Old 03-11-2006, 01:14 AM   #1
ruski
Member#: 63928
2005 WRB STi
1975 Porsche 914 V8 Swap
Default BASE MAP: Valet Mode Questions
I've had my car at a body shop for a while (other story...), but I got it back tonight. Before I brought it to the shop I loaded the Valet Base map. I didn't have time to change the base map when I picked it up so I flashed the the cobb stage 2 real time map. I start driving and everything seems fine, however i slowly creep past 3100 and I hit the limiter from the valet mode but I did flash the stage 2. Anyone have any ideas why this happened? Is there any way to verify what real time map is loaded?
Quick Sum:
1. Loaded Valet Mode Base Map
2. Loaded Cobb Stage 2 Real Time Map
3. Car still wouldn't go pas 3100rmp
4. Why?
Evan
ruski is offline   Reply With Quote
Old 03-11-2006, 02:36 AM   #2
Carizme
Member#: 59848
2004 FXT 5 Spd
My guess....
I would say because your realtime map only tweaks your car up until 3200 and then the base map takes over
Excerpt from cobb tuning
Additional Notes:
"Map designed to prevent abusive driving when using a valet service. When using the Real Time map, the valet may clear the ECU memory with a hard reset to revert to your base mapping"
From this I'm taking the notion that your base map should be whatever and then you're supposed to flash the valet realtime. Valet mode isnt intended to have a "Stg anything" flashed as a realtime.
Carizme is offline   Reply With Quote
Old 03-11-2006, 04:38 AM   #3
ruski
Member#: 63928
2005 WRB STi
From my understanding the realtime map takes over, it dosn't take over part way. I could see a map from other than Cobb not working, but I'm using cobbs realtime map.
I swore I even read somewhere that it shouldn't still have the 3200rpm limit with the realtime map. I'll send an email to cobb but they take forever to answer.
Stage 2 and valet mode question the Stryder AccessPort 3 02-16-2010 11:12 AM
AP Valet Mode Map Question STINOMORMONEY Newbies & FAQs 6 08-20-2008 07:40 PM
Question about CEL and Valet Mode ( AP ) Dragonbreak North West Impreza Club Forum -- NWIC 2 08-15-2007 05:22 PM
Valet mode question WR-REX Engine Management & Tuning 7 05-07-2004 06:34 PM
Security System stuck in Valet Mode??? cincyRS Technical Forum Archive 2 07-21-2000 09:24 AM
