Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-10-2006, 11:36 PM   #1
MonoxideChild
Member#: 107739
04 Ej20
Default 04 wrx, cel flashing. utech installed
i noticed my cel flash today i think 3 times. it was when i got on the throttle pretty hard in 1st gear. what could that mean. i have the TXS up pipe,and TXS tbe. im at 2nd stage on the utech,i think my abc is three turns from fully seated.
MonoxideChild is offline   Reply With Quote
Old 03-11-2006, 12:58 AM   #2
The Cheat
Member#: 66044
2004 WRX/1994 Miata
the cel flashes when there is knock.
The Cheat is offline   Reply With Quote
Old 03-11-2006, 01:54 AM   #3
Gethin
Member#: 2998
the basemaps are poo. Get it tuned. They run pig rich and are designed for 93 octane. My AFR dipped into the 9's on the stock stage 2 basemap.
Gethin is offline   Reply With Quote
Old 03-11-2006, 10:56 AM   #4
MonoxideChild
Member#: 107739
04 Ej20
Default utech
so then does it mean i damaged anything then, would it be safe to wait one more month ,thatway i can get it tuned when i get my super 16...or do i really need to get it tuned now...?
Old 03-11-2006, 11:35 AM   #5
Bill5998
Member#: 106917
The exact same thing happens to me.
Bill5998 is offline   Reply With Quote
Old 03-11-2006, 11:46 AM   #6
kcook
Member#: 78074
2005 STi
the abc should be 2 turns
kcook is offline   Reply With Quote
Old 03-11-2006, 01:34 PM   #7
Gethin
Member#: 2998
the number of abc turns open depends on your car, each is different. Some can run without it, some need it opened up 5-7 turns for example.
Just drive gently until you get it tuned or you tune it yourself, epsecially if you are getting det on the stock stage 2 map. If you're not running at least 93 octane for starters you need to remove some timing.
Have you done any logging? Remember the UTEC is not really a set and forget like the AP or ECUTEK. So after loading the basemap, close the abc fully, then do some logged runs (using logger #1) and see what your numbers are like. The boost map needs to be tuned for starters then work from there.
So in summary, dont "got on the throttle pretty hard in 1st gear" until you're sure what the UTEC is doing! i.e. datalogg.
Old 03-11-2006, 04:30 PM   #8
MonoxideChild
Member#: 107739
04 Ej20
aaahhh.. thankyou...!
04 STi: CEL + flashing cruise light + rattly exhaust + <3psi boost Dirty25RS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-19-2010 05:07 PM
04 WRX - Going to be installing STAGE 1... Real Time vs Base map Question. Jeenyus AccessPort 10 12-27-2007 02:44 PM
04 WRX rear strut bar install help 04REX85 Newbies & FAQs 5 11-30-2005 11:01 AM
02-04 WRX Cel Fix wrxwhip Private 'For Sale' Classifieds 0 08-03-2005 04:12 PM
Stock 04 WRX, CEL - O2 sensor, slow response... Spectre186 Service & Maintenance 4 06-22-2005 06:06 AM
