be upgrading to Cobb stage 2.5 next week. In addition to the standard upgrades required for this stage, I'd like to also add a Helix TMIC and a set of headers. Does anyone know of any problems with doing so? I am in Miami and there are no protunes available anywhere in FLA as far as I know, so the off-the-shelf map will have to do. Please help.
GM02WRX is offline   Reply With Quote
Old 03-10-2006, 10:52 AM   #2
23b_Rex
Member#: 79394
02 gda
wrb
headers aren't certified compatable with the mapping... and know that they'll hurt your low-end performance
check your guages and log some runs.. if everything turns out ok then
23b_Rex is offline   Reply With Quote
Old 03-10-2006, 11:03 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Post in the right forum
2. Read the sticky in the right forum
Had you done 1 and 2 you would have seen this: http://forums.nasioc.com/forums/showthread.php?t=940483
Old 03-12-2006, 01:13 AM   #4
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
a simple "yes" or "no" would've been sufficient, but that would've been too easy
WolfInSheepsCLothing is offline   Reply With Quote
Old 03-12-2006, 04:36 PM   #5
flabele
Member#: 87475
2005 VF-34 / COBB
PSM SILVER ( not pms )
I am running a top mount helix myself with the ots map. No problems. ANd pulls harder in third gear..
flabele is offline   Reply With Quote
Old 03-13-2006, 01:21 PM   #6
GM02WRX
Member#: 16989
Cobb Stg.2 PSM
Where did you get the TMIC from? What'd you pay (if you don't mind my asking)? How long did you have to wait for it?
Sorry,...it's just that no one seems to have the damn thing in stock!...
Old 03-13-2006, 01:51 PM   #7
fliz
Member#: 30342
I've got Borla headers, Helix TMIC and K&N intake (plus standard 2.5 mods). When I went in for my protune, the OTS map was running less than 10:1 AFR, and pulled timing at multiple points on the baseline runs.
fliz is offline   Reply With Quote
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 09:01 AM
Best runs on Cobb Stage 2, OTS maps MaxSTi05 Proven Power Bragging 41 10-04-2008 07:41 PM
Cobb FP18G ACN OTS Map CRAZY overboost tangmonkey AccessPort 14 05-05-2008 02:02 AM
safe running cobb stage 2 OTS map with catless tbe + megan headers? spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2006 06:41 PM
Stock turbo with sti tmic and protune, or vf34 and OTS map?? scoobtothenoog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 86 02-18-2006 02:39 AM
