Old 03-10-2006, 06:30 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default ECUExplorer data logging question
I am new to ecuExplorer software.
In order for a tuner to adequately understand car's tuning, how long do I need to drive the car for to store all necessary data? do I need to push my car to the limit so that tuner can see all parameters?
I just got a USB to serial cable for $35.99
Thanks!
Old 03-10-2006, 06:41 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
For WOT tuning just do a few pulls in an upper gear to get some info. Record IAM, IAT, TPS, RPM, MAP, IDC (woah acronyms ), engine load (if avail), and fuel trims at min. For more complete tuning just log a few trips around town and things like pulling onto a highway - it should provide more than enough of nominal data.
cdvma is offline   Reply With Quote
Old 03-10-2006, 07:17 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here are a few parameters available... which set of data are required by tuners to determine if their emap are optimized?
- Mass air flow
- air fuel learning #1
- air fuel correction #1
- engine speed, vehicle speed
- throttle opening angle
- coolant temperature
- intake air temperature
- ignition timing
- atmospheric pressure
- knock correction
- Throttle sensor voltage
- air flow sensor voltage
- battery voltage
- fuel temperature
- fuel tank pressure
- manifold relative pressure
- CPC valve duty ratio
- Primary wastegate duty cycle
- Rear O2 sensor
Old 03-10-2006, 10:31 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
any tuning experts want to chime in here? here are data logging date from 2nd and 3rd gear pull.
Time Engine Speed (RPM) Throttle Opening Angle (%) Mass Air Flow (g/s) Ignition Timing (BTDC) Vehicle Speed (KPH) Knock Correction (BTDC)
0 2042 27.84 32.14 20 30 1
270 2137 17.25 34.91 25 29 4
501 2252 17.25 33.57 27 29 1
731 2363 17.65 36.13 27 32 2
961 2463 18.43 38.75 27 32 4
1192 2605 18.82 42.59 27 34 5
1422 2669 18.82 44.51 27 34 6
1652 2806 28.24 52.71 26 38 7
1883 2901 33.73 69.26 20 38 8
2113 3072 74.12 88.95 16 40 9
2343 3324 100 115.59 12 40 8
2574 3495 100 135.38 8 45 7
2804 3771 100 154.88 8 45 7
3034 3925 100 161.34 9 49 7
3265 4160 100 171.18 9 49 7
3495 4417 100 181.44 9 57 7
3725 4618 100 189.14 10 57 8
3956 4845 100 196.18 10 63 8
4186 5085 100 202.22 11 63 7
4416 5256 100 206.19 11 71 7
4647 5494 100 207.39 13 71 8
4877 5660 100 212.15 13 78 8
5107 5873 100 212.54 14 78 8
5338 6053 31.37 210.96 16 85 8
5568 6097 0 21.03 12 85 0
5798 5415 27.45 24.23 13 90 0
6029 4928 100 148.86 17 90 9
6259 4438 100 168.97 -15 93 8
6489 4433 100 173.82 11 93 8
6720 4610 100 179.85 11 96 8
6950 4702 100 187.66 11 96 8
7180 4820 100 195.44 10 100 8
7411 4937 100 198.78 10 100 8
7641 5033 100 200.64 11 104 8
7871 5092 100 206.75 11 104 7
8102 5179 100 209.7 11 109 7
8332 5415 0.78 208.13 12 109 5
8562 5597 0 16.26 12 113 0
8793 5085 0 21.12 12 113 0
9023 4653 0 20.87 12 116 0
9253 4144 0 19.2 12 116 0
Old 03-11-2006, 12:38 AM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Why isn't BCS duty cycle contained in ECUExplorer parameter list?
Old 03-12-2006, 06:59 AM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Anyone???
Data Log question KDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-07-2009 03:19 AM
Data Log Question? Sports Wagon Rocky Mountains Impreza Club Forum -- RMIC 7 06-25-2009 03:00 PM
Newbie question about data logging... ECUexplorer wrxrex Newbies & FAQs 20 12-06-2007 02:36 AM
data logging questions kirbwrx AccessPort 13 10-13-2007 06:14 AM
rehash obd 2 / unichip data logging question Tex-WReX2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-20-2001 10:22 AM
